How to back up with a floppy disc
I forget how to back up my data. I do it on floppy disc (square shape). How do I do it? iI thought this is chat. Why is it asking for my email and what product?
  • Vikas Garg May 11, 2010
    you have not cleared that what sort of data you want to backup.
    if you want it from some software or is it through windows only.
    if you use CD or now a days a pen drive for the backup it will be better as floppies are not reliable for the purpose.
  • 153 Answers
A floppy disc has only 1.44MB, your data file size must not acceed 1.44MB. You only have to copy and paste your file or data to your drive A, Drive A should be your floppy disk. Make sure your disk is not lock, there is a botom lever that locks the disk to prevent accidents like unexpected deleting. If it's locked you can't copy, past or save data on your floppy disk.
Posted on Nov 14, 2008
  • 84 Answers
First you have to go to the back up wizard... click start, then program, choose accessories, then system tools then choose back up... there is a wizard there that can help u out... this only applies to windows OS especially XP hope this help you out...
have a nice day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Just put in the floppy disk and copy the backup info to A: Let me know if you need more help.
Henry
Posted on Nov 13, 2008
Error message says hard disk failure is imminent. Back up hard disk and replace
Backup all importent data.RUN CHKDSK AS ADMISTRATOR C:\ CHKDSK /F/R OR WITH DRIVE LETTER BAD DISC.is disc older then 5 years think of buying new.
Apr 03, 2013 | HEWLETT-PACKARD Hewlett Packard Pavilion...
Floppy disc does not work on pc
Floppy discs go bad all the time. Test with another floppy.
Dec 09, 2012 | Computers & Internet
Remove hard disc from dimension 3100c
David, this is the Service Manual for the Dell Dimension 3100 Desktop PC,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
Click on Removing and Installing Parts.
Click on Harddrive
1) Pull the SATA power cable out of the back of the Harddrive,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
[ Note the L-shaped slot in the connector. Lines up with the L-shaped tab on the back if the Harddrive ]
2) Pull the SATA data cable out of the back of the Harddrive,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
[Top example is a SATA data cable. The bottom example is a SATA connector on the motherboard. Again note the L-shape in the connector.
The SATA power cable connector has 15 contact pins.
The SATA data cable connector has 7 ]
3) Now press the blue tabs (Clips) towards each other.
(Can also be said as -> Towards the middle of the harddrive )
4) Pull up, and out on the harddrive.
If I may ask, why are you removing it?
Post back in a Comment.
Regards,
joecoolvette
Jul 26, 2012 | Dell Dimension 3100 PC Desktop
Where is the floppy disc on my acer SA80 - Z970
I doubt you have one. Computer manufacturers have not been installing floppy disks for some years now.
Jul 07, 2011 | Computers & Internet
Disc slot
If you are speaking of a 3.5 floppy, you won't find one on the newer systems. 3.5 Floppys are out of date and are rarely put into new sytems. If you have data that you would like to retrieve from some old floppy disks, you will need to go to a computer store ie: Bestbuy or CompUSA and get an external USB Floppy drive. Then you can save them to your hard drive and then burn them to a CD or DVD.
Hope this helps you.
Apr 08, 2010 | E-Machines eMachines Desktop PC
My dc7100 has a compact power supply with proprietary 24 pin plug. Pretty sure power supply is non-functional (shorted green to black and fan didn't come on). Is it possible to rewire a conventional ATX...
I just spotted this, hence the late solution. Perhaps this will help someone in the future.
Yes it is possible.
Observe the color code of the insulation of the wires.
1) Orange wires are 3.3 Volts
2) Red wires are 5 Volts
3) Yellow wires are 12 Volts
4) The Green wire is the Soft Power On wire
5) All Black wires are Ground wires. Doesn't matter which Black wire it is, it's a Ground wire.
(It isn't a Common wire. This is DC electricity, not AC)
These are your main voltages, and wires to be concerned with.
Fortunately all HP, (Or any proprietary computer manufacturer in that time period), did, was to change where the wires are placed in the 20, or 24-pin ATX main power cable connector.
They just moved the wires in the socket holes, didn't change the color code.
Solution is,
1) To remove the wires in the ATX power supply, main power cable connector
2) To remove the wires in the proprietary computer's ATX main power cable connector.
(NOTE*
BE SURE to make a concise, clear, drawing FIRST, of where the colors of the wires went in the proprietary connector, BEFORE you remove them!)
3) To reinstall the wires into the proprietary connector.
