Question about Magicard Avalon Card Printer
Can Not Print
I Deleted my Magicard Avalon ID Printer and now i cant find my driver CD
Where can I get this drivers.
    Scholar:
  • 71 Answers
Hi There,
Follow the link below;
http://www.magicardonline.net
Enter your Avalon's serial number in the QuickSearch box at the top right of the page.
You will then be offered the latest driver suitable for your printer.
I hope this helps.
With Best Regards,
MC.
Posted on Nov 12, 2008
Pronto id card printer is not working
Hi There,
This may be a simple driver issue.
If the USB cable is moved around on the PC, multiple copes may be installed in your Devices & Printers folder.
To test the printer, double-click on the printer's front panel button. It should print its internal test card.
To test the USB connection to the printer, download, install and run the ID Card Printer Support Utility (this requires no driver).
If you can connect using the support utility, then it is a driver issue.
Unplug the printer (power cable), delete any pending print jobs for the Pronto (including any copies - Copy1, Copy2, etc.).
Uninstall the printer driver from the control panel (Programs Uninstall).
Reboot the PC. Download the latest driver (V2.0.9). Run the installation. Plug in the power cable when prompted.
The support utility, driver etc. can all be downloaded here;
(You will need your printer's serial number which is on the base).
Hope this helps,
MC.
Mar 26, 2014 | Magicard Pronto ID Card Printer
Card wont code
Hello Sonia,
Sorry for the delay in replying to your request.
If you mean 'magnetic encoding', by far the most common reason for MAG encoding problems is the printer requires cleaning. The MAG encoding performance drops long before any problem with print quality is seen. Clean the printer thoroughly using the Magicard cleaning kit for the Avalon (part number M9005-761).
There are some useful videos showing the cleaning sequence here;
Enter your Avalon printer's serial number in the QuickSearch box (open the lid, and the serial number will be on the label below the printhead).
Kind Regards,
MC.
Feb 15, 2014 | Magicard Avalon Card Printer
I need driver for magic card printer avalon for windows 7.
look up this link to download the driver-
http://www.ultramagicard.com/technical-support/avalon-avalon-duo/drivers
Apr 20, 2011 | Magicard Avalon Card Printer
Lokking to replace my exhausted printer ribbon
Search online for magicard dyefilm and you will find many suppliers.
Nov 07, 2009 | Magicard Alto Card Printer
Magicard rio 2e, the printer needs to print the access codes on the otherside
The Rio 2E is a single side printer to print on both sides of the card you need a Tango 2E Printer.
Aug 05, 2009 | Magicard Rio ID 2 Card Printer
I cant print cards using cardfive software and magicard rio print
Hi There,
First of all, for Windows Vista, you need to be using the very latest driver (V6.02).
You can download this by following the link below;
Just enter your printer's serial number in the QuickSearch box.
Please Note: - With CardFive software, you need to scroll all the way down to the bottom of the printer list, then select the printer driver with the Windows logo next to it called 'Magicard Printer Series'.
If you still can't print from the CardFive software, can you print the Windows test page?
I hope this helps.
Regards,
MC.
Feb 12, 2009 | Magicard Rio Card Printer
Printing problem
Hi JuanU,
Which version of Windows are you running now? Vista?
If it is Vista, you will need to use the newer 'UltraDriver' for the Opera printer (V1.3.0.0 Issue 1).
This can be downloaded from Magicard's web site here;
http://www.ultramagicard.com/fileadmin/inc/support_scripts_en/printers/files/ultradriver_opera__v1.3.0.0_iss1.exe
NOTE!!! This driver will ONLY work with the following operating systems: Windows 2000, XP, Server 2003 and VISTA. If your PC has a different OS from those above DO NOT install this driver!
If you have an 'older' Opera printer which does not have an 'E' in the serial number, you will need to change the 'PRODUCT ID' from 2000 to 2800 before this driver will recognise the printer.
This is quite simple to do. Download and install the Magicard Support Utility Version 3.13 by clicking on this link;
http://www.ultramagicard.com/fileadmin/inc/support_scripts_en/printers/files/msutility_v3.13.exe
Run the Utility, select 'USB' for the comms port.
