Question about NEC VT47 Multimedia Projector
NEC VT460 issue with RGB input saying out of range. Using cable between laptop and projector
  • 88 Answers
Dear please set the resolution of your PC or Laptop ,so that it can give O/P at same resolution as projector. For issue regarding resolution supported by Projector go through manual of Projector.
regards,
rakesh Kumar
Network Support Engineer
Posted on Nov 12, 2008
What is pc contol
When using a special cable, pins 1, 4 and 7 of the PC control connector on the rear of the projector are used to receive RS232 serial commands from the PC to control various functions remotely in the projector.
Mar 02, 2011 | NEC VT460 Multimedia Projector
I have hooked my Epson 77c to cable in the following method. Cable directly into old vcr, vcr cabled into tv, RGB cable from vcr out to Epson 77c video input. The issue is that I can view only channel 3 on...
VCRs typically do not have RGB outputs. If you are using the VCR as a tuner for your projector, then be sure you have selected the VCR/TV button to VCR then your VCR will be the tuner. If you have it set to TV then the signal is passed through the VCR by your coax to the TV and the TV is the tuner but the VCR is now only outputting Channel 3.
Feb 22, 2011 | Epson PowerLite 77c Projector
I've connected the projector to my laptop using the VGA cable as stated in the manual. The projector reflects as it should, i can access the menu and input options which i then select RGB scart (though...
Not with any RGB input options, computers are not compatible with these. The projector needs to be set up to receive VGA. There must be a toggle button or menu entry somewhere on your projector that lets you do this or why would it have a VGA input?
Dec 07, 2009 | Sanyo PLC-XW55 LCD Projector
Double display
Hi yaali
Try using a different cable.
If the problem however persists , then you will have to get the Mainboard either repaired or replaced.
May 17, 2008 | NEC VT460 Multimedia Projector
NEC VT 460 LCD Panels & Fly Eye Lens
HI there
Firstly this ghosting image will NEVER be caused by your LCD's , so do not take them out.
Have you tried using a different cable ?
If you have and the problem still occurs , you will have to look at replacing the Mainboard.
Apr 13, 2008 | NEC VT460 Multimedia Projector
Pink tint when usig the RGB component cable
Check the green signal lead - if one of the RGB leads doesn't make good contact, the picture will take on an odd tint that doesn't always look like it's missing one of those colours. For some reason, the green is always the most common one to fail.
Feb 28, 2008 | NEC MultiSync VT540 Multimedia Projector
NEC vt460 Projector have a ghost problem on the screen
Hello
Pls Service the LCD Panels of the Projector, Also check the Fly-Eye lens, just next to Lamp unit. This will solve your problem. if it's not then the only solution is Replacement of LCD Panels, But Must check or replace the external RGB Cable first befor doing all this exercise.
Dec 16, 2007 | NEC VT460 Multimedia Projector
Problem on Picture
Pls check the RGB Panels opening physically. that doesn't seems to be a PCB fault.
Viren
Nov 26, 2007 | NEC VT460 Multimedia Projector
I have a vt46 and the projection background is red, Ive tried cleaning the lcd and the complet optic system but I cannot help myself with this partial solution, can anybody help. Thanks
Hello
PlsCheck the clear white image on the display after taking out three RGB Panel ribbon Cables. or Reconnect the red Panel, if not then replace.
Viren
Rave Services India
Sep 19, 2007 | NEC VT460 Multimedia Projector
NEC VT47 Multimedia Projector Logo
228 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
