Question about Bosch Washing Machines
My Bosch Exxcel 1400S Express (WFX148SGB) just doesn't spin anymore. Everything else seems to work fine?
    Scholar:
  • 111 Answers
Bummers. Sounds like the clutch is out. (If you can hear the motor spinning but not the drum, I'd say that's it. Especially if the machine has a number of years on it.)
I once looked into having a service man come fix a clutch. He said it would be cheaper to buy and new washing machine and have the old one hauled away.
Good luck.
Posted on Nov 13, 2008
My bosch exxcel 1400 express will not spin
take out plug first check the motor carbon brusher are not worn
Dec 03, 2013 | Bosch Exxcel WFX 145S Front Load Washer
Bosch EXXCEL 1400s. Clothes have a horrible damp smell when they come out of the washing machine. have clean and washed out all pipes but sill a damp smell inside machine. What is wrong with it? So bad...
yes,,,,,1 coup of soda crytal
1 coup of any vinegar
1 coup of diswasher salt
put it on 90 degree empty wash..........and see the result.....
my name is khan.
Apr 06, 2011 | Bosch Exxcel WFX 145S Front Load Washer
Bosch exxcel 1200 express fault code f04 what is it
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
Apr 02, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
Bosch exxcel 1200 express spinning slowly
I would suggest that you remove the motor, and check the brushes for wear.
If they are less than 3 or 4mm long, then they need to be replaced.
Hope this helps.
Jan 07, 2010 | Bosch Exxcel WFO 2465 Front Load Washer
My bosch exxcel express washing machine spin has stopped working any ideas.
not turrning drum could be motor brushes not filling could be door interlock switch..not coming on could be plug fuse or off/on switch...
Oct 24, 2009 | Bosch Logixx WFR 3267 Front Load Washer
Bosch exxcel 1400s express is the drum stainless steel
It is simple to tell what the drum is made of: if it is silvery metal-like finish, then it is stainless steel. It cannot be aluminum because the aluminum would not withstand the abrasive and detergent chemical action . It would also not be chrome or chrome finish.
If it is normal steel, it must be porcelain coated since porcelain can take the abuse necessary and also protect the steel from eroding. Porcelain will (of course) be white or grey paint-like finish. It could be a poly/pvc/plastic drum but this hopefully would be obvious and of course would also be white.
Many model come as an option of porcelain steel or stainless steel and the model number is the same except for one digit. I will assume your 's' digit stands for stainless, in either case, the silver metallic finish is the determining clue. Macgivor
Oct 11, 2009 | Bosch Exxcel WFX 145S Front Load Washer
I have a bosch exxcel 1400s washing machine and after about five minutes it trips the house electrics, can you help?
try disconnecting the Heater element, Both wires the plug back in and try..Good luck
Oct 09, 2009 | Washing Machines
USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is sironsheik@hotmail.com
Apr 01, 2009 | Bosch Exxcel WFX 145S Front Load Washer
Bosch Exxcel 1200 Express Washing Machine spin not working
I had the same problem- machiine not spinning and a few days later not turning at all. Display would go from 11min to 1min.
I did 2 things - 1) changed the brushes on the motor- cost £7.50 .
2) whilst working under the machine disconnected pipe from drum to pump and emptied it- found 2 coins in the bellows.
Nov 09, 2008 | Bosch Washing Machines
Washing Machines Logo
252 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
