Question about Cameras
HP Camera R727 When switched on the screen shows 'Camera has experienced a problem' 00018-4489-957-000 Pleaee reset your camera. It then switches itself off immediately
  • robin1smith Nov 12, 2008
    I tried the suggestion but it has not worked
  • robin1smith Nov 13, 2008
    Advance Camera say they cannot get spares for HP Cameras
    Brigadier General:
  • 6,966 Answers
It would seem that this indicates a hardware error. A few suggestions you can try:
  • clean/scrape the battery terminals. you may even need to bend/stretch them a bit to ensure more pressure/positive contact with the battery;
  • the unit maybe need to be jarred. A common solution to similar products and not only with HP models. Pls see this post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 13, 2008
  • Louie  Role
    Louie Role Nov 15, 2008
    Hi again,
    Any development(s) so far?
    Champion:
  • 225 Answers
Most camera error messages are for lens jams. Most likely, you will need to replace your camera lens, or find the grain of sand that is stuck in a gear somewhere in the lens mechanism.
    Genius:
  • 1,269 Answers
Turn off camera. Try to remove the battery for 5-10 minutes. Make sure your battery is fully charged. You can try different battery as well. Try to turn on the camera without memory card.
  • 81 Answers
Does it let you go to your menu?
And if it does then go to menu reset enter password (if need one) and click yes but it will delete everything on your camera....or Take the battery out of the camera for 5 minutes. Reinstall the battery & it should have reinitialized.
else you can go to a repair shop and ask them to reset it for you..
Posted on Nov 12, 2008
  • Faraz Zama Nov 12, 2008
    Check this out
    http://www.fixya.com/support/t257543-hp_...
  • 13,433 Answers
The problem you posted doesn't come up with anything.
If you are out of warranty I suggest you contact 3rd party repair company for repairs.
you can get a free repair estimate from advance camera http://www.advancecamera.com/repair
    Genius:
  • 1,913 Answers
Press power botton for 10 secionds.
then it shut down.
rthen put away memoryt card and start your camera.
then again shut down.
thehnn put memory card then try.
How do you reset an HP R727 camera?It comes up saying it has experienced an error 5555AAAA-61EE-14B-031 as soon as you switch it in. Battery is fully charged.
Normaly the repair service reset camera by using special file on the SD card.This file is impossible to find it on the internet.But you can try to update FW maybe it will help to this error message.You can try download lates FW for R727 from google.(Last FW version is 3.02.15).
Then extract exe file and copy FW file to the SD card.Put SD card into the camera and close battery door.Hold Shutter button and power on camera.After FW update is complete just power off camera.Then try it again to swith on.If it will not help the only way is send camera into the repair service.
Best Regards
AIOS
Apr 17, 2010 | HP Photosmart R727 Digital Camera
Photosmart R727.Camera has experienced an error 000000018-4489-957-000 please reset your camera I don't know how to reset the camera. help!
Two ways: 1. Go into the menu and find "reset"...follow the on-screen instructions. 2..Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Jan 30, 2010 | HP Photosmart R727 Digital Camera
How reset this camera
Dec 02, 2009 | HP Photosmart R727 Digital Camera
Hp photosmart R727 reset problem
The reset button is located next to the battery release tap. Here is a picture (sorry for the lousy quality, it was taken with a ten dollar web cam.)4f16c6c.jpg
Mar 28, 2009 | HP Photosmart R727 Digital Camera
How to reset hp photosmart R727?? pks help me
TENGO UNA CAMARA DIGITAL HP R727 ESTABA FUNCIONANDO NORMALMENTE CUANDO DEPRONTO ME APARECE QUE HAY UN ERROR NO SE ALCANZA A VISUALIZAR EL NUEMRO DEL ERROR PUES SE APAGA MUY RAPIDAMENTE PERO DE TANTO HACERLE VI QUE DECIA REINICIAR LA CAMARA PERO NOSE COMO HACERLO, POR FAVOR DIGANME COMO SE REINICIA.
GRACIAS.
ATTE. XIMENA CASTRO
Feb 23, 2009 | HP Photosmart R727 Digital Camera
HP R727 stays on 2 seconds then flashes contact HP
Try holding in the reset button longer then the recommended 6 seconds.
I've fixed many of these Photosmart series this way.
Dagra
Dec 20, 2007 | HP Photosmart R727 Digital Camera
Please help!!
Try a safety pin in the reset hole by the battery compartment most paper clips seem to be much to big. Also hold the reset for at least 3 seconds. The first time I tried I just pushed it down quickly and it did not reset. I just fixed my mom's camera with the exact same error. So safety pin and hold 3 seconds. For a diagram of the reset hole see web site1.gif mentioned in jimg's suggestion
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00743921&lc=en&cc=us&dlc=en&product=1154651
Hope this helps
Dec 20, 2007 | HP Photosmart R725 Digital Camera
HP Photosmart R725 camera error.HELP!
Smack it a couple times, gently. You have nothing to lose, AND, I swear it works!!!
Digital camera photosmart r725
it wont open when power is turn on,i keep getting ,(camera has experienced an error)(please reset your camera)this number accompanies the message-00000018-4489-957-000,ive read the manuel nowhere does it say how to reset, help ?
Dec 13, 2007 | HP Photosmart R727 Digital Camera
Cameras Logo
21 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
