Im running my adsl into my modem then to my laptop by wireless signal and then from the laptop to the x-box. the connection is fine its just i cant find anything on my router to change my nat type to open please help
SOURCE: How do i set my Netgear Routers NAT type to open for playing xbox 360 games?
Ok in order to help you resolve this issue I need more information. Is this a newly setup router? Did you setup any type of security? WEP OR WPA these are encryption tools that allow only you to get onto your network.
SOURCE: Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
I assume you know the ip adress of your xbox.
First of all check on your router to see if UPNP is enabled.
Then go to Portforwarding/Port triggering.
Then add custom service
service name: the name of how you call it. doesn't matter really
service type is UDP
start port 88
end port 88
server ip is the adress of your xbox
then apply and make another custom service
name it how you want
service type tcp/udp
start port 3074
end port 3074
server ip adress of you xbox
this should work
SOURCE: How do i change my NAT connection from moderate to open
This one is simple. Find the IP address that your Xbox is assigned by your router, then put it into the DMZ. This also goes for PS3 users who are having trouble with internet access.
SOURCE: Change NAT to open
Go to your router admin panel and into advanced settings and set UPnP (Universal Plug'n'Play) to enable. If that doesn't work then manuallyopen the ports on the IP assigned to your Xbox. Opening NAT all the way is never a good thing. it opens you up for attacks. So with the above mentioned solution, either way, you should game on well!! Go forth and frag!!
the connection from laptop to x-box is by ethernet cable
