Question about Argox X-2000+ Thermal Label Printer
X2000+: no thermal transfer options and Argobar Pro issues
Dear Sir/Madam
I have recently re-installed my x2000+ argox printer at home. I am using Argobar Pro and Windows Xp SP3. I had saved all the printing files i had created in Argobar. Once Argobar had installed i created a folder on the hard drive, as previously and placed the printing files in there.
Once i opened Argobar however and selected on of the files i had created...it said that the width of the label was incorrect, yet the same size previuosly had worked.
Also, for the printing properties of the X2000+, It should give the option of thermal transfer for printing, yet only gives auotmatic selection and direct transfer settings. These i think would damage the printer head. I need thermal transfer settings for media with gap, but the properties of the printer does not give those settings.
In Argobar as well, when it starts up it asks for the printer driver to use. Previously i used the windows driver, but now i have to use the 200 dpi printer driver. Im just very baffled as to why in the windows printer properties of the printer, it does not give any thermal transfer options for the printer and why the previous files created in Argobar now dont appear to work properly.
Please help as the machine is crucial for my Father's printing business.
Thanks
Umang
    Scholar:
  • 45 Answers
Netsrapcc:
I don't have an Arox printer or Argobar, but I've seen similar messages from other programs.
First, I'd open a file in Argobar and make sure that another printer has not been selected. If the printer name has changed since the file was saved, the program probably selected your default printer, with far different attributes (higher resolution, different fonts, no thermal options).
Also check the printers properties (probably under an "advanced" option) to make sure the driver is installed for the correct model. If your printer supports label sensing other than "Media with Gap", the driver should show other settings. If a label is fed consistantly to the same spot when you Form Feed, then your sensor is working. It might take two From Feeds - one to advance the leading eadge to the printhead and one to advance the trailing edge to the tear bar.
If you just installed XP SP3, you might need to re-install the driver. You can download from Argox, but I prefer Seagull drivers, at http://www.seagullscientific.com/aspx/thermal_printer_list.aspx#Argox . There are several +2000 models listed. These work with XP SP3. You should be able to set many attributes in the Proerties and Preferences.
Occasionally, one or two files may be saved incorrectly and become corrupted (but never ALL files). In these cases, it easier to start a new file, with the proper label size, and copy & paste (if your software lets you) from the old to the new. Once I get files working well, I always copy them to a another folder.
By the way, if you have already printed with Direct Thermal settings, but had a ribbon loaded, the print head has not been damaged. Direct Thermal should turn off the warning when the ribbon sensor doesn't find a ribbon, and probably changes some of the heat attributes to optimize for ribbonless printing, so the quality with a ribbon is decreased.
The printhead can be gently cleaned occasionally with 70% Isopropal Alchohol on a Qtip, but never touch the printhead with a hard object. One tap with a metal object while the printer is on would probably destroy that part of the printhead.
I hope this helps!
God bless,
Label Guy
Posted on Nov 14, 2008
Argox x1000+ driver installed but printer does not print
try driver from seagull scientific and choose printer model Argox X 1000 PPLB . double check with another parallel port cable.
gurjeet singh
delhi india
98180 14878
gurjeet99-at-gmail
Feb 08, 2013 | Argox X-1000 Thermal Label Printer
Hello i want to use a argox ribbon printer os 214 plus with my mac book pro and osx lion is this possible ? so yes i like to know how Ron
To be able to do that you need to use a cups driver.
Try www.cups.org
try a driver for datamax or for Zebra if you have the pplz option
Else you'll have to write one.
Aug 04, 2011 | Argox OS-214 Label Printer
Need, argox x-1000+ window7 driver
Argox list another driver for windows7 - it is the seagull driver and is available from the Argox product support pages - go to http://www.argox.com/content.php?sno=0000033&P_ID=23 click on the drivers tab and you will see it there.
Jun 10, 2011 | Argox X-1000 Thermal Label Printer
I need the drivers for argox r-400
Hello Sir,
You Can get the Argox Printer Driver From the below mentioned site
http://www.argox.com/content.php?sno=0000033&P_ID=22
If you need help with Barcode Printer Sales/Service.
Call Trridev labelss Mfg Co Manufactures of Self Adhesive Labels Resellers Of Barcode Printer and Barcode Scanner And Thermal Ribbons.
Reach us at 044-24543123 / 96000 07995
For more information, visit our web page.
Sep 08, 2010 | Argox R-400 Thermal Printer
We have argox thermal barcode printer....the issue is while printing for example printing 10 copies it leaves space i.e it prints 4 copies and leaves a space and again print 4 copies and so on .... please...
Hello santiago271 ,
Hopefully problem might occur with the printer calibration setting, try printer calibration in argox printer,
if that does not work, check the label mm/inch setting.
if that do does not work, check the labels peel gap in between is even.
Hope fully, this should solve your problem
If you Any other queries, Related to barcode printer - Sales and Services.
Contact , Trridev Labelss Mfg Co Leading Labels Convertors In Tamil nadu
For more information visit our web page.
Aug 05, 2010 | Argox R-400 Thermal Printer
Argox x-2000+ barcode printing is not clear
Hello !
This model is an thermal printer.
The thermal printhead need to be cleaned with isopropylic alchool with a cotton bud.
All the best !
Nov 05, 2017 | Argox X-2000+ Thermal Label Printer
Argox 214 not compatible with vista
Thermal printers seem to be notorious for that.
Try using Vista's "Generic/Text" printer driver (you'll need to go into device manager, select to update the drivers, go to Have Disk, select "generic" as the brand). That will send raw text to the printer. Many thermal printers support this.
After you do that, you will also need to go into your printer settings and setup a custom page size that matches the size of your labels. Then you should be good to go.
Jan 02, 2009 | Argox OS-203 Thermal Label Printer
Troubleshooting Argox OS-214 Label Printer, Support
Your ribbon is not firm enough - roll the ribbon at the top until it is firm. If it is too loose it will stick to the paper. Follow directions to ensure that ribbon is installed properly.
Jun 06, 2008 | Argox OS-214 Label Printer
Argox X-2000+ Thermal Label Printer Logo
552 people viewed this question
Top Argox Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
sahoo_sanjay
bvmihai
Are you an Argox Office Equipment and Supply Expert? Answer questions, earn points and help others
