Dell Motherboard
Problem for Dell (W2562) Motherboard
DELL GX60 WITH WINDOWS XP. MACHINE RE-STARTS AT ANY MOMENT
By jotam_54 on Nov 12, 2008
Hi
One friend of mine said his Dell did the same. After close examination of the mainboard he discovery some bad looking caps. Replaced them and solved the problem with his PC.
What capacitors are the ones that fails? Please advice.
Thanks
Comments:
Nov 14, 2008
- Thank you. Very specific.
Best Solution
posted on Nov 12, 2008
Helpful)
Geekman
Rank: Guru  Dell Expert
Rating: 85%, 1878 votes
If you look at the top of the round shaped electrolytic capacitors, the good ones are flat, the bad ones are domed (internal pressure deforms the top of the capacitor and can explode).
Make sure you replace with the same capacitance and working voltage or slightly higher voltage.
These capacitors are polarized, make sure you don't solder them the wrong way.
Also the RAM may not make proper electrical connection, it can cause re-booting problems, remove the RAM and insert them a couple of times.
Over heating problems can also shut a computer down, make sure the fans are working properly, vacuum/remove dust from the fans (ie CPU fan & heatsink also from power supply and vents)
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Mar 09, 2009
Not Rated)
computerscot
Rating: 91%, 96 votes
The ones that failed most in DELL's had a mark looking like a "+" or an "X" depending on your point of view. The ones that had "K"'s on top were usually the good ones.
Was this helpful?
Yes
No
Popular Solutions for Dell Motherboard
Questions and Unsolved Problems for Dell Motherboard
Do you recommend Dell (W2562) Motherboard?
Answer
Answer
i have problems with webcam vx3000 microsoft and windows live messenger on windows 7
Answer
como conectar los cables de una motherboard Foxconn 45Gm/Cm? H.D.D LED + P LED - P LED RESET SW... (More)
Answer
upgrade amd le-1300 to a dual core for a 531S dell
Answer
sir i want to repair my mother bord what i will do
Answer
I tried to connect an internal card reader to my PC. Un plugged the 9pin connector to the USB... (More)
Describe your Motherboards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
