Sharp AR 407
My friend,
that day i clear the message when switch off and on the machine its comming again copie also comes with background
jegatheesh.1983@gmail.com this is my email id can u give me the simulation code for this machine
please
  • Tim Babcock
    Tim Babcock May 11, 2010
    Has the developer been changed recently? Has the drum been changed?
    Problem Solver:
  • 3 Answers
Hi friend,
Thanks for your assistants
there was a problem in developer unit pin(PJ Jack)
i found and solve the problem
once again i thank to u my friend
Posted on Nov 15, 2008
My sharp copier AR-407 is showing error code H5-01
hi this means you have had jams in the fuser or problems with the fuser/heater. You must clear all paper jams and the code by entering the simulation. to do this in a steady rythem press the # then the * then the red C key then the star key again. so its hash star C star
this will enter the sims. now enter 16 on the keypad then select yes. the machine may restart if this fails try the same as above but type 14 instead of 16, also 14 if you can. If this fails your fuser has a problem and may need parts changing
Jan 07, 2015 | Sharp AR-405 Printer
Sharp AR-5316 F5 ERROR
check the exsposure lamp this error relates to damaged or blown lamp also you check this when you turn th ecopier on you should see it self test at hte start up if there is no light it has blown or connections are bad
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Apr 28, 2009 | Sharp AR-407 Copier
Print Black Page
Is the scanning lamp coming on ? No, replace lamp
is there a print in the background? Yes, check Seperation unit ( inside under the drum, usually three thin wires)
Nov 19, 2008 | Sharp AR-M450N Copier
Sharp AR 407
Try this procedure:
http://olsonbros.com/sharp/support/ar16x_devinstall.html
Nov 11, 2008 | Office Equipment & Supplies
Copy to 11x17
check your settings on tray one. make sure the you set it to 11x17 by the way what is the model of your machine? don't set the machine to auto detect paper.
Mar 19, 2008 | Sharp AR-407 Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
47 people viewed this question
jasbo
jasbo
