Want to change LCD brightness on Clock Radio
I brought a Logik LOGCRI138 Clock Radio, only problem is the LCD display is so bright it lights up the room in the dark.
There are 2 settings for LCD brightness and it is switched to Lo.
I'm wanting to find out if there is a way to internally adjust the brightness on the LCD?
Any help appreciated.
Thanks
  • Heather McGuinness
    Heather McGuinness Apr 25, 2014
    I know what you mean. The leds are way too bright. Bright LED Shades makes an adhesive plastic that covers over the led to cut way down on the glare. Nice and sleek. And it pulls off without any sticky residue. Just a thought.
  • 62 Answers
You could try to internally change the brightness, but unless you know a lot about circuits, I wouldn't mess with the internal wiring.
Posted on Dec 09, 2008
How do i adjust the brightness on the lcd display. LOGIK cd/usb/sd car radio. RSH-249385-018
Most car radio displays are pre set and dim when the lights are on.
Feb 09, 2015 | Cars & Trucks
Display not bright enough on Bose AWR1-1W clock radio
Yes...within a range. The display will automatically lighten and darken depending on the amount of light in the room. During the day or when there are bright lights in the room, the display will go to full brightness. When the lights go off or the room is otherwise darkened, the display will shift down to a lower brightness. You can make the "lower brightness" a bit brighter by holding down the CLOCK SET button and pressing the 'volume up' button.
Dec 26, 2013 | Bose Wave Am Fm Radio Awr1-1w Not Working...
Display light not working. can't see time at night
From the manual:
This alarm clock radio features an adjustable display backlight, with dim, medium, and bright settings. To select a backlight setting, press the Snooze/Dimmer Bar until the desired brightness is reached.
Dec 01, 2013 | Timex T309TT Clock Radio
How do i increase the back light. IT has gone dimmer while setting clock
Press the snooze button 4 times. The display toggles between lo/high brightness. ;-).
Mar 31, 2012 | Sony ICFC218 Clock Radio
How do you increase the volume of the backlit light?
Hello
The backlight can be adjusted as follows:
select a backlight setting, press the 3 Snooze/Dimmer Bar until the desired brightness is reached.
Please note that the backlight will not work while the clock is operating on battery power.
OK
Apr 07, 2011 | Timex T311T Clock Radio
My Bose Wave is doing fine except that the brightness of the display in the front goes dim and bright, sometimes flickering. Most of the time it is dim and not readable. I did change out the 9V battery...
Hi.
This is a common problem with this model.
The LCD has a dimmer circuit that can be responsible, in some case it is not the dimmer regulation, but the LCD control circuit itself. In that case you have no LCD backlight and the display is almost unreadable. If that is the problem, changing dimmer settings with procedure below will not help.
Most of the time the problem is dimmer regulation.
About dimmer regulation:
Try disconnecting the unit power cord for ten minutes and connect back.
Try holding down CD or CLOCK button and pressing at the same time the volume buttons. This procedures regulates Bose dimmers setting in a scale from one to 9. The dimmer has separate settings for medium and low brightness. Set both to 5 if you want to disable dimmer settings.
Dec 09, 2010 | Bose Wave Radio
Lcd display very dim
My clock display is extremely bright, is there a way to dim it? thanks Natalie natalie1959@gmail.com
Jun 18, 2009 | Bose Wave Radio
Time Display
A-ha! Those manuals sure do come in handy sometimes. I found the solution. In addition to functioning as a snooze button for delaying the alarm, the snooze button is also a brightness button for the time. If you press snooze one time it changes the time brightness from bright to dim, press it again and it goes from dim to motion sensitive only, press it again and it returns to bright.
I just tried this and resolved my problem. I hope it helps you as well.
Enjoy!
Sep 01, 2008 | Emerson Smartset Clock Radio
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Timex t439s clock display light out
The display on my clock is red as well. I found it that way when I came home from work today. It had lost all of its settings as well. I put everything back to the way it was supposed to be but I can't get the color to change. I guess something just quit.
Dec 12, 2007 | Timex (T439S) Clock Radio
689 people viewed this question
 Grubhead
Grubhead
