Question about RCA D52W19 52" Rear Projection Television
My rca rear projection tv wont turn on
A day after a power surge i turned on my tv pic came on followed by a clicking noise sounded like a relay i walked out of the room and returned to no pic and just the clicking sound i unplugged for 24 hours tried turning it on and nothing not even the clicking sound green light doesnt come on either what do i do
    Genius:
  • 2,920 Answers
It probably blew the power transformer
Posted on Nov 15, 2008
Tv won't turn on makes clicking noise
that click is the power relay, but i have seen several diferent ways this can happen, is it clicking so fast it kinda resembles a buzz noise or do you just hear one loud click when you turn it on? email me maxtek73@yahoo.com.
Sep 08, 2013 | RCA P52960 52" Rear Projection Television
No Picture/No Sound
This is very possibly a power surge, can you tell me how many times the light blinks, you probably have a bad power board now if you had a power surge.
Aug 11, 2007 | RCA HD52W59 HDTV Projection Television
I have a JVC AV-65WP74, I went to bed watching the TV then turned it off for the night but the next day when I turned it back on the blue light came on on the TV but no picture, the TV makes a fast...
The clicking you hear is probably caused by a relay that controls the incoming AC to the main power supply. This is a protective reaction to a problem in the power supply itself or an overload due to a failure downstream from the supply. This is not a likely DIY repair. You will probably need a technician to determine which of these two likely problems it is.
May 19, 2011 | JVC AV-65WP74 Rear Projection Television
Hi the tv just wont turn on...
most likely its your J2 noise reducer. it filters out the static in the electrical line to convert or power to a resonable voltage to use. however when the go bad the tv filters in to much power thus casing a power surge blowing a internal circuit so u have two options a go to a local repair shop and get them to fix it or throw away cause u will spend more fixing it than what is truly worth sorry.
Feb 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" rear projection tv has no power and fuse is ok
The clicking noise that you are hearing is actually the power relay. Normal operation by either the remote or the power button on the front panel, you would normally hear a soft click just after the press of the power buttons to turn the unit on or off. When you initially plug the unit in to power, you will hear the same click noise. Being that you are hearing it all the time indicates a failed relay. TV's now a days, or at least ones built during the last 15 - 20 years have different Printed Circuit Boards (PCB). There are PCB's for power (which youre dealing with now), sound,video and so on. The PCB that you need to repair your clicking issue will run you about 80 U.S. dollars for the part plus the average going rate for repair from a qualified service tech. You could purchase the part from Thompson Consumer Products repair and fix it yourself, but be aware, there will be no warranty on the part itself unless an authorized tech does the work. Located on this PCB is the power on/off relay, fuse, usually 4-5 connectors for power to different PCB's (depending on model and features). Now depending on how old the TV actually is, you may want to invest in a newr set, the reason why I say that is, is because the new power unit may and can overload the other boards and cause damage to them and now you have a new problem to deal with( along with more money being tossed down a hole.
Good luck
Sep 19, 2009 | RCA P52926 52" Rear Projection Television
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
During a power surge my tv turned off and it wont turn on now at all
i have a rca television and my t.v. just cut off when i was looking at it and , when i tried to cut it back on, there was no sound and no picture and the power button did not want to cut off on it's on i had to unplug it.
May 12, 2009 | Mitsubishi WS-55805 55" Rear Projection...
RCA HDTV DLP Rear Projection TV wont turn on
RCA Projection tvs are trash,should be off the market.
Mar 29, 2009 | RCA Scenium D40W20 40" Rear Projection...
Tv wont turn on p52960
Still sounds like the flyback. Rca has had issues throught the years with flybacks failing especially that model.
May 12, 2008 | RCA P52926 52" Rear Projection Television
Television malfunction
If you know how to solder - solder around Flyback transfomer,if not you need to order a deflection power supply board.this is where your problem is.ThankYou for using FixYa. Have a Nice Day.
Feb 10, 2008 | RCA HD52W59 HDTV Projection Television
RCA D52W19 52" Rear Projection Television Logo
174 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
