Question about Singer Featherweight 140Q
Oiling for the Singer 140Q
There seems to be no mention of where to oil the machine in the owners manual. Or even any mention that lubricating is part of regular maintenance but it sure sounds like it needs some.
  • 255 Answers
SOURCE: Is it safe to use WD40 oil to lubricate my singer
Hi. No, don't use WD40 oil to lubricate your Singer. Use sewing machine oil--it's a whole different breed of animal than WD40 and won't hurt your machine. You can easily find sewing machine oil at Jo-ann's, Hancock's, or any other local fabric and/or craft store. It's not expensive, but repairing the insides of a machine gummed up from WD40 IS!
Good luck and let me know how this works.
Robbie
Posted on Jan 11, 2010
  • 33 Answers
SOURCE: maintenance of Athena 2000 (Singer), specifically,
http://www.threadsmagazine.com/item/4731/preventive-sewing-machine-maintenance
http://esostarikaknitfo.blogspot.com/2007/05/how-to-clean-your-sewing-machine-101.html
These might give you an idea on cleaning and oiling your machine - I also use my vaccum cleaner sometimes- but very carefully.
Always use sewing machine oil - singer brand is good. - If you have pipe cleaners they are good to use on hard to reach places.
Posted on Feb 16, 2010
  • 2501 Answers
Use sewing machine oil but be sparing with oil, as it can collect dust and clog the machine.
Posted on Feb 21, 2010
  • 1116 Answers
SOURCE: I need the oiling instructions for a Singer 9410 sewing machine
You can get a free download from Singer. The maintenance section should have the information you are looking for.
http://www.singerco.com/accessories/manuals.html
Posted on Apr 20, 2010
  • 980 Answers
SOURCE: Where do I oil this machine?
You can only oil modern machines on the moving parts that you can see.
Posted on Jul 23, 2010
Where do I oil this sewing machine?
you did not provide the name and model number of the sewing machine or serger, so the only thing I can suggest is look in the instruction manual if you have one, the information should be in there.. if you don't have a manual, provide a name and model number and some one will try to help you find a manual
May 07, 2016 | Sewing Machines
Thehook assembly will not move when you turn wheel
Could be a multitude of issues depending on your machine make & model. If it is an older mechanical machine, it most likely seized due to lack of regular cleaning and oiling. Consult the owner's manual for maintenance instructions and use ONLY fresh good quality sewing machine oil & applying only 1-2 drops of oil each spot.
You can take it for the standard sewing machine checkup service.
If you have the patience and time, you can try fixing it yourself:
http://www.fixya.com/support/t25934410-wheel_right_side_controls_needle_up_down
In the future, be sure to clean and oil regularly (every 40 hours of sewing, every 6 months if not in use). Use ONLY fresh good quality sewing machine oil, applying 1-2 drops of oil each spot. Consult the owner's manual for instructions.
Dec 24, 2015 | Sewing Machines
Do I need to oil the 7200? Manual does not mention it.
There are no user oil spots on the elna 7200. It does require lubrication. It is important to take these modern machines in for service by a professional regularly.
Jan 31, 2014 | Elna 7200 Computerized Sewing Machine
Should the Simplicity SE3 embroidery machine be oiled by the operator
If the manual doesnt mention oiling at all, then it probably has silicon or nylon parts not needing lubrication. It may also have oiling wicks which the technican will attend do during the regular services that the manufacturer probably recommends annually in the manual.
You do need to clean out the bobbin area regularly though and your manual should mention this, lint will build up in any sewing machine and affect perforance.
May 15, 2011 | Simplicity SE3 Computerized Sewing Machine
How and where do I put oil in my hobby 303 sewing machine? Can I use WD40 to oil my sewing machine?
Don't use WD40, as if it gets onto paint or plastic it could damage the surface.
Use clear sewing machine oil.
You can purchase a manual for this machine from here http://sewingonline.co.uk/library/pfaff-303-301.html - the manual will identify the oiling points, for a mechanical machine there is usually a point within the rotary hook area that will need lubrication (and regular cleaning of lint and dust).
YOu can find general machine maintenance tips here http://sewing.about.com/od/sewingmachineindex/a/machinemaintain.htm
Your machine may have marked oiling points with a red dot - each machine is a little different hence the manual is always best reference point.
Apr 28, 2011 | Sewing Machines
How to oil a sewing machine
Computerized sewing machines are not to be oiled.
The lubricant is factory sealed and any additional lubrication is to be done by a sewing machine tech that is certified to work on your particular brand of computerized sewing machines.
The maintenance section of the manual for your machine will indicate how to clean the machine.
Be sure the needle is at it's highest position when removing and replacing the bobbin case.
Apr 30, 2010 | Brother CS6000i Computerized Sewing...
Where do i oil it
Check your owners manual under "Maintenance" it should tell you and even illustrate the points that should be oiled regularly. Have a great day!!!
Apr 18, 2010 | Brother LS-1217 Mechanical Sewing Machine
Oiling a pacesetter
No oiling by the user.
Computerized machines are lubricated and sealed in the factory.
If you are the original owner, you could invalidate your warranty if you go beyond the maintenance routine described in the manual.
To keep the warranty, your machine is to be serviced by an authorized Brother tech on a regular basis - once a year if it gets heavy use.
General maintenance, per the manual, will keep the machine in good working condition.
Mar 31, 2010 | Brother PC-6000 Pacesetter
How do I lubricate/oil my Pfaff 2054? There's nothing in the owners manual.
Oiling the sewing hook is about all that you can do and that is the most important. Somewhere in your manual will be a mention of oiling the hook.
Jan 09, 2010 | Sewing Machines
Rattle in the movement of my Riccar 807
Even though the machine was bought 30 years ago, we overcame the problem by lubricating all the moving parts indicated in the manual with a silicone lubricant. We would have used a recognised sewing machine thin oil; but living deep in the French countryside, we didn't have access to an outlet and we had a deadline to meet for the work we were doing.
It now seems to be silent and smooth-running. The problem only arose when my wife changed her choice of settings from one of the ones she regularly uses to one that she had never used before. Thank you
Feb 14, 2009 | Riccar R552
Singer Featherweight 140Q Logo
77 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
