Question about Microsoft Office Professional 2007 Full Version for PC
Event log service unavailable. verifie that the service is running. windows could not start the windows event log service on local computer. error4201:THE INSTANCE NAME PASSED WAS NOT RECONIZED AS VALID BY A WMI DATA PROVIDER. THX
Go find this below mentioned .Reg key in registry and export it from another Vista computer, save it somewhere and then get it ur comp and run it. Restart the comp and have fun. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Eventlog
Posted on Jun 22, 2009
  • 76 Answers
In dg41wv server 2003 is not loading
problems in Windows Server 2003
To start the computer by using Last Known Good Configuration, follow these steps:
Click Start, and then click Shut Down.
Click Restart, and then click OK.
When you see the message Please select the operating system to start, press the F8 key.
Use the arrow keys to select Last Known Good Configuration, and then press Enter.
Collapse this imageExpand this image
Note NUM LOCK must be off before the arrow keys on the numeric keypad will function.
If you are running other operating systems on the computer, click Microsoft Windows Server 2003 on the list, and then press Enter.
Notes
By selecting Last Known Good Configuration, you can recover from problems such as a newly added driver that may be incorrect for your hardware.
This feature does not solve problems caused by corrupted or missing drivers or files.
When you select Last Known Good Configuration, only the information in the following registry key is restored:
HKLM\System\CurrentControlSet
Any changes that you have made in other registry keys remain.
If you can start your computer by using the Last Known Good Configuration feature, the last change that you made to the computer (for example, the installation of a driver) may be the cause of the incorrect startup behavior.
if this fails to fix the problem try to repair in safe mode
How to start the computer in safe mode
When you start the computer in safe mode, Windows loads only the drivers and computer services that you need.
You can use safe mode when you have to identify and resolve problems that are caused by faulty drivers, programs, or services that start automatically.
If the computer starts successfully in safe mode but it does not start in normal mode, the computer may have a conflict with the hardware settings or the resources. There may be incompatibilities with programs, services, or drivers, or there may be registry damage. In safe mode, you can disable or remove a program, service, or device driver that may prevent the computer from starting correctly.
To troubleshoot startup problems in safe mode, follow these steps:
When you see the message Please select the operating system to start, press F8.
On the Windows Advanced Option Menu, use the arrow keys to select Safe Mode, and then press Enter.
Note Num Lock must be off before the arrow keys on the numeric keypad will function.
Do one of the following:
If the computer does not start in safe mode, try starting the computer by using the Recovery Console. If you still cannot start the computer, look for possible hardware problems, such as defective devices, installation problems, cabling problems, or connector problems. Remove any hardware that was added recently, and then restart the computer to see if the problem is resolved.
If the computer starts in safe mode, go to the next section to continue to troubleshoot the startup issue.
Use Event Viewer to identify the cause of the startup problem
View the event logs in Event Viewer for information that can help you identify and diagnose the cause of the startup problem.
To view events that are recorded in the event logs, follow these steps
Click Start, point to Administrative Tools, and then click Event Viewer.
Start the Event Viewer snap-in in Microsoft Management Console (MMC).
In the console tree, expand Event Viewer, and then click the log that you want to view. For example, click System log or Application log.
In the details pane, double-click the event that you want to view.
To copy the details of the event, click Copy, open a new document in the program in which you want to paste the event (for example, Microsoft Word), and then click Paste on the Edit menu.
To view the description of the previous event or the next event, press the UP ARROW key or the DOWN ARROW key.
Use this tool to help identify possible problem devices and device conflicts.
To do this, follow these steps.
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
you might be able work your way through the problem
hope this helps
Sep 01, 2012 | INTEL - MOTHERBOARDS Dg41wv Uatx Intel Gma...
Tip
Services You Can Disable
There are quite a few services you can disable from starting automatically.
This would be to speed up your boot time and free resources.
They are only suggestions so I suggestion you read the description of each one when you run Services
and that you turn them off one at a time.
Some possibilities are:
  • Alerter - Sends alert messages to specified users that are connected to the server computer.
  • Application Management - Allows software to tap directly into the Add/Remove Programs feature via the Windows Installer technology.
  • Background Intelligent Transfer Service - The Background Intelligent Transfer service is used by programs (such as Windows AutoUpdate) to download files by using spare bandwidth.
  • Clipbook - ClipBook permits you to cut and paste text and graphics over the network.
  • Error Reporting Service - Allows applications to send error reports to Microsoft in the event of an application fault.
  • Fast User Switching - Windows XP allows users to switch quickly between accounts, without requiring them to log off.
  • Help and Support - Allows the XP Built-in Help and Support Center to run.
  • IMAPI CD-Burning COM Service - You don't need this if you have other software to create CDs.
  • Indexing Service - Indexes contents and properties of files on local and remote computers; provides rapid access to files through flexible querying language.
