After a few minutes of the t.v being on the picture will suddenly go of as if the T.v. puts itself into standbye mode, once this happens the only way to get the picture back is but switching the T.V. off for 30 seconds and then it resets only to switch off again after a few more minutes.
    Sergeant:
    Champion:
  • 346 Answers
When the picture goes, does the screen remain lighting?
Posted on Nov 14, 2008
    Novelist:
    Champion:
  • 203 Answers
Sure wish we knew which brand and model of set it is, but it sounds like the tv is going into shutdown possibly caused by bad solder connections or a weak component on the circuit board. The only thing you can do yourself on this one is to disconnect the power cord from the wall for a few minutes and hope it clears out any confusion in the microprocessor. Otherwise, you need a service person to go in and check it with test equip. Good luck, Russmann.
Posted on Nov 13, 2008
Vizio E470i_A0 shutting off after loosing horizontal frame sync
It could be several things but I'd start with a main board, the fact its shutting off kind of drives me away from Tcon as that shouldn't shut the set down if there was an issue there, it also could be power supply, you could test the voltages from the board once it starts giving issues and if some are off then change the power board.
Dec 10, 2017 | Vizio Televison & Video
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
TV turns itself off after about 5 minutes (green light remains on). I can turn off the TV and turn it back on immediately, however, the TV turns itself back off after a few minutes. It started turning off...
Check and make sure your fans are working and there is sufficiant cooling to the back of the set. Sounds like it is overheating and going into protection mode.
May 04, 2011 | Mitsubishi WS-65513 65" Rear Projection...
My new LG LCD TV (3 days old!) suddenly started playing up, last night. I was initially using the receiver unit (with built-in DVD) to play a disc of MPG files, which it did successfully. Then, I tried to...
Good thing the tv is under warranty, theres no magical fix for a problem like this. I would either return it to the store or call for service. If you atempt to do to much to fix it you might voide the warranty, and you should have to do anything to fix it as you said its 3 days old.
Tim Nolan
Sep 24, 2008 | Televison & Video
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
