Question about Dell Inspiron E1505 Notebook
My dell notebook d800 does not charge though the adapter is working and the when turned on it does not come,whether on ac or on battery
    Genius:
  • 1,913 Answers
Check your battery. may be it it faulty.
or check also your adpter power supply and earthing working properly.
Posted on Nov 12, 2008
I have a dell latitude d800. I need an ac adaptor a battery pack
The Dell Latitude D800 series of Notebook PC's, uses an AC adapter that puts out 19.5 Volts DC. 90 Amps. (Amperes)
This is one example I found from a quick search,
http://www.acadapterz.com/product_26527.html
Regards,
joecoolvette
Jan 16, 2012 | Dell Computers & Internet
Dell PC losing battery very fast
hi
turn off the computer , then remove the battery . reboot system and try rebooting the notebook with the AC adapter only.
this is to ensure the Ac adapter is working fine, and if it is, it should be charging the battery properly when its installed.
now, turn off the system again. re install the battery and try booting it up with the battery only
if the battery hasn't enough charge, then attach the AC adapter. If you have allowed the computer to charge the battery (while the computer is powered off) and it is not charging the battery, then you need to replace the battery definitely.
you can get a new battery (if you are in North America) from www.compluscominc.com
please send me 4 thumbs up
Jun 06, 2011 | Dell Vostro 1500 Notebook
The D800 says it is docked or running on battery, push F1 to shut down. This happens at power on and with AC power adapter being used. Have tried other power adapter(90 watt) and no docking station being...
There's a "slide-away" coverv on the bottom of the laptop, where the docking-station's adapter would connect. Manually slide the cover, and inspect to ensure that there's nothing stuck there that is "tricking" the laptop into claiming that it is docked.
Apr 16, 2010 | Dell Latitude D800 Notebook
My Dell Latitude will not turn on. When I press the power button it will come on for 5 seconds then go off. Can anyone help ?
Plug in the AC power cord, remove the battery, and try powering up. Anything? Any lights?
Remove power cord, hold in the power button for 30 seconds, then try plugging it in again and powering up without the battery. Any change?
Mar 13, 2010 | Dell Latitude D800 Notebook
I had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Sep 26, 2009 | Dell Inspiron 1501 Notebook
Cant run on battery it dies after 5 mins but battery power says i have 99 percent battery and the ac adapter only charges for 5 mins
The Cell on you battery might be dead. if its brand new you need to replace it, might still have warranty.
if not you have to buy a new one in order to run it in battery mode, how ever you can still use it without battery and plug directly at an outlet.
Apr 03, 2009 | Dell Latitude D800 Notebook
D800 will not even boot
Okay, I had that problem with my HP less than a minute ago.
Maybe it is the same problem. See if the battery light comes on. Press the power button again and again if it doesn't start, for some time. It may show the boot screen and hang. Now, the battery must be charged. Shut it down directly and switch the AC off.
Now, switch it on and see if the battery light comes on. If it does, it is the same problem as mine. Now, turn the PC over and remove the battery carefully. There may be switches for that.
Now, plug in the AC and start it without the battery in. If it does, you're done. Now, plug in the battery again.
Nov 28, 2008 | Dell Latitude D600 Notebook
remove the battery from the system and try to power on the System with the AC adapter connected. its only to check whether the system is receiving the power .
Also press the Fn key holding it down press the power button and release both the buttons , look for the LED codes and do let me know abt it
Apr 21, 2008 | Dell Latitude D600 Notebook
My laptop battery won't charge
possible when the old AC adapter blew it took part of the power management circuit with it, This is the circuit that detects and charges the battery, I'm not sure whether this a seperate replaceable daughter card or whether it is part of the main motherboard. you will need to investigate this (or send it for a service)
Oct 09, 2007 | Dell Inspiron B130 Notebook
Dell Inspiron E1505 Notebook Logo
Alun Cox
