Question about HP Computers & Internet
Un-Booting System there is power on the board but nothing seems to work as the screen does not display, the systems does not also send any beeping sign.
  • ceamghana Nov 12, 2008
    I think it may be an overheating problem - which appears to be the norm for this make of computer;
    however, since i am abroad in northern Ghana - I can not guarantee getting to an HP repair workshop.... hence would also be grateful to hear if this problem might be able to be a straightforward one, eg: the computer just needs a rest and then may return normally later when switched on
    or whether to go through the long process, involving warrenty et al.
It didnt work i tried both steps
Posted on Nov 12, 2008
    Guru:
  • 558 Answers
If the system is under warranty then call to nearby repair shop, as the steps given would cease the warranty.
1 Step:
You need to check out its Power unit (SMPS) placed at top in the CPU cabinet. May be it get worn out and need to replace.
2 Step: you can try is to Unplug the RAM (memory Stick) from the Slot and place it again after 10 min and then power on the machine.
Let me know the status after this to help you out. Don't vote till you get the solution.
Thanks,
Scott
  • Puneet Jain
    Puneet Jain Nov 12, 2008
    Overheating problem can be resolved, you can replace the Power supply unit and the cooling Fan of system, If you are able to install them yourself.
    For more help regarding this:
    http://www.pcguide.com/ts/x/ggen02-c.htm...
    http://www.intel.com/cd/channel/reseller...
    Please now vote the solution, will be appreciated.
    Regards
    Scott
Lenevo t61 1 long beep and 2 short beeo no display
Standard Original IBM POST Error Codes 1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Nov 09, 2012 | Lenovo ThinkPad T61 6457 Notebook
PC Freezes During Boot and at the BIOS Screen, EVGA P55 Classified 200
Beep Code Descriptions
Aug 30, 2012 | Evga P55 Classified 200 (160LFE659KR)...
My pc is booting but no display
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
best of luck!
Mar 13, 2012 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
No signal on monitor, vga tested and ok
Mar 11, 2012 | Computers & Internet
Erro sound/pip when ibm 8310 netvista starts, no error message are show on the screen, the screen are black.
how many times it beeps is an indication of the problem
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard cardhope this helps.
Sep 14, 2009 | IBM (09N5424) Motherboard
IBM Think Center A51, 8131-35U will not boot up. Fan comes on but nothing else. Power Supply checks out good. If it is a mother board problem, is it fixable? I tried another hard drive and I do get a...
IF your systems turns on no beeps ...everything seems to work just no display on the screen then i guess would should try discharging your system - ie un plug the power cord take out the Motherboard ,ram , basically take everything apart leave it for a day and connect everything back again ti should work
Sep 05, 2009 | IBM Computers & Internet
Beep sound continus
I went to google and it seems like the beeps can be problems for different problems in the hardware, this is what one message says,  there are lots of computer beeping answers out there: 1 short beep is your BIOS saying "HELLO I'M OK"
3 long beeps keyboard card
Each BIOS company has modified these codes over the years.
May 25, 2009 | Dell Dimension 4600 PC Desktop
My ECS 915 G-A elite group motherboard doesnot display anymore on the monitor..
have you tried to isolate what the cause of the problem? first check the video card if is properly inserted into the slot, and check the memory, and cable from CPU to monitor if it is connected properly. then boot your system. And try to observe this beep error code this might help you locate where the problem is.
short beep System is OK
1 long, 3 short beeps Display adapter problem (EGA)
thnk you.
Nov 29, 2008 | Computers & Internet
Toshiba satellite A100 Monitor problem
LCD issue it needs repair..call tosh if your laptop is still in warranty
Feb 01, 2008 | Toshiba Satellite A100-ST3211 Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
