Question about HP Color LaserJet 2600n Printer
Sensor error, turn off then on
Hp color laserjet 2600n
  • Altin S1 May 11, 2010
    Same problem here !!
    My printer shows "sensor error, turn off then on", almost immediately after "initializing".
    I took a new printer, and checked on the old printer the two boards on the back, no result, then changed step by step the fusing unit, and the power supply - the same problem... The same think also without toners.
    So i tried to put the old things on the new printer engine... - the new printer now says "sensor error, turn off then on".
    I have returned everything on back, on the right place...
    Now i have two printers with the same error, "sensor error, turn off then on" !!!!
  • bob name Mar 29, 2013
    This problem plagued me for quit some time-finally when I replaced the DC power supply on top(RM1-1976-000), that solved the issue.
    Sergeant:
  • 237 Answers
Check the level of your toner or TOP errors. If the problem persists, let me know
Posted on Nov 25, 2008
5 Suggested Answers
  • 97 Answers
SOURCE: my hp color laserjet 2600n giving 50.2 fuser error. what should i do?
50.1 Fuser Error Turn off then on Error message50.1 Fuser Error Turn off then on Description50.1 Low fuser temperature error. The device has experienced an internal hardware error. Action
  1. Turn off the device, wait at least 25 minutes, and then turn on the device.
  2. If a surge protector is being used,remove it. Plug the device directly into the wall socket. Use the powerswitch to turn on the device.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Posted on Sep 17, 2008
713printech
  • 32 Answers
SOURCE: HP color LaserJet 2600n stucked on Initialzing
Well we can check and see if the printer is able to run an engine test. This is how you can run this test;
  1. Turn the printer around so the back of the machine is facing you.
  2. Remove the Engine etest button acess door. This is located in the bottom center of the back.
  3. Push the botton once while the printer is on. The printer should print a page with colored horizontal lines.
If the printer is able to print this page there is a very good indication the problem revolves around the PCA formatter board.
The Firmware might be outdated and causing this problem. Worst case scenario the board might be faulty, in that case your better off buying a new machine, since the cost to replace the board will be higher than that to replace this machine.
Posted on Nov 19, 2008
  • 199 Answers
SOURCE: Color printing (not black)is light on left side
you have to clean the scanner mirror . open the front cover and remove all the cartridge. you can see a 4 no's of rectangle box in which inside you can a mirrors.clean all the four mirrors.
Posted on Oct 20, 2009
SOURCE: hp color laserjet 2600n displays error 55.1 turn off then on
hello friend i have a printer HPColor Laserjet 2600n it displays Erroe 55.1 Turn OFF/ON. How do i over come this problem?thx
Posted on Jun 15, 2010
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
I can't romove drive HP 2600n in my computer! please help me!
Problem with the HP Color LaserJet 2600n Printer
Reinstall the HP Color LaserJet 2600n Printer driven...
Then try again to remove the driver.
sure you can remove the driver...........
thank you...............
Jul 23, 2011 | HP Color LaserJet 2600n Printer
Hp color laser 2600n error 51.23
51.23 Error-yellow scanner error
Try this:
Turn off the power by using the power
switch, wait at least 30 seconds, and then
turn on the power and wait for the device to
initialize.
If a surge protector is being used, remove
socket. Use the power switch to turn the
device on.
Laser scanners are not replaceable.
Replace the engine.
Jun 28, 2011 | HP Color LaserJet 2600n Printer
Sensor error
Sir
contact me at walid_sayed@hotmail.com and I will send you the service manual for free
regards
Apr 02, 2010 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600n displays error 55.1 turn off then on
Feb 18, 2010 | HP Color LaserJet 2600n Printer
Sensor error on hp 2600 printer please
Try to clear all paper dust from the photoelectric sensors inside the printer. User compresses air, if you can find a can of it. but use it gently. You ust want to clear the dust fromthe sensors, so that they can "see" again.
Nov 26, 2009 | HP Color LaserJet 2600n Printer
HP 2600n
50.2 Fuser Error Turn off then on Description 50.2 Slow fuser error. The device has experienced an internal hardware error. Action
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.
if no result,
Fix this with a new FUSER Assembly for HP Colour Laserjet 2600/n (200/240v) Part Number: RM1-1821-240CN or Fusing Assembly – RM1-1820(110/120v )
Oct 05, 2009 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600n giving "10.0000 suply error"
10.00 error is for the black cartridge. Check the cartridge locker for the black toner cartridge on the right side, is it different from the other? does it moves correctly? check properly. If the locker seems correct, try clean the contacts on toner and opposite HV pins in printer
Nov 27, 2008 | HP Color LaserJet 2600n Printer
Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Dec 05, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
1,220 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
