Question about Cuisinart KUA-17 Cordless Electric Kettle
How do I clean the contact points between kettle and platform?
My kettle keeps going on and off. There must be a problem with the contact between the kettle and the "heating platform." When the kettle is full of water the weight of seems to help make the connection work better. But it often switches on and off and the kettle has to be re-positioned to make it work. How do I clean or replace the contact points? Thanks
  • Luanne Brown Jan 05, 2007
    Thanks! I ended up throwing my kettle away and buying a new one--different brand! The warranty had expired and no one fixes these things anymore. Hate to be a part of the throwaway society. Appreciate your comment! Ickytutu
  • Anonymous Dec 15, 2008
    My Cuisinart KUA-17 is brand new and the auto shut-off clicks off before the water boils, in fact it is only luke warm. Any suggestions?
PROBLEM:
My problem was similar for the Cuisinart KUA-17.  I clicked down the on switch and it stayed down.  However, the light and power together seemed finicky.  That is, the light came on if I positioned the kettle in the base correctly, but then it sometimes went off without triggering the switch to pop up.  When the light went off while the switch remained down the water never boiled, but when I was lucky to position it such that the light remained on, the water did boil and the switch popped up ... as it should have.  It seemed to be getting more and more finicky and difficult to position correctly ... so I took it apart.
SOLUTION:
First of all, the base has screws that take a triangle screwdriver which I don't have.  So I found a small flat-headed screwdriver (like one you'd use for glasses) that just fit along one side of the triangle.  I was able to get three base screws out this way and since I expected to need to do this again in the future, I used my dremel to grind a larger flat-headed screwdriver slot in each.  It's been about a year and a half since I fixed it last time and this time I was glad I had the slots.
Once you get the plastic base off, you'll see the mechanics of the switch.  There are two wires that both turn on the light and power the heater element.  Where the wires connect to the switch mechanism, there are two metal tabs that stick out in opposite directions from the center.  When the switch is pushed down, you can see these two tabs move.  They are each moving to touch a contact and complete the electrical circuit.  My problem was they were not making a good contact.  The contacts are hidden behind the tabs.  All I had to do was bend the contacts one millimeter closer (i.e. as little as possible) so that they would make a good contact.  The only other trick was I had to remove the switch mechanism from the bottom of the kettle to do this.  Then I just used the same small flat-headed screwdriver to bend the contact as in the picture below.
Posted on Mar 11, 2009
  • Anthony Hill Oct 24, 2011
    You can also use a small hex wrench to undo the triangular screws.
You can use the hex wrench to pry the contacts up without removing the switch mechanism from the base.
Posted on Oct 24, 2011
Scott Cowan's solution fixed my Cuisinart electric teakettle! My dad followed his instructions. One of the screws with the triangular slots was very difficult to remove but he tried some sort of pincer-like tool (w bent/curved ends) and was able to get it unscrewed. It works like new.
Posted on Mar 17, 2009
I had the same problem before mine broke completely (see my problem posted today). The problem seems to be the support that holds the center pin inside the control. I have not been able to fix mine. Now it is totally broken and Cusinart has been no help. How old is your unit? Cuisinart told me that there is a 3 year warranty. Give them a call. They can decide based on the serial number whether they will cover it.
Posted on Jan 04, 2007
It beeps and the temperature light comes on but then it immediately fades and the kettle does not heat up.
I had the same problem after 2 years usage and found the problem to be the contacts between the kettle and base.
  • Unplug the base and using a very thin needle file clean the 3 contacts and centre pin carefully. These contacts are sprung metal, so be careful to apply slight pressure in a clockwise direction.
  • Next empty and upend the kettle, now use a fine abrasive pad (I used a piece of 'wet and dry' paper) and gently clean the surface of the contact rings.
  • Clean away all dusty residue, this should cure the problem.
Jan 13, 2016 | Bosch Styline Collection Kettle Twk8633gb,...
Mt HB kettle 40886 has stopped working. The switch moves into place, but doesn't light up or heat up the water. Can I fix this?
Whats very common on cordless kettles is the contacts inside the base get badly caboned up, You can fix it by opening up the base, and cleaning the three contacts with a disposable nail fie. Then re-assemble and it should be fine. If you can get at it, the ring and the center contact in the bottom of the kettle can also be cleaned with the file.
Mar 08, 2015 | Hamilton Beach 40886 Stainless Steel...
My kettle wont start. it seems the connection from the base to the kettle is not connecting. if I hold the kettle firmly down it will start but as soon as I take weight off the kettle it stops.
The contacts inside the base are carboned up and possibly misaligned. Take the base apart and clean the contacts with a nail file, check the alignment and correct if needed. Also clean the contacts on the bottom of the kettle. If you still have the same issue, open the base and inset a small piece of cork gasket material under the three contacts so they will not drop down when you put the kettle on top of the base. Don't make the cork pieces too thick or the kettle will not sit flat.
Mar 05, 2015 | Magimix Brushed Stainless Steel Jug Kettle...
