Question about Rowenta Power Duo Iron
Shot of Steam
The shot of steam button on my iron has quit working though steam does come out of the bottom while ironing. Help?
  • Anonymous Mar 12, 2014
    it looks like it been droped, the temperture you slide up is loose but it works but the steam is coming out all the time, please can you help?
  • omaurice Feb 04, 2016
    I have the same problem I think it is a defect with Oliso. I called the company and of course the iron is out of warranty, they said I could not fix it myself and that there are little rubbers inside that have let go and I am to sent it in to be repaired The iron sells for around 200.00Can but it does not last long
    Genius:
  • 1,074 Answers
Take it down and clean, it is clogged up.good luck.
Posted on Apr 18, 2007
I got this iron for christmas, it shot steam 2 times and thats all. I had it set on cotton, linen. I used reg bottled water, should i use tap and why no shots of steam.
take it back for a warranty exchange after you check that the thermostat setting is on steam
distilled water is recommended for irons
bottled water ( filtered water) and tap water is the same product and will have minerals and contaminates that affect irons
Jan 02, 2016 | Oliso TG-1100 Continuous & Burst of Steam...
Steam not working on iron then lots of water pouring out of holes
fill water chamber with vinegar and let it sit for 24 hours.
empty vinegar - fill with distilled water - turn on and press the steam button to clean the holes in the plate of mineral deposits which accumulate from using tap water. after a few shots of steam all should be clear - empty and refill with distilled water and it should be good to go.
May 08, 2012 | Tefal Pro Express GV 8120 Iron
Water leaks out when tank is more than 1/3 full after pushing the shot-of-steam buttom
Most instructions state that iron must be at the hottest position to "boil the water." If you need a cool iron, turn steam off, and just sprinkle cool water on fabric.
Jan 10, 2011 | Rowenta Irons
I love my iron, BUT I used to be able to clean it by the recommended method, but now it will not shoot out steam to clean the holes. It does not steam on clothes even though I prees the steam button. ...
Put in as much white vinegar as possible and then turn iron on. Let it stay on for about 30 minutes the try the steam button. Once the steam button begins to work empty the vingar an fill with distilled water to rinse. You'll need to rinse several times to get all of the vinegar out.
Sep 28, 2010 | Rowenta Irons
How to empty water form iron when finished
Unless you are not going to use the iron for a long time, especially if you use distilled water to fill your steam iron, I would really not bother.
However, if you do want to empty the iron after using it, you have a couple options:
- With the iron still hot, very carefully, use the cleaning function or the 'shot' of steam until no more steam is generated above the sink preferrably.
- With the iron unplug/NO electricty: very carefully tip the water out from whe filling hole above the sink - be aware that the water will remain extremely hot for a long time so avoid splashing water on yourrsel!
Hope the information is useful.
Sep 23, 2010 | Black & Decker D2030 Iron
I want to know how to clean my Rowenta Advancer DZ9080 steam iron. When I use the shot of steam, ''stuff'' comes out of the holes.
You can use ordinary white vinegar. Use about 1/4 cup or so mixed with 2 cups water. Fill iron with this solution and operate it at full steam setting(high as possible) Set a folded towel(may want to use an old one)iron on the towel and operate the steam device until all the liquid is gone. This may clear some of the scale build up. There are Generic brands available at the stores made especially for irons, but vinegar is the most enviro friendly and is cheap.
Feb 20, 2010 | Irons
Won't steam
The steam irons I have see have a separate button to allow water from the reservoir to enter the steam chamber. This button latches down for steam and you unlatch it for dry. Also, there is a temperature range on the temp dial for steam.
The reservoir must have water in it for the iron to make steam. If calcium from the water has built up on the reservoir valve, it may prevent the water from entering the steam chamber. Straight white vinegar instead of water may help.
Nov 02, 2007 | Toastmaster 3302 Iron
Rowenta Power Duo Iron Logo
246 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
