Question about Emerson EWV403 VHS VCR
Emerson EWV403 VHS VCR stops taping and powers off spontaneously
While recording, it spontaneously stops recording and powers off. Can do it less than an hour after starting or even 2 or 3 hours. Once, the tape was still in machine and pulled from the cartridge on eject but was able to easily pull the tape from inside and rewound it into cartridge manually. The tape was damged (crumpled) in one area.
Thanks for your help.
    Novelist:
    Champion:
  • 254 Answers
There are probably a few different ailments which can cause this. One is if something is afoul in tape transport. I'd think the problem would occur whether in record or playback however.
If the tape takeup reel drive is slipping, tape takeup might intermittently stop, and cause the machine to power off (this is to avoid spilling tape in the machine). With the cover off, insert a tape, hit play, and see if tape takeup is steady, especially nearer the end of the tape, when the right reel is filling up.
An associated problem is if the reel sensor is intermittent- this sensor tells the logic whether or not the takeup reel is turning- again, this is to avoid massive tape spillage and damage.
Another possibility is a dirty mode switch- this switch tells the logic circuitry what position the mechanicals are in. It is probably located on the underneath side of the deck. Sometimes it can be disassembled and cleaned with a cotton swab wetted with contact cleaner. Others must be replaced.
Hopefully this helps- perhaps another tech has a better solution too.
Posted on Nov 14, 2008
How do you record somthing when what you want to record is 8 ours away and you won't be home
you need to set up the vcr clock and then setup scheduled recording as per your VCR manual. This is usually found in the VCR menu accessed with the VCR remote.
Mar 06, 2011 | Emerson EWV403 VHS VCR
Taping VHS through HD Set Box
as i am aware of you can only tape sd programs on to vcr and not hd.
May 26, 2010 | Emerson EWV403 VHS VCR
EWV403 VHS VCR: Can't get it to eject the tape. Any suggetsions...
This is common for this player. if you need the tape, send it to the shop because parts inside can break.
May 18, 2010 | Emerson EWV403 VHS VCR
Tape ejects after playing for about 30 minutes
it could be dirty pinch rollers causing the tapes to tighten and be ejected. try fast forarding the tape to the end and rewinding. if this does not cure the problem, run a wet cleaner tape through.
Mar 05, 2010 | Emerson EWV403 VHS VCR
After vhs auto rewinds both it and TV power down
some televisions have a feature where the video signal disappears,they power off.when the vcr shuts off,the signal goes and the tv shuts down
Jul 07, 2009 | Emerson EWV403 VHS VCR
Changing to ep
Hi, Try push (Menu) button on VCR Recorder to see Tape speed. Then follow instructions on TV to change speed of tape........Crazyred94
Jun 28, 2008 | Emerson EWV403 VHS VCR
Recording a tv show on a emerson vhs recorded problem
Allow the VCR to perform the much needed channel set up process... after this procedure, you will be able to record error-free...
May 30, 2008 | Emerson EWV403 VHS VCR
Can't get movie to play
Are you trying to record on a protected tape? Does it do this on all tapes?...accordianman
Feb 18, 2008 | Emerson EWV403 VHS VCR
Emerson EWV403 VHS VCR Logo
166 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
