Question about Intermatic EI210 Electronic Auto Shutoff Timers
Ei210 in wall countdown timer in undocumented ''test mode''?
Hi
The Intermatic EI210 - bought at Home Depot. I use it to turn the fan off after 10 minutes, or 20 minutes.
This worked fine for about 6 months, but now it appears to be counting down in seconds rather than minutes. My guess is that it is in some sort of undocumented test mode.
Nothing about it in the online manual...
Anyone? Beuller?
  • kenika73 Feb 13, 2009
    I bought the Intermatic EI210 inwall timer and have a wiring question. The timer comes with 4 wires (R, B, W, G), but the junction box for the fan only has 3 wires (B, W, G) and no red. There's no separate wire from the fixture that the manual is calling to connect the red wire from the timer to. Any suggestions on which wire to match up with what? Thank you in advance!
    Dennis
    kenika73@yahoo.com
  • 44 Answers
You could try disconnecting power to the switch for a few minutes maybe that will reset it. Other than that I would say cut your losses and replace it. Hope this helps a little.
Posted on Dec 04, 2008
I have a Woods Decora time we use on our bathroom vent fan. It is preset for 5-10-15-30 minutes. It now runs for 5-10-15-30 SECONDS! How can I fix it?
There are no repairs for electronic wall timers.
Timers have 1 year warranty against defects in workmanship. This sounds like the case here.
Try timer on different circuit and see if same malfunction appears.
Woods is rated for 1/4 HP and will handle bath fan, so load does not sound like a problem.
Timer worked before, so wiring is correct.
Power outages can knock out timers when the power turns on again and timer is exposed to surge.
View countdown timers:
Electronic Leviton 6200 series and Leviton LTB series are more robust than Woods.
Mechanical rotary-type timers have no electronics, and last many years without problems.
Buy locally: GE countdown timers are sold at Home Depot. Advantage of store-bought timer is hassle-free warranty: buy new timer and return defect timer in new package.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 26, 2011 | Woods 59007 Decora Style 3015105 Minute...
I have two of these switches and they both are operating incorrectly. I use them to control bathroom fans in two separate bathrooms, but they both act the same. That is, when I push one of the time...
Leviton countdown timers have additional wire that powers internal electronics.
Leviton timers have red-black-white-green wires (or blue-black-white-green wires)
1) Regular single pole switch has 2 insulated wires. One of these wires is Hot from breaker, and the other goes to Load (fan)
2) Timer green wire connects to bare ground as you know.
3) Hot from breaker connects to timer black wire.
4) Load wire connects to timer red (or blue) wire.
5) Located in back of box are white wires that are twisted together and covered with wire nut.
These are Neutral wires. Connect timer white to these wires. This will power timer electronics.
6) If box does not have Neutral wires described above, then connect timer white to bare ground along with timer green wire.
7) Turn power ON and try timer countdown.
If timer does not work, then reverse timer red and timer black wire.
8) If box does not have neutral wires: Image on link below shows similar Intermatic timer:
Image applies ONLY when Neutral is not available.
http://waterheatertimer.org/images/EI210-wiring-full.jpg
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 25, 2011 | Leviton 6230M Decora Four Preset...
I nees 15 min. timer for my Newtone bathroom heater. I live zip code 94602 Oakland, Ca. Where to find. Thanks
You need "15 minute countdown timer" for a bath fan.
1) Following page shows selection of timer types and brands:
http://waterheatertimer.org/Countdown.html
There are push button electronic types and rotary dial types.
2) Easiest to wire is mechanical spring type countdown timer, FD series.
No electronics that can be affected by 'electric noise' on fan circuit.
Intermatic spring-wound last for years without problem.
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers.php
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers/fd15mc_w005485.php
3) Another reliable timer is GE 15088 sold at Home Depot.
Timer has preset for 20 minutes, not 15
http://www.homedepot.com/webapp/wcs/stores/
4) Amazon sells reliable 15 minute Intermatic electronic countdown:
http://www.1000bulbs.com/product/3293/ELEC-EI200LA.html?utm_source=SmartFeedAmazonProduct
5) Timex sells 15 minute spring wound countdown timer. Lower price is probably with reason since Timex are generally sold in drug store/dollar store rather than hardware/electric outlets.
http://www.amazon.com/Timex-Minute-Springwound-Countdown-Timer/dp/B00013K69Q
6) Spring wound timers connect easily to same wires that come off old fan switch.
Old switch has 2 insulated wires, connect them to either terminal on spring wound timer.
7) Electronic timers are wired differently:
Instructions for wiring electronic timers appears on following link:
http://waterheatertimer.org/GE-timers-and-manuals.html#15088
Jan 23, 2011 | Broan-NuTone Fan,Bathroom Exhaust Broan...
Our Intermatic EI200W is 1 1/2 years old and it has stopped working the way it should. It turns on the fan unit, it runs for 5 seconds and shuts off, it can be re turned on but again it only lasts for 5...
