Question about Sony Cyber-Shot DSC-S40 Digital Camera
The screen is blank and I cna't take a picture. . I put new batteries in the camera but still can't see anything. I have pressed LCD on/off button, turned camera on/off. What else should I try to do?
  • hhoo Nov 30, 2008
    I had the same problem. The camera kept saying access and would not show a visual on the screen. A couple hard taps on its side and bam it started working again. Thanks for the help.
I had the same exact problem. All I had to do was turn my camera on, and while holding it, rap it on the side. Surprisingly, it works now and I just saved myself a couple hundred dollars!
Posted on Nov 26, 2008
LCD screen is blank in normal picture mode. I
This Camera has an CCD issue. It seems that the CCD of the Camera is gone bad. However, you may try resetting the Camera to the factory settings. If the issue persists, try power resetting the Camera. To power reset, remove the battery of the Camera and press and hold the power button for 30 seconds and reinsert the battery after one minute and check the operation. If the issue still persists, the service is required.
Jul 26, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
The LCD monitor setting was lost after changed battery pack
Take a picture with the new battery pack. Is the picture also blank? Are the menu selections still visible in the LCD? Have you tried pressing the DISP button on the back, but the screen still remains blank?
If the answer is yes to these three questions, this sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Dec 19, 2009 | Canon PowerShot SD110 / IXUS IIs Digital...
The screen on my camera will not display anything at all. The camera appears to turn on, but the screen is blank. Even when I switch it from one mode to another, there is nothing displayed on the screen
Have you tried taking pictures with it? Do the pictures show up when taken? If so, then it's likely that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Oct 26, 2009 | Canon PowerShot SD600 Digital Camera
Blank screen
Sounds like you accidentally pressed the DISP (Display) button on the back of your camera. This manually turns the screen on and off in picture taking mode to save battery power. You could then use the optical viewfinder in its place. To turn it back on, just the DISP button one more time.
Jul 07, 2009 | Canon PowerShot SD600 Digital Camera
Blank LCD on Canon A95
Believe that you accidentally pressed the DISP button on the bottom back row of your camera. This manually turns the display on and off as desired to save batteries. Press the button once more to turn it back on.
Feb 21, 2009 | Canon PowerShot A95 Digital Camera
No picture on lcd screen only when taking pictures
Did you accidentally press the DISP or DISPLAY button on back (it turns the screen off to save batteries). If so, press this button again to turn your LCD screen back on.
Oct 07, 2008 | Canon Cameras
Samsung s860 digital camera turns on and then goes to blank screen and will do nothing else, to turn off it requires battery removal. same story with new batteries.
Dear customer
thanks for ur inquiry for ur product
If the LCD screen is blank or black when you have your camera in the Camera or Play mode, the camera may need service. To determine if this is the case, follow these steps:
1. Press the Menu button to see if the LCD screen can display the OSD (On Screen Display). 2. Set your camera to Play mode, and then see if the LCD screen displays a picture. 3. To eliminate the possibility of a user setting causing the problem, put the unit into Auto mode by rotating the dial on the units exterior to Auto Mode. Note: The word "Auto" appears on the screen when this mode is activated. 4. If putting the camera into Auto mode does not resolve the problem, test the unit in Play mode. If the unit operates normally in Play mode, but the screen in Camera mode is blank, your camera requires service which you can arrange by Creating a Service Ticket below. Note: Because your camera has an automatic LCD display shutdown feature, its normal for the LCD to stop displaying when the camera has been on for along period of time. This feature prolongs battery life.
urs sincerely
Harrish
Jul 10, 2008 | Samsung Cameras
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
Blank LCD on the camera
The camera turns on but the screen stays blank and I press any button and do not do anything no zoom no nothing and I press the menu button but neither nothing shows up just the blank screen
Jan 16, 2007 | HP Photosmart 620 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
