It has been locked by my frnds ,,,,,,,,thy had attempted too many times too open the phone,,,,,,,,,,,,,,,thn it comes to give ur google account to open it/////////i hve entered it.....it doesnt take.................wat to do?????????????help me
Http://img338.imageshack.us/img338/1613/a60d.jpg
SOURCE: i attempted my unlock pattern to many time now my phone is locked
you will have to do a master reset....you will loose everything on the phone....it is important that you create a google profile, which will back up all your contacts....
if this doesnt work is because your phone doesnt have the harware keys firmware update... need to take it to a repair center and have do a software reflash
SOURCE: locked out by too many
1. On the computer: Start PC Companion™.
2. On thecomputer: In the Support Zone™ descriptor, in the Software Updatesection click Start > (Repair) and follow the instructions on the PCmonitor screen.
3. Turn off the phone.
4. Connect the USB cable to your computer.
5. On the phone: Press and hold down Back key and connect the USB cable to the phone.
6. Follow the instructions on the screen.
Note : The software in your phone will be replaced. All personal data stored in your phone will be lost.
There is also a way to unlock the pattern screen lock by signing in with your Google account.
1. After 30 seconds, tap Forgot pattern?
2. You need to log in with the primary gmail.com e-mail address and not the alternative email address connected to the Google account.
3. Tap the username field and enter the primary Google account user name.
4. Tap the password field and enter the primary Google account password.
5. Draw a new unlock pattern and tap Continue .
6. Draw the new unlock pattern again and tap Continue .
If these options are not available to you, please describe preciselywhat you see when attempting to connect to your PC and use PCCompanion.
SOURCE: i have a samsung galaxy
The way around this is to factory reset the phone.
1. switch off. Hold volume UP and power button and home button
simultaneously. release home button (and press again) while still
holding volume up and power button. A boot up screen will pop up. Use
volume keys to select (reset and restore) press home button to select.
2.Once reset and the phone starts up again it will still show locked.
Get another phone to call your phone. as soon as you swipe answer press
back key (arrow key) (you gotta be quick) and the main home screen will
come up . press the left menu button and select settings and turn
off pattern code then go to menu and factory reset the phone again.
Hope this helps.
SOURCE: too many pattern attempts
there's an actual android bug here as well, even if you haven't forgotten your credentials. see comment 93 or 127 in http://code.google.com/p/android/issues/detail?id=3006
SOURCE: Hi, I have got a Sony
To unlock the pattern screen lock without signing in with your Google account You need to repair the software of the phone.
The steps to repair the phone are the following:
