Question about Koss KD230 DVD Player
Shut Down just after turn on
I have this model I press the on it powers up then goes off will not respond to remote. I donot know if this is a safe mode for this model. Thankyou for your advise and help.
0 characters
1 Points
Tried to reset DMPBD79last step it shut off it wouldnt turn back on I just get a blinking redlight.
This is for a diff. model but give it a try, they may be diff. #'s showing up then what pops up on screen then is listed below.
  1. Remove any disc from the drive and switch the device to stand-by
  2. Press and hold [OK], [BLUE] and [YELLOW] simultaneously on the remote control until the device turns on and shows "00 RET" on the display
  3. Repeatedly press [RIGHT] on the remote control until the device shows "08 FIN" on the display
  4. Press and hold [OK] on the remote control for at least 3 seconds -> The device will reset itself to factory condition and show "HELLO" on the display
  5. Press [POWER] button on the remote control -> The device will shut down
May 02, 2016 | Panasonic DVD & Blu-Ray Players
I need code(s) for my DVD Video, Model #: NB093 remote control to program my Philips DVD Player/VCR, Model #: DVP3345V/17. Can you please help me? I would greatly appreciate it. Here is a picture of it. lists the code for your device as possibly being 1000, 1001, 1002, 1003, 1004, or 1005. Of course, you also have the option of using the remote controller's "Code Search" button. 25300580-iv4burzhkawezvl2jbah1xae-2-0.jpg With Codes:
Turn on the DVD/VCR unit directly. Continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Enter the four-digit code (1000, 1001, 1002, 1003, 1004, or 1005) for the DVD/VCR unit. The remote controller's light should go off. Press the remote controller's power button, & when the DVD/VCR unit turns off, then you will know that the remote controller has been correctly programmed.
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Nov 29, 2014 | DVD & Blu-Ray Players
Unit model D-C350/XSA only opens region 4 need to also to open region 2 DVD's
When I was with Samsung NZ, the following was how we multizoned our DVD (Region 4) players:
1. Turn on your player, but ensure no disc in machine - screen should show "No Disc"
2. Turn on your TV and select your DVD input (as if you were to watch your DVD).
Using your factory supplied remote, press the following buttons:
3. Press the Repeat (or Repeat A-B) button
4. Press the following button sequence: 7, 6, 8, 8, 4, 9 (you should see the number '9' appear on screen - this means 'Region Free').
5. Press the Open/Close button (to open the tray)
6. Press the Open/Close button again (to close the tray)
7. Press Power OFF (to shut down your DVD player)
8. Press Power ON (to turn on your DVD player)
9. Insert Region 2 disc and wait (up to 1min) for firmware to respond and read your disc
If this fails, try procedure again, except for Step 4: change the last number (instead of 9) to '2'.
Let me know how you get on.
"If this has helped you, please be kind enough to leave a testimonial rating"
Jul 09, 2011 | Samsung DVD-C350 DVD Player
Do you have to reprogram the remote after changing the batteries?
It depends on the remote model.
After changing the battery please check weather the remote works or else you need to reprogramme it.
For programming please follow the below steps
1.Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid. Release the Setup button.
2.Press the Mode button for the type of device you want to program on your Philips universal remote, such as the TV or DVD button.
3.Release it immediately and make sure the indicator light is illuminated.
4.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
5.If the device responds, you have successfully programmed your Philips universal remote.
6. If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds
Jul 25, 2010 | Philips Magnavox DVD/VCR Dual Player
How to turn the "SAFE" feature off
Normally it's a button on remote you would hold down for 3 to 5sec. if you don't have owners manual check there web site i'm sure they can help.
May 22, 2010 | Sanyo DVW-7000 DVD Player/VCR
Unlock Region Code for LG XB12 Mini Home Theater
Below is the only known process to unlock the region settings on that model of dvd player.
Make sure there is no disc in it
Turn on by pressing "Power"
(--------) apears an "No Disc"
Press "Pause" on remote and "314159"
"Code" apears
Press "0"
"Code 00" apears
press "enter"
Turn off and on
Hope this works for you, let me know. If it doesn't then there are no available region hacks for your dvd player.
Thank you for trying Fixya!
Mar 25, 2009 | Sylvania DVC-840E DVD Player/VCR
"safe" keeps me from opening dvd tray manually (must use remote control)
I unplugged the recorder for 10 seconds, replugged it in and voila, the problem was solved.
Walt in Indiana
Apr 11, 2008 | GoVideo VR3845 DVD Recorder/VCR
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Stuck in "safe" mode
Hold down power on vcr/dvd unit or the remote for 8 seconds. It turns the SAFE mode on or off.
Oct 29, 2007 | GoVideo DV2150 DVD Player/VCR
Koss KD230 DVD Player Logo
21 people viewed this question
Top Koss DVD & Blu-Ray Players Experts
Mike McWhinney
Are you a Koss DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
