Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Toyo stove laser 30
My toyo stove laser 30 would not ignite. I was getting ee2 which means out of fuel. I fixed the problem and now it is regerstering ee22 which my manual says is an igniter problem now I can't get it to even try and run when I plug it back in its says ee22 and won't even try to begin to run.What can I do? COOOLLLLDDDD
  • dwestalaska Nov 14, 2008
    Thank you you hit the nail on the head and its working fine again thanks very much
  • 8 Answers
EE22 means that your Toyo failed to ignite 3 times in a row. You need to unplug it for 30 minutes to reset the circuit board. Then plug it back in, push the red reset button on the right hand side in the little hole towards the back and push the Power button. Your Toyo should ignite after that barring some other problem caused by running out of fuel.
I am assuming that you ran out of fuel which caused the EE2 error code originally. Sometimes, when you run out of fuel you can get water, ice, debris in the fuel line causing an obstruction or limited fuel flow. You may also get an air lock. You may need to crack the fuel line at the back of the Toyo where there is 3/4 nut and bleed the line. If you see no fuel or a small quantity of fuel then you will need to thaw and/or purge the fuel line in order to get fuel to your Toyo's fuel pump.There is also a screen in the sump which can get plugged with rust, debris from the bottom of the fuel tank so you may need to clean the screen in order to get fuel to the pump.
Posted on Nov 13, 2008
    New Friend:
Hi i have laser 30 and it exceeds the temperature set. Like i set it at 68 degrees and it the actual temperature will be at 78 degrees. The pot burner will not go out. So dont know whats going on?
Posted on Mar 08, 2013
Steps to fix a EE2 Code on a Toyo 30?
It is a fuel issue, when opening that valve with the fuel strainer out. If your fuel was right it would gush all over. More fuel or lift tank. I hope you have a filter at the tank, if so change the element. (its cheap and good preventive maintance.
Any other questions call me
Total Toyo
Nov 19, 2012 | Rinnai Toyostove Direct Vent Heater: Laser...
Lazer 30 error 22 on panel
The stove quit three times with an ee2 message. The stove is trying to save you from flooding. You may have a fuel problem that is causing the ee2 problem. After three time the stove locks out and won't let you try again. Find out whats up with the fuel. Unplug the heater for 20 minutes and you will be able to try again. Also make sure the igniter is getting hot. Two red wires going into the burner should get hot.
Sep 25, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Ee2 error on toyo laser 30, how do we access fuel system
I would look outside first. Filter, fuel level and bled the filter. Loosen the fitting on the fuel line and let some of the air out. Do it outside so you don't make a mess inside. After that if you still have a problem check the two red wires that go into the burner. If they don't get hot when you try to start you have an igniter problem.
Sep 20, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
My toyo lazer 30 won't start, and the EE2 problem comes up.
With an EE2 message you have a problem with the stove igniting during start up. If you continue to try you will end up with an EE22 and the stove will be locked out. If so, un plug for 20 minutes. While you are waiting check out you fuel system. Low fuel, no fuel, dirty filter on tank and stove. Be sure to bled the air off the top of the filter when you change it.
Keep us posted.
May 14, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
I have an error code of EE2. The system will not
First- do you have enough fuel.
Does the unit ignite or not
More info would help me
Total Toyo
(907) 488-9179
Dec 15, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyo Laser 56 EE2 message--no flame? valves open and clean filter
You might of got type 2 fuel oil. If it is a smaller tank sometimes the fueler doesn't clear the line before filling and you'll slug down some type2 which will snuff the flame.
Check to see if the filler kinked a line outside while filling.
Just an Idea...
Oct 07, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Error 22 whats that?
The EE22 message means the stove quit with an EE2 three time in a row. In order to clear the EE22 you must unplug the unit for 20 minutes. Then you can try again. It sounds like you have the fuel problem figured out?
Tom Hawkins
Apr 01, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
L60AT wont relight
EE2 means no ignition. It could be No fuel or low fuel, dirty filter. You need to look at the flame when you try to start the stove. If you have flame then the igniter is good. If there is no flame and a bumping noise you have a fuel problem. No flame and no bumping you may have an igniter problem. Feel around the burner pot to see if it gets hot. A bad igniter will lead to a flooded stove if you continue.
Tom Hawkins
Bethel, Alaska
Dec 23, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove Laser 73 EE2
The firing sequence for a L73 is blink, blink, blink, on the green burner light, then it clicks up to the medium, amber or yellow light...that's when the pump kicks on. If you hear click, click, click, or thump, thump, thump, that means the pump is starving for fuel. The problem is from the carburaot/sump back to the fuel tank. You may have icing in your line or a line restriction, no fuel, plugged fuel filter or plugged sump screen. You can thaw your fuel line, until you have a free flow of fuel and then push the red restart button on top of the sump. Try to restart your Toyo.
If you follow the firing sequence and hear no click, click, click or thump , thump, thump and your Toyo goes off on EE2 then you can have a dirty flame sensor...the whilte wire running to a U shaped part that is the ground for the entire unit. You can take ythe ytwo phillips screws out, turn the part to the side and wiggle it out. Clean it qith a green scrubby or sandpaper and put it back in. Be sure it points stright down. Then take out the igniter which are the red wires. Put a long screw driver in there and rattle it around real good. You are trying to shake any carbon cxhains off the burner ring that can be "shorting" the flame sensor. You can also removee the 1/2 inch flare nut from the fuel nozzle...brass yellow colored metal part, and put a paper clip or wire down that about 3 inches. That will clear any blockage in front or inside it. Put everything back together, hit the red reset button on the sump and re-fire your Toyo. You might get it going in this manner. If not, you may need a tuneup because your Toyo is too sooted up to run correctly. Try these things and post back!
Nov 10, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyo stove, Lazer 30 model
EE22 is a lockout code.
Unplug unit for 30 min.
You need to findout why you still get EE2 or EE6
Check fuel and filter
Still have problems call me I'm in North Pole
Dave 4889179
Apr 10, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
1,382 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
