Question about Compaq Presario Notebook
Compaq presario m2000
When i switch on my computer i only see the screnn:
press f1 to resume pres f10 to setup
but nothing happend when i did this
  • devi lal May 11, 2010
    cq 40 133tu driver
  • 541 Answers
Try puting in an xp disk in and leave it to boot up if it dose the same you need to reinstall windows
Posted on Nov 17, 2008
I have a COMPAQ Presario M2000 laptop Win XP with latest updates, 5yrs old, working fine till recently. after switching on , hear two BEEPs & can see the black screen with COMPAQ logo, then Press F1...
Hello cgilpin659,
There is usually an error code that comes with the 2 beeps post error. This link shows what the error code for the 2 beeps might mean: http://www.kiesler.at/faq14.html
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Apr 25, 2011 | HP Compaq dc5000 Small Form Factor PC...
My Compaq V2000 beeps twice & freezes
It sounds like the RAM is either not compatable or is bad. Put the old RAM back in and try again. Also the V2000 and HP DV2000 is in recall for mother board problems.
Nov 12, 2009 | HP Compaq Presario V2000 Notebook
When booting computer,then comes F1 to resume
there is a problem of your EP ROM . you need to update your BIOS or you can try by applying default value by pressing F10 During POST.
Try it and reply me
Aug 24, 2009 | Compaq Presario M2000 Notebook
No responce from keyboard
The keyboard is not dead. I have contacted HP about this issue (DO NOT CALL THEM AND HAVE THEM FIX IT! THEY GAVE ME AN ESTIMATE OF $300!) they SAY that it is a hardware issue...
However have found more than one website saying that it is most likely the CMOS battery that has gone dead.
Nov 27, 2008 | Compaq Presario M2000 Notebook
Compaq Presario V2000 boot up problem
i have the same problem with mine, the compaq2_bing.gif screen shows and beeps twice and then it says press f1 or f10 but it doesnt respond to anything i press
Nov 24, 2007 | HP Compaq Presario V2000 Notebook
Unless your machine took a bad fall down some stairs, I am guessing you have a problem with hardware. Unplug the machine and remove the battery. Unplug any external devices like cards, USB devices and printers, etc., and then reboot. Is the hard drive running? Try F10 into setup, and then select LOAD SAFE DEFAULTS AND REBOOT, or something similar. If this does not get it going, check to see if the harddrive or memory has become unseated in their bays somehow. Turn the laptop over, remove the screws covering the little doors, lovingly and gently unscrew the harddrive retaining screw and remove it, and then put it back in and secure the screws. Check to make sure the memory modules are seated correctly, and reseat them if necessary. Then try rebooting. If you get the same problem, go into the BIOS again and check to make sure you are booting to the HDD as first, and then start turning off devices in the BIOS and rebooting in cycles until it boots. Also, try booting to CD (for example, OS installation disk) and if that works, you likely have a boot problem or hardware problem on the hard drive.
Good luck....
Nov 15, 2007 | Compaq Presario M2000 Notebook
wat do u read before this??
Press (F1) to resume, (F10) to setup
I need a bit more info to try to give you an accurate solution
Does the screen change after you press "F1" ?
Do you have access to an external keyboard, if so try plugging that in while the computer is off and then using that to press "F1"
Compaq Presario Notebook Logo
115 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