(Again. Following the color code of the wires you removed)
Removing the wires out of the 20, or 24-pin ATX main power cable connector:
Observe these photos, of a 20-pin ATX main power cable's connector. This procedure can be applied to a 24-pin ATX main power cable connector also. (Or a 20 + 4-pin ATX main power cable connector)
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
(Also gives you information about the color code of the wires)
The middle photo shows you a view of the Front of the connector.
The photo to the right shows you the Back of the connector.
Where the wires go down into the connector is a Socket Hole.
At the end of each wire is a metal pin connector. A Male pin connector.
This metal pin connector is shaped like a tube on the end, and comes up to a square shape as you go up.
The square shape fits the square socket hole.
On one side of the square shape is a Tang. It's part of the square metal shape, and sticks out away from the square shape.
Resembles a barb on a fish hook.
In this crude illustration, let a small L represent the side of the square shape, and this forward slash - / represent the tang.
l/
This is an illustration from a manufacturer that supplies this type of metal Male pin connector,
http://www.molex.com/molex/products/datasheet.jsp?part=active/0002092166_CRIMP_TERMINALS.xml&channel=Products&Lang=en-US
A needle with the proper thickness so it won't bend, is inserted into the Front side of the socket hole, and is used to depress the Tang.
If you look down into the back of the connector, and into an individual socket hole with a bright light, and a magnifying glass, you will observe that the square socket hole has a small notch in one side.
This is where the tang slides down into.
It isn't easy to see from the front side.
The tang is depressed using the needle from the FRONT of the ATX main power cable connector, and the wire is removed from the Back side of the connector.
The metal pin connector's tube shape only goes up so far, then it turns into a square shape.
The socket hole in the connector is shaped to match. Tube shaped hole at the front of the connector, square shape coming on up to the back of the connector.
The square shape's corners, of the metal pin connector, keep it from coming out of the Front of the ATX main power cable connector.
The tang keeps the metal pin connector from coming out of the Back.
More information about the color code of the wires in an ATX main power cable connector, (Scroll towards the bottom of the page)
http://en.wikipedia.org/wiki/Computer_power_supply
Oct 16, 2009 | HP Compaq dc7100 PC Desktop
My HP s123w Slimline Pavilion will not start up. Every time I turn it on, it goes to a black screen stating "DISC BOOT FAILURE, INSERT SYSTEM DISC AND PRESS ENTER" and I do not have the system disc. Any...
Take the floppy disk out of the drive... this sounds like the classic error when the boot order includes the floppy disk first, and a blank or data (not bootable) floppy diskette gets left in the drive.
There could be another type of drive set as bootable. CD's and DVD's don't normally do this - they usually cause a prompt "press any key to boot from CD..." or similar.
You could go in the computer setup and set the hard disc drive to be the 1st in the boot order and also solve this problem.
Otherwise could be your C: drive got damaged somehow. Virus or otherwise.
Jul 07, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
I have an old e machine Tower Mod.667IR S/N QA309-108-O2995 no manual on hand. Please advise correct drawer ID. Top drawer C or D ? Mid drawer C or D ? Which drawer is the Burn drawer? Bottom...
Your master hard drive will be C, slave hard drive or top media drive will be D, and so on unless you have reconfigured them from the factory setup. Floppy disks only have 1.44 megabytes on them, so easiest way to copy data from them is just to drag and drop all the files into a folder on your desktop. Insert a blank CD-R into your writeable drive...win 2000 will open a blank cd window. drag and drop the files you wish to copy into the blank cd window and click "burn these files to disc". A CD-R has 700 megabytes on it, so roughly 675 floppy discs can be copied to a single CD-R.
Jun 20, 2009 | E-Machines etower 667ir PC Desktop
Which is which
this diffrence is that the floppy disk has pretty much been made obsolete now due to its max compacity of (I belive its only) 2MB where a data cd or DvD can have anywhere up to (at this time and common affordable) is at 3.7 GB withs is almost x2000 bigger. The floppy drive is now commonly used for password backups so if you forget it, you pop in the floppy and its on there.
Aug 31, 2008 | Dell Dimension 2400 PC Desktop
When my mom turns on the compter the computer says nonsystem **** or dic error and replace and strike and key when read and it keeps going back to the same thing when she hit the keys.
Make sure you don't have any discs in any drives when you restart the computer. Unplug any USB devices except mouse and keyboard before re-booting.
Jul 04, 2008 | Dell Dimension 4500 PC Desktop
Computers & Internet Logo
63 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
