PLAYS CD BUT COMES VACK NO DISK WHEN YOU TRY TO LOAD DVD .ALSO LO
NEED
  • 684 Answers
I think there is a problem with the Optical Lens...........There are 2 things which u can try to do at this point of time.......
1. Use a Disk cleaner and use it abt 3 times and then use the CD and see if it gives the same error message.....
2. Remove the cover of the DVD player u will see a white strip going from the Lens to the Board take out that strip and reinsert it.........
3. Please don try to replace the Optical Lense without trying this steps because the optical lens will be more costlier then a Strip may be the strip is defective......
Posted on Nov 14, 2008
    Habit-Forming:
  • 163 Answers
The laser (optical pick up) need repalcing usually an uneconomical repair in view of the low cost of DVD players noe.
SUPER8
Posted on Nov 13, 2008
Dvd player will not load disk and play?
From your description it is hard to tell if the problem is from the disk or the player. Can you try another disk? If that loads and plays the problem is with the previous disk you tried to load. If there is a problem with the DVD player, it will be cheaper to buy a new one than try to repair. You can even find DVD players at some of the resale shops for under $10. Good luck.
Apr 20, 2016 | GoVideo DVR4175 DVD Player / VCR Combo
CD disk is plays, but DVD disk in no playing,,sometimes dvd plays,mostly no disk
try cleaning the laser lense
If you have a dirty lense it can still read cd because data is not as compressed on dvd, each byte of data takes up far less space on a dvd so the dirty lense might not pick it up whereas it might pick it up on a dvd
Jun 24, 2015 | Televison & Video
Cds will not play in loop. plays one cd and shuts off will not move to the next cd
Troubleshooting Solution
  1. Lift disk changer doesn't work comes message "Disk Error"
  2. Lift disk changer work fine but doesn't load a DVD
  3. Power light is ON but doesn't want to Power UP
  4. From the beginning start DVD movie the picture distorted and freeze
    avsystemparts.com
1. Possible Problem w/ Main Board PCB
2. The dive laser assy replace. or full complete 5 Disk changer ROM
3.More chance problem w/ Main Board
4. Problem w/Main board need replace it.
Dec 24, 2012 | LG LHT874 Theater System
Dell demension 3100 dvd plays any disk ok but will not burn
when you try to save or burn any data to disk, you should use burning programs just like nero or any other burning program. at the time when you click the button burn, it always ask you to insert disk such as CD/DVD +R or RW
Mar 25, 2010 | Dell Dimension 3100 PC Desktop
The DVD player does not play any DVD disc but plays CD.It says DVD driver not installed.
yah, you need to install the driver. If you have the recovery disk of your laptop that it comes when you buy it, insert into your cd rom and run it or follow what it says to the screen.ok
Feb 18, 2010 | Compaq Evo N610C Notebook
DVD Player Not loading Movies
optical sensor is burned out or the spindle is not spinning the disk to read it.
Nov 06, 2009 | Coby DVD-224 DVD Player
DVD plays audio but no video? The LG screens comes on but the screen goes dark and only the audio plays. I ran the disc cleaner.
NO NEED TO CLEAN LENS, YOU HAVE A MOTOR PROBLEM, IN THIS CASE YOU WILL BE ONLY ABLE TO PLAY AUDIO DISK AND NOT DVD. BECAUSE OF FREQUENTLY USED, DVD DISK MORE SPEED ROTATION THEN NORMAL CD, SO CHANGE YOUR MOTOR AND CHECK IT WILL WORK......
Oct 14, 2009 | LG DP781 Portable DVD Player
The problem is i cant play mp3 or DVD s in my philips dvd player when i insert sometimes it plays but sometimes it says LOAD but doesn't play.product code is philips dvd dvp3268
When the unit does not load any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Jul 21, 2009 | Philips DVD625 DVD Player
Dvd player only plays some movies
it might be sevral reasons:
1. Check if region code is the same for movies you playing and DVD player
2. If you using video CDs or copyed DVDs, player might be preventing to playback those kind of discs, due to copyright laws or due to different speed settings for DVD player and discks you using (for intsrance you player can playback DVD/CD+R, and you using DVD/CD-R, or mximum allowed playback speed is 16 you using disk recorded at 24, but this is in case you using burned/copied CD/DVDs)
3. Check it lens is durty. For that use CD/DVD lens cleaning disk
($6 in Walmart, if you are in US)
4. Check if movies you are have the same coloring system, i.e NTSC for US
5. Check CD/DVD for scratches, some DVD players can not playback scratched disks
Please kindly let me know if my information was helpfull for you or you need more info
Good Luck
Feb 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Will not read disk recorded on Samsung DVD digital Camcorder
The disk needs finalizing.
However this then will make the disk unusable for anything else
Switch to CR R or DVD R as appropriate
Dec 18, 2007 | Plextor PX-740A (00765075107763) DVD RW...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