When the other tabs open up, select 'Statistics / Commands'.
In the 'Quick Command' box type;
PID2800
Then click 'Send'.
Exit the Magicard Support Utility, and unplug the printer's power cable.
Now, install the UltraDriver version 1.3.0.0 Issue 1.
When the driver install has finished, plug the power cable into the printer. The hardware wizard will finish the installation and you will then see the 'Magicard Opera' printer icon in your printers folder.
It should then work fine.
Let me know if you have any problems.
Regards,
MC.
Jul 22, 2008 | Magicard Opera 100 Card Printer
Offline
Hi There,
I think this may be something Win 2K is doing.
However, rather than power cycling the printer, simply removing the USB connection then replacing it should be enough to 'wake it up' (and save on dye film).
Check the power saving settings for your USB Root Hub;(Hardware/Device Manager/USB Controllers/ USB Root Hub/Properties/Power Management). Make sure the 'Allow the computer to turn off this device to save power' option is NOT ticked.
Check also under 'Settings' / 'Printers', right-click on 'Magicard Printer Series', you should NOT see either 'Resume Printing' (printer is paused), or, 'Use Printer Online' (printer is offline).
Also, make sure you have the latest drivers installed. The Rio 2 / Tango 2 driver V6.01 is compatible with the 'older' Rio / Tango printer (even the non 'NP' models). You can download this here;
Make sure though that you select 'update driver files' and NOT 'add a printer' when prompted (restart is required). Port name should be 'NUSB01' when you see the list of available ports.
I hope this helps.
Regards,
MC.
Mar 11, 2008 | Magicard Rio Card Printer
Static Warning light
Hi Angela,
The Red LED has the following function;
On all the time (not flashing) - Lid is open.
On and flashing - An error has occured. ('out of dye film', 'card jam', etc).
The error would normally be reported on the PC screen via the status monitor. If the status monitor is not running you will not get any error messages. To get the status monitor running again, it's easiest just to re-install the driver. The drivers can be downloaded from Magicard's web site The latest driver for the Rio 2 / Tango 2 (V6.01) is also compatible with the Rio 1 / Tango 1 printers. Download the driver from here;
http://www.ultramagicard.com/support/technical-support/?R=&L=&id=&lang=1&printerID=7&supportOption=1
IMPORTANT: When you run the driver installation setup program, the printer should be switched off. Also, you will be given the following choice;
'Add a printer' or 'update driver files'. Select 'update driver files'. The PC will then ask you to restart. The installation will continue after the reboot. Select your communication type (either USB - recommended, or LPT). You will be prompted to switch on and connect the printer. If USB the port name will be 'NUSB01'. Follow the rest of the instructions to the end of the installation. You will be asked to choose the model at the end.
You should now have a working status monitor. Let me know what the error says on the PC screen if you get one when the printer initialises.
I hope this helps.
Jan 16, 2008 | Magicard Rio Card Printer
I have error whenever i just select encoding only
Hi There, I presume (from the error number) that you are using LC3 (monochrome) dye film in your printer. This error is normally given when the printer detects LC3 (monochrome) dye film, but is then sent 'Colour' printing data from the driver. If you have 'encode only' selected there should be no printing data sent to the printer at all (number of copies = 0), only the mag stripe information should be sent. I suggest you contact Magicard Technical Support in the UK (I am one of their support engineers). We will need some further information (serial number of the printer, etc). Please also check you have the latest firmware (print the internal test card by pushing the button on the back) and are using the latest driver. All are available for download from: www.magicard.com To contact customer support send an email to: customer_service@ultra.co.uk Advice is free regardless of whether the printer is in warranty or not. With Best Regards, Alan.
Aug 20, 2007 | Magicard Avalon Card Printer
Magicard Avalon Card Printer Logo
173 people viewed this question
Top Magicard Office Equipment & Supplies Experts
Safe-Card ID...
Tom Chichester
Are you a Magicard Office Equipment and Supply Expert? Answer questions, earn points and help others
