Question about Philips HD4651 Electric Kettle
Philips Kettle Can I purchase a replacement base for the Philips HD4651 anywhere? I love my kettle however it was resting on a rear burner that was turned on accidentally and the base melted. Do I have to buy an entire new kettle?
4 Suggested Answers
SOURCE: How to descale Philips HD 4651/C Electric Water Kettle
Not having received any solution message from FIXYA contributors, I consulted with a family member
and also my long held Time-Life Books, Fix It Yourself Library, Volume: Cleaning & Stain Removal,
ISBN: 0-8094-7400-X, Copyright 1990. My issue was resolved by using white vinegar and soaking the internal problem area for 30 minutes. The appliance has cleaned up like new and works fantastic. I apologize for bothering you.
Posted on Nov 28, 2008
SOURCE: I need a replacement seal for a Philips kettle HD4681
what is the solution for electronic harmonics & producing power
Posted on Jan 02, 2010
EwingElect
  • 276 Answers
SOURCE: need new base
Try http://www.support.philips.com/support/service/onlineStore.jsp?userCountry=us&userLanguage=en
At the top corner you can choose your country, and hopefully you'll be able to locate a local Service Center
Posted on May 19, 2010
I have a model RK 17 Cordless electric jug kettle from cuisinart that I just love because of the old fashioned design. I need a new base because a mouse decided to chew the cord and was incinerated.
i HAVE THE BASE IT WORKED FINE, MY DAUGHTER COOKED THE KETTLE WHEN SHE TRIED TO HEAT IT ON THE ELEMENT, now I need to find a new kettle! ONSCHMITT@SHAW.CA
Jul 18, 2012 | Cuisinart RK-17 Cordless Electric Kettle
There seems to be a loose connection between base and bottom of kettle . At first I could press down on the pot and it would start heating . Now I can
If it uses a detachable base to the kettle tank with electrical contacts, sometimes the base or kettle connector must be replaced. You will need the proper tools and wire connectors to be able to replace these parts.
Technically speaking... These are not worth servicing.
Jerry G.
Jun 21, 2012 | Philips HD4651 Electric Kettle
My Phillips kettle does not boil water but the light turns pOn. It is electric
Very simply, it sounds like the element has blown. If the element is built into the base of the kettle I am afraid it is terminal, if it is a calrod type element that you can see in the kettle, it can be replaced.
Jan 21, 2011 | Philips Kitchen Appliances - Others
Cordless Electric Kettle won't turn on anymore.
Sounds like dirty contacts in the base.
UNPLUG THE BASE BEFORE CONTINUING ANY FURTHER!!!! I CANNOT STRESS THIS ENOUGH!!!
Once Base is definitely unplugged, take it outside and use a piece of fine grit sandpaper inserted in the contacts to give it a good rub all around. Also polish the contacts on the base of the kettle.
Blow the contacts out to make sure there's no grit remaining, and then plug in and test again. You might need to do this a couple of times.
However, make sure it is UNPLUGGED before you touch any contacts!
May 15, 2010 | Kitchen Appliances - Others
Need new base
May 16, 2010 | Philips HD4671 Electric Kettle
Jan 01, 2010 | Philips Kitchen Appliances - Others
Nov 27, 2008 | Philips HD4651 Electric Kettle
HD 4651/C Electric Kettle Handle switch lights but wont heat
This maybe the thermo fuse, and or the heating element that is defective. These parts must be properly replaced for safety issues.
Usually these appliances are not worth to service.
Jerry G.
Apr 07, 2008 | Kitchen Appliances - Others
Philips HD4651 Electric Kettle Logo
77 people viewed this question
Top Philips Kitchen Appliances - Others Experts
Dennis Maeder
Thomas Perkins
Thomas Perkins
Robert Kilpin
Robert Kilpin
Are you a Philips Kitchen Appliances - Other Expert? Answer questions, earn points and help others
