Question about HTC Touch Cell Phone (Unlocked) - Soft Black
HTC Touch - Screen & touch flo problem
Hi..i have a problem with my touchflo screen...i have to keep aligning my screen everytime i have to use it ....the stylus wont respond accurately....as it clicks the wrong place when i try to click sumthing ....for example ...if i try to click 'L' ...the 'K' gets clicked ...also ...the respond of the touch screen is very hard.....and not sensitive enough...pls help ....
  • 2 more comments
  • Anonymous Nov 13, 2008
    i did all things described to get the screen workin,pressed the red n green buttons simultaneously n with the friggin stylus i pressed the reset button underneath, pulled the battery out a coupla million timesn put it in, but it jus doesnt unlock, the touchscreen aint workin, i can call, mssag or do anything except recieve calls, donovan
  • ravinhetty Mar 26, 2009
    I have the same Problem which you have
  • Anonymous Apr 04, 2009
    I have the same problem, although it is possible to allign the screen again, it still switches automatically after a while.
  • Anonymous Apr 15, 2009
    same here
I did all things described to get the screen workin,pressed the red n green buttons simultaneously n with the friggin stylus i pressed the reset button underneath, pulled the battery out a coupla million timesn put it in, but it jus doesnt unlock, the touchscreen aint workin, i can call, mssag or do anything except recieve calls, Arpan
Posted on Sep 01, 2010
I forgot my HTC touch flo password and I can't
do a factory reset on your phone,
vol button down + OK button ( center ) + power button
hold them all at the same time and use stylus to reset your phone on the bottom
tricky but works just fine
you have to keep holding them until u see the msg on the screen
Jan 26, 2013 | Cell Phones
I am using HTC Touch P3452 model.The main screen always shows "Tap here to Launch TouchFLO" but never launches TouchFLO. I have tried a reboot and also taken out battery before rebooting but no...
My HTC HD2 had the same trouble. Runmunng windows would work ok.
The solution for me was to reset the phone to original specs.
The downside is you have to re-laod all your stuff. Make sure it's backed up before you start if you do re-set the phone to factory specs.
Al
Feb 11, 2011 | HTC Touch P3452 Smartphone
Touch Pro2 won't go past the htc load up screen
Make sure your TouchFlo app is turned on. Goto Start, settings, Personal TAB, Today icon, Items Tab. Scroll down the list of items and check the TouchFlo 3D item then click OK.
Apr 14, 2010 | HTC Touch Pro Smartphone
TOUCHFLO IS NOT LAUNCHING. AFTER CHARGING, I JUST SAW ON THE SCREEN "TAP HERE TO LAUNCH TOUCHFLO" AFTER TAPPING, IT SAYS "LAUNCHING TOUCHFLO" BUT IT DOESN'T PROCEED. INSTEAD, IT GOES BACK TO "TAP HERE TO...
This can be an indication of a Out-Dated Firmware. In this matter, you need to download the Software Updater tool from the Official HTC Website. If not available, take it to a Service Center of HTC and tell then to install the upgraded version.
Thank you Sir, Have a nice day.
Oct 16, 2009 | HTC Touchâ„¢ 3G Cell Phone
Touchflo of HTC Touch 3G won't launch
Hi. TouchFlo is the special today plugin for the HTC devices, and as you realized, you can still use all functions of your PDA without. I think there is an error in the installation of TouchFlo (There can be a bunch of reasons, we have to know everything you did with your PDA in order to guess them), but there is a safe solution for that problem, you can backup all your personal data and software to your PC, then you can hard reset your PDA to its factory default settings. That way both your phone and the TouchFlo will work. In order to hard reset your PDA (after the backup of your personal data), you can follow the steps in this link: (http://www.hardreset.eu/htc_touch_diamond_hard_reset_soft_reset_en.html). Hope this helps.
May 27, 2009 | HTC Touch Diamond Smartphone
I am using htc tytn-2 kaiser window 6.1 version.I just want to know that how we can activate the touch flo technology in this device so that the pictures can be changed with just the flick of a finger on...
i dont think that touchflo is available for this device it is for HTC Touch GSM phone but u can get it on some forums it is called Manila 2D please check u can also get Custom Roms for ur device on this Forum
http://forum.xda-developers.com/
Pls rate me Fixya for help
Mar 25, 2009 | HTC TyTN II Smartphone
HTC touch flo cube
Just try colly from exact bottom center and push your finger very normally....even it took me about 3-4 days to get it right
Feb 08, 2009 | HTC Touch P3452 Smartphone
Touchflo does not appear to be working on new Touch diamond
TouchFlo is an application that needs to run on top of Windows. It is quite well hidden in the menus....
To start with, I assume you get the normal Windows Mobile 'Today' screen? If not, you have bigger problems!
If so, hit "Start" --> Settings
Then on the 'Personal' tab, go to 'Today'
Then look at the 'Items' tab and make sure that TouchFLO 3D is the only checked item.
Hit 'OK' top right, then 'X' top right and you should get back to find it activated.
@deepak - TouchFLO 3D is standard on the HTC Diamond. If you have TouchFLO then I guess you have a HTC Touch (different phone).
Dec 02, 2008 | HTC Touch Diamond Smartphone
HTC Touch Cell Phone (Unlocked) - Soft Black Logo
1,410 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