  • IP SEC - Manages IP security policy and starts the ISAKMP/Oakley (IKE) and the IP security driver. If you are not on a domain, you likely don't need this running.
  • Messenger - Transmits net send and Alerter service messages between clients and servers. This is how a lot of pop-up windows start appearing on your desktop.
  • Net Logon - Supports pass-through authentication of account logon events for computers in a domain. If you are not on a domain, you don't need this running
  • Network DDE - Provides network transport and security for Dynamic Data Exchange (DDE) for programs running on the same computer or on different computers.
  • NT LM Security Support Provider - Provides security to remote procedure call (RPC) programs that use transports other than named pipes.
  • Performance Logs and Alerts - Collects performance data from local or remote computers based on preconfigured schedule parameters, then writes the data to a log or triggers an alert. If you don't need to monitor your performance logs, then you don't need this service.
  • Portable Media Serial Number - Retrieves the serial number of any portable music player connected to your computer
  • QOS RSVP - Provides network signaling and local traffic control setup functionality for QoS-aware programs and control applets.
  • Remote Desktop Help Session Manager - Manages and controls Remote Assistance. If you are not using Remote Desktop you don't need this service.
  • Remote Registry - Enables remote users to modify registry settings on this computer.
  • Routing & Remote Access - Offers routing services to businesses in local area and wide area network environments. Allows dial-in access.
  • Secondary Login - Enables starting processes under alternate credentials. This is what allows you to run an application as another user.
  • Smart Card - Manages access to smart cards read by this computer.
  • Smart Card Helper - Enables support for legacy non-plug and play smart-card readers used by this computer.
  • SSDP Discovery Service - Enables discovery of UPnP devices on your home network.
  • TCP/IP NetBIOS Helper - Enables support for NetBIOS over TCP/IP (NetBT) service and NetBIOS name resolution. This should not be needed in today's network environment.
  • Telnet - Enables a remote user to log on to this computer and run programs, and supports various TCP/IP Telnet clients.
  • Uninterruptible Power Supply Service - Manages an uninterruptible power supply (UPS) connected to the computer.
  • Universal Plug and Play Device Host - Provides support to host Universal Plug and Play devices
  • Upload Manager - Manages synchronous and asynchronous file transfers between clients and servers on the network.
  • Volume Shadow Copy Service - Manages and implements Volume Shadow Copies used for backup and other purposes.
  • Web Client - Enables Windows-based programs to create, access, and modify non-local files across the Internet.
  • Wireless Zero Configuration - Provides automatic configuration for the 802.11 adapters
  • WMI Performance Adapter - Provides performance library information from WMI HiPerf providers.
on Sep 20, 2010 | Computers & Internet
Remove error106
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or
NTFS Partition
1. Click the Start button, point to Settings, click Control Panel, and then double-click Services.
2. Select the Event Log service and click Start up. Change the Start up Type to Disabled, and then click OK. If you are unable to log on to the computer but can access the registry remotely, you can change the Start up value in the following registry key to 0x4:
3. Restart Windows.
NOTE: When the system starts up, several services may fail; a message informing the user to use Event Viewer to review errors may appear.
4. Rename or move the corrupt *.evt file from the following location:
%SystemRoot%\System32\Config
5. In Control Panel Services tool, re-enable the Event Log service by setting it back to the default of Automatic start up, or change the registry Start up value back to 0x2.
FAT partition (Alternative method)
1. Boot to a MS-DOS prompt using a DOS bootable disk.
2. Rename or move the corrupt *.evt file from the following location:
3. Remove the disk and restart Windows.
When Windows is restarted, the Event Log file will be recreated.
hope this helps
Jul 03, 2012 | Computers & Internet
Main OS does not mount
Boot in safe mode
Start msconfig.exe and configure windows to start with a clean boot.
a. Log on to the computer by using an account that has administrator rights.
b. Click Start, type msconfig.exe in the Start Search box, and then press ENTER to start the System Configuration Utility.
If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
c. On the General tab, click Selective Startup, and then click to clear the Load startup items check box. (The Use Original Boot.ini check box is unavailable.)
d. On the Services tab, click to select the Hide all Microsoft services check box, and then click Disable all.
Note Following this step lets Microsoft services continue to run. These services include Networking, Plug and Play, Event Logging, Error Reporting, and other services. If you disable these services, you may permanently delete all restore points. Do not do this if you want to use the System Restore utility together with existing restore points.
e. Click OK, and then click Restart.
Boot the machine in normal mode.
Nov 11, 2011 | Compaq Hewlett Packard Presario SR5110NX ...