How do i clean my glass kettle from lime scale
try vinegar neat white or brown its less corrosive than the branded descalers which do work quicker i admit but my kettle started to leak
because of these strong cleaners now i use vinegar its cheap.
place 500 ml to 1 litre in kettle switch on just warm vinegar and switch off leave in for 30 minutes swilling round empty and you can keep in a bottle and repeat every month if you wish or use in cleaning solution if you don't want to waste it look on internet 1,000 ways to use vinegar.
wash kettle with copious amounts of water inside and then use kettle cleaned and sparkling
Aug 06, 2014 | Kitchen Appliances - Others
Stopped heating
A part of the problem may be from the water supply. Water with minerals builds up in the percolation area pinching off the flow. You can put a cup of water, a cup of white vinegar, and about a teaspoon of Epson salts in the kettle and try cycling it. If it gets through the cycle, dump the mixture in something temporary to save. If it short cycles, try letting it cool 15-30 minutes and cycle it again. Keep in mind this mixture will not hurt anyone, but you may want to heat a couple kettles with fresh water before making anything for your significant other. That is, if it unclogs. If it doesn't, can't hurt to let it sit an hour and try again. Chemical reaction will clear it usually eventually.
Depending on the age of your kettle and the amount of water that gets on "that" plug on the bottom from filling can take its toll on the contacts. They can usually be cleaned up, buy DO NOT HAVE IT PLUGGED IN, when this is done. The base has a spring loaded bezel with the outer contacts on the outer part of the circle. Take a couple of Popsicle sticks on opposite sides to depress the cover evenly. Look around the outer ring for copper wire contact and rub it a might with a flat point jewelers screw driver (a little bit), if it looks fonky. If not, don't bother it. On the inside in the same area there's a copper tube. Look it over. It can be rubbed on the same way with your little screw driver. If the contacts look reasonable, don't mess with'em. Don't mess with those contacts at all, if the light comes on every time you press the switch down. Good Luck.
Dec 23, 2013 | Hamilton Beach 40870 Electric Kettle
Kettle base got water .keeps blowing....how do i solve problem
For the kettle's black 'charging' base:
Unplug this charging base immediately. Let it dry out completely. If you have an air hose, contact cleaner or Electronics Duster (compressed air) to displace the water.
If you're kettle stopped working after its fully dry (wait a day to be safe), make sure it's still unplugged and check the contacts in the base center for corrosion (there's the center ground pin and if you push down on it's spring-loaded ring around the ground pin you'll find two more inner/outer circumferential contacts). If you see corrosion try to clean them with a cotton swab (like Q-Tip) and alcohol and retry.
For the kettle's stainless steel 'pitcher' base:
It's the same as above but you'll need to expose the bottom for best results and to find out where's this water it leaking from.
You'll need to remove the 3 Phillips screws and one safety-screw with a "spanner insert bit" on your driver. If you don't have access to one of those and your kettle leaks when filled then I'd bet it's cheaper to replace than to repair, sorry.
Jan 27, 2013 | Oster 5965 Electric Kettle
Hi, I have a Bosch Private Collection Kettle. It is over a year old and has until recently been working fine. However, lately I do not feel that it boils to a high enough temperature for a long enough...
Some types of kettles use a separate power base to heat up the kettle jug. If this is the case with yours, turn the jug upside down and look. Also look at the parts on the base that touch the kettle jug contacts. If you can see the electrical contacts; mine were built on spiral rings for differing temperatures; try cleaning them with Brasso and a Q-tip (cotton swab) wiping the contacts several times to remove any tarnish and then use clean swabs to remove all traces of Brasso metal cleaner. Fill the kettle jug up to the maximum fill line and put the boiler on the maximum setting... boiling water. If the water doesn't boil... you have a more serious problem. Buy a new boiler as it isn't worth having someone fix it. Mine worked like new after I cleaned the contacts. Never immerse the jug contacts in water!!!
Nov 25, 2012 | Bosch Private Collection Jug Kettle steel...
The kettle is not getting a good contact, It must be jiggled to make a conection. is there a way to correct this?
There will be a contact somewhere within the kettle which is probably sooty and will need cleaning. If you can take it apart carefully you will probably be able to locate and clean the contact. Rub it with your fingers if you can get it off...or if its stubborn, use a nail file/emery board
Jan 10, 2011 | Breville SK550XL Electric Kettle
Chefs choice electric kettle 677 works sometimes
I have the same problem and I tried to open the base to clean the contact points but found that it is molded into one piece and would have to be cut open and then glued shut when finished. I am about to pull out the file for the kettle contacts because its headed for landfill If I do nothing so I cant make it worse. I am going to file the contacts until itere a little shiny.
Nov 22, 2007 | Chef's Choice 677 Cordless Electric Kettle
Kettle keeps Turning off and on.
Try descaling the kettle for about an hour with some white vinegar without heating. Hopefully the problem is caused by limescale on the thermostat/thermocouple and this will cure it. If this doesn't seem to help then probably the thermostat/thermocouple is to blame, and although easy to replace, it seems that the best way to get the right bits is an authorised tefal dealer. This link will get you the user manual for your kettle if you need it; http://www.t-fal.ca/tefal/products/product/index.asp?univers%5Fid=400&dept%5Fid=430&sku=L00056&mscssid=JXT37R7ERWKH9P2URRA8CLM0SHMF327C Also it has the contacts for tefal customer service(Canada) if you need. Hope the descaling helps, it usually does the trick :)
Mar 21, 2007 | Tefal Elegance Brushed Chrome Cordless...
Cuisinart KUA-17 Cordless Electric Kettle Logo
2,743 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
