Question about Zenith P42W46X 42 in. Plasma EDTV
Philips TV will not tune
I have a Philips 42PF5520 and have restored to factory settings, when i go through the set up menu and go to service scan the auto store freezes on 44mhz, can anyone help me?
  • Anonymous Mar 22, 2014
    I hit menu and get mode backlight contrast advanced settings
  • 38 Answers
Yes its SSB board is faulty, Replace complete Board or just replace is EEPROM
Posted on Nov 12, 2008
Cod resoftare nokia 7100s2
Restore to factory settings
To restore the phone back to factory conditions, select Menu > Settings > Rest. factory sett. and from the following options:
Restore settings only -0 to reset all preference settings without deleting any personal data
Restore all - to reset all preference settings and delete all personal data, such as contacts, messages, media files and activation keys
Apr 17, 2014 | Philips Televison & Video
For a Panasonic CT-30WX54J: What's the button sequence to do a factory restore of the settings in the 'Service Menu'.
Press and hold Power & Chnnel button on the front panel of the TV, and plug it to AC power. The set must come on with service mode screen. The procedure will differ set to set. If you wish to get some details, check the site linked here.Pull up older posts.
Dec 07, 2013 | Televison & Video
Reset printer
On your printer, go to the settings menu -> factory defaults.
Do not restore - this is the factory default setting. Do not restore keeps the user defined settings.
Restore - returns all printer settings to the factory default settings except the Network/Ports menu settings. All downloads stored in RAM are deleted.
Jun 04, 2012 | Lexmark X204n Multifunction Printer,...
No control buttons on Philips 234CL (lit but not possible to turn off)
Philips 234CL
Go to:
Control Panel
Hardware and Sound
Devices and Printers
Select >> Philips 234CL
Select >> Display Settings
Select >> Advanced Settings
Select >> Graphics and Media Control Panel
Select >> Graphics Properties
Select >> Monitor/TV Settings
Select >> Restore Factory Defaults
May 17, 2012 | Philips Computers & Internet
Need to tune in Philips Tv 14pv284/05 lost manual
If you're trying to scan for channels, this option should be found in your menu. I am not sure what your menu looks like, but usually there is a "Channels" setting in your menu. You can then select "Start Scan" or "Scan for Channels." You might also look for anywhere that says "Initial Setup" or somewhere in the menu that says "Add/Remove Channel." For some reason, Philips does not allow you to look this model up on their website. If you can't figure out the menu you should try calling Philips customer support.
LCD Television (2008 and newer)
1-866-771-4018
Televisions (purchased before 2008)
1-866-310-0787
May 01, 2011 | Televison & Video
My PHILIPS 34PT9420 tunes only fifty channels and not more than that.Earlier it use to tune 99 channels.So kindly tell me how to tune all 99 channels or how i may have changed some of its factory settings...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Aug 23, 2017 | Philips 34PW8502 34" TV
Factory reset was reset---now we have a no signal on the screen
Please go to tuning menu and select Auto Scan/ Auto Tuning to tune all available channels to store in tv memory.
Factory reset actually delete all data/ settings in memory chip and set tv as it was in-box.
Thanks.
Jun 13, 2010 | Olevia 237T 37 in. LCD TV
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Unclear picture, tv won't change from 480i to 1080p
Try restoring factory settings, most Panasonic TV's have an R-Tune button which means if you enter a menu and press R-Tune it should restore all settings. If the TV cane on 1090p then it should change....
That was a blind guess so I mean sorry if it doesn't work.
Dec 28, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Digital tuning
You'll need to go into service mode and do a factory reset.
To enter service mode you'll need to press these buttons on your remote in the following order:-
Standby-info-menu-mute-standby.You'll need to do it fairly quickly and be patient it doesn't always go into it first time,don't press and hold the buttons.
The service menu should appear on the screen.Use the up /down cursor to scan down to option number 12 (factory reset)and then press the right cursor wait will appear on the screen and the set will go to standby(don't worry this is normal)
Reboot the set and retune and all should be well
Oct 16, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Zenith P42W46X 42 in. Plasma EDTV Logo
95 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
