Fujitsu Lifebook N5010 PNY sd card not reading.
Thanks for the quick response this is quelitemorad. The card reader is built into the computer. I do not have the software for the phone but I am searching for it. I lost the disk never had to use it before. Do you have any other suggestions?
  • Tim Babcock
    Tim Babcock May 11, 2010
    What is the make and model of the phone?
I have a PNY usb 2.0 combo. The usb ports work fine and read external drives etc. The SD readers quit working. The SD cards read fine on the internal mounted reader. My PC recognizes the drives, and t
I bought a deer cam (trail camera) at Walmart and a PNY card with PNY Multi-Slot USB & Flash Card Reader P-UBSDRDR21K-RF. I can't make them all work for me. PNY card reader has no instructions on the package neither on their website and their support is a joke. When I plug in this multi-slot card reader into my PC (I tried two different PCs) something isn't right. I get no results, just empty folders. The card is new and has data on it. Both products come from PNY, both were purchased at Walmart and both are going back to Walmart for a full refund and I will never buy a PNY product ever again.
Feb 14, 2013 | PNY Memory Card Reader and USB Hub Combo
My computer is not recognizing my PNY SD 1GB memory card. I can still take pictures and my camera saves them to the memory card, but when I try to transfer the pictures to my computer, it does not...
In this instance, you might want to consider either borrowing, or, purchasing and card sd reader. Some computers just don't read these cards from their built-in slots, so, using an sd card reader often fixes the problem.
Hope this helps. :)
Oct 06, 2010 | PNY 1GB microSD Memory Card
Cannot sync my sd card. if you slide in the memory card no response from my computer. im running oon an windows 7 o.s.. what should i do to install the sd card reader driver. im using a fujitsu lifebook...
No driver is required, the SD card should be automatically recognized as an generic Removable Dive. If it isn't it's because the card itself has died. Junk it and buy a new one.
Aug 07, 2010 | Computers & Internet
The operating system was Kubuntu and i switched it to windows XP and now the Sd card reader does not read an SD card.What could the problem be?
http://www.pc-ap.fujitsu.com/support/drv_lb_wxp_e8010.html
the problem that you do not have the driver for the device ....on this link you have all drivers for your model .....take a look I do not know the exact one ..but you will locate it ...I believe that its tha PCMCIA but Im not sure ...
Oct 21, 2009 | Fujitsu Siemens LifeBook E8010 Notebook
Have a pny micro sdhc 4 gb disk that is not being read by my computer?
From your description, it sounds like the card is faulty, not the computer or the card reader. If you can't get the card to read or write in any device now, then it's probably dead. Is the card reader you're using an SDHC card reader or just a regular SD card reader?
May 14, 2009 | PNY 4GB Secure Digital High Capacity...
Fujitsu N3511 not reading 2GB SD Card
you have install memory card driver first..
Dec 08, 2008 | Fujitsu Siemens LifeBook N3511 Notebook
After reformatting my fujitsu lifebook n5010 it doesnt read it.
Is the card reader built into the computer?
I know there are a few card readers out there having trouble reading 2 gig memory cards if the computer or card reader was built over 5 years ago.
If you have a data cable for your phone and software for the phone, your computer should be able to read it that way.
Nov 12, 2008 | PNY 2GB microSD Memory Card
SD and CF reader
The PC will see the card as a storage device so should read any capacity Compact Flash, or Secure Digital cards that you put in the readers.
The devices their used in usually have the capacity limitations as to what size cards they will read/write to.
Mar 21, 2008 | Fujitsu Siemens LifeBook P5020 Notebook
Pc card slots
Have you tested the card in another laptop to be sure that its working? You shouldnt need updated drivers for it. Have used new card on 10 year old laptops before and they worked fine. Are you sure that the slot is functional?
Jan 04, 2008 | Fujitsu Siemens Lifebook N5010 Notebook
Computers & Internet Logo
232 people viewed this question
David Payne
David Payne
