Question about RCA D52W19 52" Rear Projection Television
Sparks arcing from rear of tv
While the tv was on it just started arcing out of the rear lower right rear of the tv (looking from the front), opposite side of the plug. I was told it was a high voltage transformer? it has two adjustment ports on the back, one says focus, its a square box with two leads out the top and has a large magnet around it, there is a small hole in the side, looks burnt, and when you plug it in it arcs to the magnet. I was told 600.00+ but they really want to sell me a new set. Any help?
  • jddenton Sep 02, 2008
    i have the same issue on the high voltage transformer (Flyback) on the model HD56W58. This model has HVT, then it has an extension to that on the front. Would you have the part number to this HVT?
    President:
  • 3,130 Answers
Wow they are charging you alot for this repair my friend. Go to this link and you will see! The High Voltage transformer, also known as a flyback only cost 50.00 Bucks!http://www.partstore.com/ProductDetail.aspx?ProductSKU=2187762&ProductType=PART&ModelID=420798 I would get the part and let someone replace it If you have no soldering and or TV repair experience, as this is a dangerous place to be experimenting with if you do not know the safety issues involved. Good Luck Please dont forget to rate this thread.
Posted on Nov 25, 2006
Cracks and pops when turned on and will flash light across screen at times.
That could be a number of things that would make that noise, Have you removed the front panel screen in front on bottom and try turn TV on Look for Spark? Bad anode button on one of the tubes can cause that, bad flyback transfomer.Have you removed back and look to see if arc is coming from the FBT Mounted on Deflection board. First board on the left is the deflection board.
Mar 18, 2015 | RCA D61W20 61" Rear Projection Television
Arc in projection TV
A lot of TV's using CRT tubes have SPARK GAPS, usually on the back of the socket boards. These sometimes arc. None should continue to arc. One snap and that is it...
Dec 29, 2009 | RCA P52926 52" Rear Projection Television
Arcing issue? My tv seems to be arcing in the right rear(facing front of tv) Is it an easy fix that I can do?
Common problem on this tv, ceramic capacitor .087uf 1600V.
Take out the chassis,and inspect under fly bac area, you will se a burn area; replace thsi ceramic capacitor. for parts. go to:
encompass.com thank you
Aug 02, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
1) Right rear burner electric spark always arcs no matter which of the four gas knobs I turn. 2) Right front burner electric spark only works (arcs) when left two burners panel is unplugged or removed.
Sure. Once we realized that you'd charge a fee, we went to our local brick and mortar appliance repair store and got the info needed for free. What happened to free advice?
M
Dec 02, 2008 | Amana Kitchen Ranges
Tv dont work
check fuse in back of tv behind lower panel right where power cord gose in to tv
Feb 28, 2008 | RCA P61930BL 61" Rear Projection...
Arcing in lower back left corner
Replace flyback transformer cost verys from 21.00 - 71.00
Jan 19, 2008 | RCA D52W19 52" Rear Projection Television
T.v. not coming on ,turned off by itself with an arc noise
The part is known as a flyback transformer.. it will have to be replaced.. also the horizontal ouput transistor will possible most likely be bad..
Dec 16, 2007 | RCA D52W19 52" Rear Projection Television
Poping sound, white specks and what looks like sparks
Possible arcing CRT or possible arcing IHVT part # 239111.
Dec 29, 2006 | Proscan PS50700 50" Rear Projection...
Shocking
depends where the sparking is most of the time it's the flyback transformer. other wise the tubes will spark.
Aug 11, 2006 | Hitachi 51F510 51" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
167 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
