Question about Creative Labs ZEN Vision:M Digital Media Player
Creative zen m vision won't start up,
Won't start up, but the power light comes and charges ok.On pc vis USB it won't pick up either
  • 470 Answers
You tried these yet?
Reset, Format or Clean Up a Zen Vision:M
If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
Press on the Menu/Back button on your player, and select System, and then Reset.
To Format or Clean Up Zen Vision:M
1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off.
If the battery is too low, charge the battery fully before continuing
2. Slide the Power switch towards the Power icon and hold the switch in the Power On position.
3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
4. Release the Power switch when the Creative logo appears. The Recovery Mode appears:
* Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
* Format All (Formats the players hard disk - Note: all contents will be lost)
* Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
* Reboot (Reboots the device).
5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.
http://dmzweb4.europe.creative.com/...com:80,Case=obj(14048),Kb=ww_english_add
pls rate it, thanks
Posted on Nov 16, 2008
My creative zen wont turn on just bl;ack screen
I've had this problem a few times when I haven't used my Zen for a couple of weeks. Even when the unit is powered off it still consumes battery (as the clock continues to work in the background) - so eventually the battery completely dies.
Hook it up to your PC with the USB cable and, if you can see the battery icon and it looks like it's charging, then just leave it for about 1-2 hours (it takes this long to come back to full life - enough to be recognized by your PC, anyway.
If possible, find another USB cable that will fit the connector, as the white USB that comes with the Zen is pretty rubbish and takes forever to charge - I use the mini USB cable that came with my Sony Ericsson Xperia X1 phone and it works a lot better.
Best of luck.
Sep 13, 2009 | Creative Labs ZEN Vision:M Digital Media...
My PC can't seem to recognise my Creative Zen Vision M 30gb anymore. It has been working fine but today nothing doing. The display on the device says it is docking when I plug into PC but PC says it is not...
What you have to reset is the PC, not the Zen.
Try unplugging the PC AC cord for ten-fifteen minutes. This will drain power and get rid of electrostatic charges accumulating on USB connector contacts.
If that does not work, check USB status in device manager, and test the Zen with a different cable. Also test the unit on a different computer.
Aug 14, 2009 | Creative Labs ZEN Vision:M Digital Media...
Really i don't know what the problem is. the creative doesn't charge and when it charges don't do anything
the player seems to need longer charging:
1. while player switched OFF: let it load on ac-adapter or USB-connection**** for about 1 hour, until the screen lights up.
2. still while player switched OFF: let it load another 2 to 3 hours
to get it fully charged.
**** notice: when using USB for charging:
1. Install the application software (from CD or Creative-download)
2. Preferred is a USB-connection at the backside of the computer
3. When more USB-connections are used, have the others disconnected: trying not to overload the USB-port power-consumption.
Support for Zen Vision M on the site of Creative:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=14331&prodName=ZEN+Vision%3aM
Aug 12, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen won't turn on
had same prob to the T...found this post and it fixed it...it's the computer not the zen...once I did the two steps my zen started charging and turned on...go figure...the flashing blue light doesn't mean it is charging.
posted on Feb 25, 2009 abeales
If you have windows set to do automatic updates, you most likely had a windows update installed that caused this conflict with Win Media Player 11. No fix has been posted by Microsoft yet, so the only workaround is to Uninstall/Rollback Windows Media Player 11. Goto <Control Panel<Add/Remove Programs and remove Windows Media Player 11. Follow prompts, restart computer when prompted to. Also uninstall Windows Media Player 11 Runtime application following same procedure above.
This will roll your Windows Media Player back to version 10 or 9, whichever you had installed prior to version 11. You will need to re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You probably need to upgrade your firmware at this point, follow the instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative for the screwed up hotfixes that Microsoft puts out on a regular basi
May 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
I had a similar problem with my Zen Vision:M, whereby the computer just stopped recognizing my device. I found out it was because Windws has updated to Service Pack 3 automatically, and for some reason my player only works with SP2. It started working again when I installed SP2 again, but then I keep getting the annoying upgdate notifications from windows.
May 27, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative ZEN Vision M
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
If that doesn't fix it try the USB cable
Screen Doesn’t come on anymore
http://www.anythingbutipod.com/forum/showthread.php?t=18859
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Feb 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative zen vision won't turn on
Q. Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
also try this if above doesnt work
Feb 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative zen vision m wont charge
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Jan 08, 2008 | Creative Labs ZEN Vision:M Digital Media...
It won't charge!!
More information is needed before we should talk about buying or installing anything new. Plug your device directly into a USB port on the back of your PC. If it already is try plugging it into the port on the front (yes there is a reason to my madness). Let it sit for awhile with your PC on and see if it charges now. Let us know what happens and we?ll pick up there.
Jul 24, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
1,186 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
