I have a hp 1280 deskjet , absolutely no black coming out I have changed ink cartridges cleaned all parts that clean can you please help?
    Problem Solver:
  • 14 Answers
It does sound like it could be a cartridge issue. And, that would be the place to start. Replace the cartridge with another and see if you get the same results. If so, it is highly unlikely you have 2 defective cartridges. The other components to suspect are the carriage unit itself and more particularly the sensor on the right side of the carriage unit. Dirty encoder strips (thin mylar strip running behind the carriage) also can cause these problems as well as dirty encoder wheels. (Round mylar wheel on the left side of the machine attached to the pick up roller assembly.
I have serviced several of these types of machines and it is rare to have much go wrong with them. Often a good and thorough cleaning of the entire machine will bring it back to life.
If you find you are in need of parts for this machine check out the following website:
Posted on Nov 13, 2008
  • 90 Answers
Since how long the cartridge not used. As the ink is not coming out may be it get dried up.
Have you another cartridge to use in printer? Otherwise refill the cartridge again so that it can be used.
Sorry we cannot provide you much support in this, as it seems directly the case of non-use for a long time.
Hp 1280 cartridge is not moving at all
A common issue with HP ink jet printers is the encoder strip gets dirt or ink on it. It is a plastic strip that has vertical lines all across it. The strip goes from one side to the other. You can clean it with an alcohol swab.
Jul 24, 2012 | HP DeskJet 1280 InkJet Printer
Yellow light for ink missing is blinking all the time i put the two new black and color catridge
This is a typical cartridge problem.Try clean the contacts on the carriage unit using piece of cotton and some alcohol.If this not help open the printer cover and look when carriage unit stops.On the carriage unit have a yellow arrow.In the left sidе of printer, where the carriage stops have a two icons.If the arrow shows left icon change the color cartridge.If shows right icon change the black cartridge.If this not help there is a problem in carriage unit and your printer need repair.
Nov 05, 2009 | HP DeskJet 1280 InkJet Printer
Cartridge empty light
A few basic causes.
1. The cartridges you bought iwere not proper HP ones and many "clone" cartridges are known to have problems with the ink level chips
Take them back and get them replaced with a different brand
2. They are original cartridges but may still be faulty (rare but possible)
3. Your print head is clogged or faulty
Run your printerthrough the head cleaning process a few times and see if it clears up.
4 your cartridges are out of alignment
Run your printers alignment test
I would suspect number 1.
If you found this information useful please click below
Aug 12, 2009 | HP DeskJet 1280 InkJet Printer
Black not printing
re install a Printer driver on your pc
May 11, 2009 | HP DeskJet 1280 InkJet Printer
My hp deskjet 1280 will not print yellow
Hello, this is Harry from
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
May 09, 2009 | HP DeskJet 1280 InkJet Printer
Red will only print on test page.
So what you need to do is clean the cartridge from the printer all the three steps cleaning..(clean cartridge,prime cleaning,intermediate cleaning)..
once the cleaning is done..try to make a copy..if its still the same..change both the ink cartridge and then try to make a copy..if it resolves the issue then cartridge is defective..if it does not resolve the issue then printer is defective..
Mar 09, 2009 | HP DeskJet F380 All-In-One Printer
Hp deskjet 1280 black colour problem
remove the Printer Catridge & clean the belw points where the INK come out, & shake properly & insert,
May be catridge ink got dried,
Jul 29, 2008 | HP DeskJet 1280 InkJet Printer
HP Deskjet 1280 printing problem
try cleaning your printer cartridges, go to printer preferences,then go to the service tab, try cleaning from there.
hope it helps
Dec 10, 2007 | HP DeskJet 1280 InkJet Printer
Printing only blank pages
you have to go to the printer settings start printer properies ink or color than change to color because you can set your printer to print color or just black does not matter if that one has color if the setting is for black it will print just black
Dec 02, 2007 | HP DeskJet 3940 InkJet Photo Printer
Printing problem
You have either a clogged colour print head or a non-functioning print cartridge (only one colour working). If the printer has separate cartridges for different colours (and black) you can do a partial swap, replacing the ones that have failed, but start by running the command CLEAN PRINT HEADS from the printer options or controller panel, and watch for the quality to improve. You may have to clean the heads two or three times. If no change in the quality after two flushes, replace the cartridges with new ones.
Good luck...
Nov 16, 2007 | HP DeskJet 610c InkJet Printer
144 people viewed this question