I have a excella stx check scanner which I connected to a machine running windows 7 32 bit, when running the demo program the first time everything works as it should, if I close the demo and reopen I can...
click start control panel in the top right hand corner type in event viewer press enter
a window will open with a local event viewer at the top of lists logs custom views windows logs applications and service logs and subscriptions select the local event viewer you should see your error in log summary right click on it select properties this might tell you what the problem is and allow you work through your way through it (note i have not had an issue with my windows 7 ) this is only a guide for your assistance not a cure !
you might have to select other logs to find the error
hope this helps you
Aug 18, 2011 | Magtek Excella STX Check Reader PN...
Hi,Sir, I am using the Sony Vaio Laptop, VPCEB46FG Model and its fn(Hot keys driver is missing).Please send me the link for the same. I was not able to find it on sony e-support. Kindly help out for the...
  • you can verify if the Sony Vaio Event Service has been started (by ctrl+alt+del, then Processes)
  • Install keyboard driver (http://www.sony.co.in/support/product/vpceb46fg, then Downloads, etc )
Jul 05, 2011 | Sony VAIO E Series VPCEB36GX/BJ Notebook
Network issue
Hello
This is an unusual error. Error Code 1236 - The network connection was aborted by the local system.
There is no single issue that causes this error code, so we need to verify all of the networking basics are covered and working.
1. Verify the IP address, Subnet Mask and Default Gateway are fully entered and / or populated by the DHCP server. Click START, then RUN, type in CMD then click the OK button. Type IPCONFIG /ALL - verify the three fields all have valid info for your network.
2. Verify you can see the local network - including other computers and network devices. This will rule out the possibliity that this computer cannot see any network devices and not just the shared folders
3. Log the user out and have another user that can access the shared folders log into this comptuer and try to access the shares. The user profile could be corrupted and preventing the user from accessing the shared folders. IF the new user cannot access the shared folders, then it is the PC / OS causing the issue. IF they can access the shared folders, backup the original user's data, delete their profile and have them log in again to create a new profile.
It is always recommended to upgrade Windows XP to Service Pack 3 - unless you have a very specific program that will not run on SP3.
May 04, 2010 | Microsoft Windows XP Professional SP2
Asus 5pe-hdmi mb = Q6300 Dual Core - 450W PSU
try checking out in safe mode.does it reboots in that also.
Mar 23, 2009 | ASUS P5PE-VM Motherboard
Windows event log service wont start, error code 5
Your right its not a virus, and its not because your running one of the top anti- virus software,the problem is else where.
Have you checked the log files to see if you have permission?????
Have you checked event viewer to see if you have permission????
I need to know or the fix I have for you will not work.
Mar 13, 2009 | Dell Inspiron 530 Desktop Computer
Security centre
NOTE: All indications re information to be typed are indicated in bold, so you can recognize what needs to be typed, and system titles or choices are in italics.
Most likely the service is not running. The first part here (1) is to make sure it is running, and if not, to start it. Secondly, the security service is dependent on several other services that have to be running (first) to allow the security service to run. So those will only need to be checked if the first step doesn't solve the problem (2).
Restart your computer to make sure there is nothing loaded in memory or taking action that is not known.
(1) Go to Start > Run -- type in services.msc > OK.
- Scroll down to Security Center and you will likely see that it is not listed as Started under Status, and is either Manual or Disabled under Startup Type. [If it shows Started, skip down to section (2) of these instructions.]
- Double click Security Center - in the Startup type box, select Automatic > Apply ; under Service status, click Start button , OK, Close Services window.
You should now be able to open the Security Center and set the parameters as you desire. (Control Panel > Security Center)
(2) This should only be necessary for supporting services to allow Security Services to run. They should already be running, so these instructions are more brief, and follow the same basic format as the information presented in section (1). In other words, if changes are necessary, they should be done in the same way as previously set forth.
- Make sure that these services are set to Automatic and started:
= Remote Procedure Call (RPC) - be sure to select RPC and NOT RPC Locator - it is OK that RPC Locator is not started and may show as Manual.
= Event Log - not much is really dependent on this to run, but it will be needed if there is a further problem to diagnose.
= Windows Management Instrumentation (WMI) - depends on RPC & the event log services to be running for this to run.
Now, again double-check the Security Center listing, make sure it is started and automatic. Close the Services window.
You should be set and ready to go now. Open the Security Center and set things the way you want them to be. If there is a further issue, we will need to explore the contents of the Event Log via the Event Viewer, but hopefully you won't need to do anything aside from what has been listed above for you.
Please post back if you need further assistance, or feel free to select Ask Me from the Expert listing, as I will be able to help you go through any related events if necessary. I have read of many cases where users have uninstalled and reinstalled SP2, often at the instruction of manufacturer techs, but this really should not be necessary unless there is some other overwhelming problem with the machine. Thank you for using and rating FixYa!
smartsolve
May 29, 2008 | Computers & Internet
Microsoft Office Professional 2007 Full Version for PC Logo
1,309 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
