Question about Zenith C27A24T 27" TV
High pitch buzzing.
Nice TV from 2000. Has worked like a charm until recently. While watching tv, the screen fades and turns into a white line and makes a high pitch buzzing noise. Unplugged, and plugged back in, and right at that moment, it does the buzzing without even turning on the power. Cracked it apart, found a resistor burst and burnt the spot on the board it was on. ohmed it out and replaced it with an equivilent with higher wattage, but still makes noise with no imrovment. I have been looking for a schematic of this model with no luck, finding every other zenith model but this one. Can anyone help me solve the problem or at least help me get a schematic, preferably free?
  • sprawly241 Nov 12, 2008
    On the circuit board it has the label RX3214. and yes, its a really high pitch buzzing that occurs as soon as it is plugged in. when its unplugged, it slows and ramps down in pitch, probably due to caps discharging but nonetheless, it does it. I actually managed to find a schematic from a similar model and after some detailed searching, I found the resister in the Horizontal/Vertical Deflection Circuit, and that its value is 22k. I can easily replace it, but I'm not sure if there was any damage to other components, and that buzzing is mysterious to me because I do not know of any single or combination of components that could do that.
    Alright, update.... I replaced the resistor, still buzzing. Doesn't turn on. Also, i forgot this in the last comment, but it was a horizontal line. Also, the sound is almost like clicking.
  • 346 Answers
I think rx3214 might be 2.2 ohms
now there is a 220 mfd capacitor that needs to be changed and also the vertical ic
please use the EXACT replacement
Posted on Dec 05, 2008
    New Friend:
  • 99 Answers
Hi there
Let's make ur problem a bit clear. "white lines" how? where?
meaning retrace lines with full raster or a single vertical line?
buzzing sound? without even turning the power switch of the TV to "ON" or when u just plug the power cord?
I'll check for schema, mean while can u tell me where the resistor leads to? is it a fusible resistor? if so , to which area the resistor suppliers power?
Posted on Nov 12, 2008
  • Rifaa-ath Razei
    Rifaa-ath Razei Nov 17, 2008
    Hi there, Firstly make sure u turn down the screen voltage to a level so tht u see a very weak horizontal line when u work on the tv or else ur phosphor screen might burn and u will have a permanent visible line imprinted in the screen.
    A horizontal line means u have a dead vertical stage.
    But when u say it burned a 22k resistor, I am rather doubtful that u are not sue abt the value, because I don't see how a value of 22 k ohm cud get burned. it is impossible to burn a 22k with even the voltagees of a typical tv.
    I say ur vertical stage is dead.if is a old tv u cud have class B pushpull stage which a bit difficult to trouble shoot, new one's has IC's, for the vertical drive.
    First of all check for the correct value, see whether the resistor is supplying power to the vertical.
    check the where the leads of the resistor leads to, like one pin goes to the flyback and the other goes to a diode and then to a filter cap. so and so.
    then I'll tell u where to go from there.
    Don't worry U can fix it, just give me the right info
    Happy hunting
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from
Samsung LCD Loud Noise and Green Vertical lines at Start up ... > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ... > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from
High pitched sound coming from my Samsung DLP TV - Open Forum ... > Forums > Social > Open Forum
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Image disappear, loud, high pitch noise
It is likely that your Sansui TV has a power supply problem.
Jan 17, 2014 | Sansui 22"" HD LCD/DVD Combo TV
My LCDTV has a problem, Model number is 6626LCT, Now on to the problem, While doing yearly cleaning on my tv as normal, after i plugged it in it was normal for 40 seconds, It flickered and the screen went...
Only suggestion is if set was plugged in when you did what you did--unplug it and any box or receiver plugged in and wait a while--plug back and let the equipment try to reboot.
Jun 06, 2012 | Sylvania Televison & Video
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
Hitachi VCR F361
You need to change the Audio / Control Head, as well as the Pinch Roller of the machine. A worn out Audio cum Control Head will reflect in poor tracking and so will cause the above problems.
Sep 29, 2007 | Hitachi VTFX631A VCR
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
High pitch crackle buzing sound when set turned on
Did you find a solution because I have the same problem on my JVC?
Nov 14, 2006 | JVC AV-27530 27" TV
Zenith C27A24T 27" TV Logo
158 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