The problem could be the Load and not the timer.
I discovered that if there is a problem on the circuit, that these electronic timers can malfunction.
Buy circuit analyzer from home center, test nearby receptacle that is on same circuit.
If there is a ground fault, for example in your light-fan-motor, you have to track this down with multimeter or some other testing device.
If the circuit is clean, and your electronic device has malfunctioned, then bad news: There are no repairs for in-wall electronic devices.
I test timers: 4-6% arrive defective. Many go bad first year or two. Some last quite a while.
Some programmable timers can be reset and the timer recovers.
Intermatic page below shows countdown timers.
http://www.intermatic.com/products/timers/in-wall%20timers/electronic%20auto-off%20timers.aspx
Sample manual shows 1 year limited warranty for your product:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ei200%20-%20english.ashx
If I can make a replacement suggestion:
Manual spring-wound countdown timer lasts for 10 years because it has no electronic parts.
I have three of these and they work without a problem even on circuits that have small ground faults.
For a price, fixya expert speaks with you over phone while you work on timer, or any household problem.
Jan 05, 2011 | Intermatic EI200W Electronic Auto Shutoff...
HOW DO I CONNECT TO POWER SUPPLY? WHERE DO THE WIRES GO?
You posted under Intermatic EI210 countdown timer.
To confirm this is your product, open link below:
http://www.amazon.com/Intermatic-EI210-Electronic-Countdown-Minutes/dp/B001EE1J74
Manual with operation instructions appear on link below
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ei220w%20-%20english.ashx
EI210 replaces single-pole switch only.
Single pole switch is where 1 switch controls the Load (light, fan, motor)
To wire this timer:
1) Single-pole switch has 2 insulated wires and 1 bare ground wire.
2) Connect insulated switch wires to timer red wire and timer black wire, in either order for now.
3) Connect timer green wire to bare ground wire.
4) In back of electric box are white wire that are twisted together and covered with wire nut. Connect timer white wire to these wires. This will power electronics located inside the timer.
5) If electric box does not have white wires described above, then connect timer white wire to bare ground wire along with green wire.
6) Turn power ON. Press oval button. If indicator light turns ON, then timer is wired correctly. If indicator light does not come on, then reverse timer black wire and timer red wire.
http://waterheatertimer.org/How-to-put-on-wire-nut.html
Add a comment if you need more free help.
For a price, fixya expert gives you same instructions shown above via phone while you connect the device.
Dec 30, 2010 | Intermatic EI210 Electronic Auto Shutoff...
10 year old timer will not shut off any more
It's broken.
I have a FF series countdown timer on a water heater circuit that's been used for past 4 years.
The FF and FD series timers are heavy duty, spring-wound countdown timers.
I expect 10 years is a good lifespan.
You can buy a new spring-wound countdown timer at Home Depot or Lowes, but new ones are lighter weight than the good ol' Intermatic.
Grainger sells the FF60 (60 minute, metal cover)
http://www.grainger.com/Grainger/INTERMATIC-Spring-Wound-Timer-6X546?Pid=search
Grainger shows the FD60 (60 minute, plastic)
http://www.grainger.com/Grainger/INTERMATIC-Spring-Wound-Timer-1XC27?Pid=search
Grainger Intermatic timers shows a lot of FF and FD timer choices:
http://www.grainger.com/Grainger/intermatic/ecatalog/N-1z0r56r
There are several pages of Intermatic timers:
FF5minute thru FF12hour
FD15minute thru FD60minute
Nov 09, 2010 | Intermatic FF12HHC Energy Controls -...
How do i hook up a 4 wire timer switch (R G B W) to a three wire box(G B W)?
Generally your hook up is like this.
G - Ground - Green or bare wire
B - Hot - Black wire
W - Neutral - White wire
R - Switched - Hot when on
On your three wire
B - Hot - Black wire - hook to switch wire from switch
you should also check: http://www.intermatic.com
Jun 04, 2010 | Intermatic EI210 Electronic Auto Shutoff...
Wiring the timer
green wire=ground
black wire=hot
white wire=neutral
blue=switch
May 22, 2009 | Intermatic EI210 Electronic Auto Shutoff...
Problem with wiring diagrams for EI210
Sounds like you don't have a Neutral wire in the box, timer requires Neutral.
How to wire that timer appears on following link:
http://waterheatertimer.org/How-to-wire-timers.html
Or install a spring-wound mechanical countdown timer:
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#FF
Sep 03, 2017 | Intermatic EI210 Electronic Auto Shutoff...
Can the Intermatic El210 be set to turn things on and off?
You will need a more sophisticated timer than most hardware stores carry. Go to Smarthome.com and click their timers and automation section. There you will find many levels of sophistication in timers. good luck
Jan 25, 2009 | Intermatic EI210 Electronic Auto Shutoff...
Intermatic EI210 Electronic Auto Shutoff Timers Logo
364 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
