Question about Zenith A25A23W 25" TV
Zenith 25" Color TV - Model A25A23W
Color is overly green. Will intermittently correct itself back to a normal color temporarily, then revert to excess green condition. Color will cycle back and forth between normal color and greenish color, but remains overly green most of the time.
    President:
  • 3,130 Answers
Your problem is a bad connection on the CRT socket on the CRT driver board, a bad connection in the RGB driver supply from the video jungle IC or maybe even an intermittant Picture tube. the only way to tell would be to tap on the crt board while the sets playing with a non conductive insterment, and see if it changes. Now there is alot of HIGH VOLTAGE at this spot, so if you have no TV repoair experience Please stay safe and call in a pro to assist you. Good Luck Please dont forget to rate this thread.
Posted on Nov 12, 2006
My LG flatscreen image emits an intermittent green tint and then reverts back to normal colors.
Sep 09, 2010 | LG 42LC2D 42 in. LCD HDTV
DVD viewing shows in black and white
you have to change color system of dvd(ntsc, pal,) normally dvd remote will p/n button..press it to change color system,,otherwise u have to change color system of ur tv
Mar 15, 2010 | Zenith Z25X22S 25" TV
Can someone take a picture of the original video settings on their Zenith B25A24Z 25'' TV because my screen is all messed up and doesnt get much better when i play with settings.
If this TV is a 25"...then this is an older set. Is the picture dim and the colors dim, will the tint not correct the color scheme? Zenith picture tubes, as a rule, for this model go bad...sorry but this is true!
Dec 10, 2009 | Televison & Video
Just trying to hook up a new DVD player to my 1998 Zenith TV?
Connect your video source [cable, satellite, etc] to your dvd and connect your dvd to your tv. Get back if you still have a problem.
Jun 19, 2009 | Zenith A25A23W 25" TV
We have a 25 year old zenith console, pretty old.. but still functional.. we noticed that the tv turns blank to a green screen... no picture just green color shown on the screen, then it will go back to...
Hi and welcome to FixYa,
Initially, your described problem indicates that one of 3 color drive transistors (for the green) has developed either a cold solder (most likely) or an intermittent internal fault (leak). These transistors (or in some cases a single power pack module/IC) are normally found on a small squarish PCB (printed circuit board) at the very rear of the picture tube (CRT). At times, the green blank screen would also have diagonal fine lines or would appear to be overly bright.
In some rare instances, it could be the chroma section (least likely) or in worst case scenario the CRT (cathode ray tube) itself that is faulty (hope not).
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 18, 2009 | Televison & Video
Zenith A25A23W tv - Powers up - Black screen, no sound
You might have a bad power supply inside you TV or even a couple of dry joints. Patrick
Aug 26, 2007 | Zenith A25A23W 25" TV
Occasional discoloring, tv randomly turns from green tint to no tint
Loose connections in CTR board ( picture tube), resolder it.
Aug 05, 2007 | Insignia NS- 27" TV27 TV
Bad color .
Turn the set on without an antenna, so there is only snow on the screen. Measure the 3 cathode voltages at the CRT, red green and blue. If the 3 voltages are about the same, around 175 volts, then the CRT is bad (purple picture means bad green gun). If the red and blue are around 175 and the green is over 200 volts, then there is a chassis problem, usually the video output transistor itself has gone bad or come loose.
Oct 24, 2006 | Zenith A25A23W 25" TV
Televison & Video Logo
151 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
