Question about GE GTD120 System
MY HOME THEATRE AMP. SHUTS OFF ITSELF, AND SOMETIMES SCREAMS W/ N
I HAVE HAD THIS RECIEVER FOR A YEAR NOW. THINGS ARE ALL HOOKED UP. SOME SPEAKERS DO NOT WORK. BUT IT NOW FIRST TURNS OFF BY ITSELF, AFTER ABOUT 15 TO 30 MINUTES. I HAVE TO UNPLUG IT TO TURN IT OFF, ONCE i TURN IT BACK ON AGAIN, AND AFTER 30 MINUTES, IT STARTS TO SCREAM THIS REALLY LOUD HIGH PITCH SOUND!!! IT ROCKS THE HOUSE. ONLY WAY TO TURN IT OFF IS TO UNPLUG IT. FREAKY STUFF I KNOW. ANY SUGGESTIONS?
    New Friend:
  • 99 Answers
First suggestion is to recheck all the connections
Rifaa
Posted on Nov 17, 2008
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
Amp keeps shutting off
• Check again with no speakers connected, if it doesnt shut off,
Check speaker system, connect one at a time to find the cause.
• If the receiver still shuts down without the speakers,
troubleshoot inside the unit.
Aug 04, 2012 | Yamaha Rx-a710 Aventage 7.1 Home Theater...
14 speakers hooked up to home theater reciever,shuts off .5 vol
Try less speakers.
The impedance will be to low for this amp.
Regards,
Gerard
May 10, 2010 | Yamaha P2500S Amplifier
Receiver shuts off at higher volumes
The receiver may be too under powered for your speakers or the speaker ohm's may not be matched for your amp.
The reason it is shutting off is likely because the amp is becoming overloaded. At lower volumes the amp can handle the load of the speakers, but at higher volumes the power supply of the amp can't keep up with the power demand the speakers are pulling.
If you were previously able to turn the reciever high without turning off, then there is likley something wrong with the amp or possibly a blown speaker.
Try measuring the resistance of the speakers if you have access to a multimeter. They should normally read 8 ohms for home speakers, but some common home speaker impedances in order from (I'm assuming) most common to least common are are 8, 4, 2(bose), and sometimes 10 or 12 ohms. The lower the number of ohms, the more power the amp will need to put to the speakers and the more chance you could be overloading your amp.
Mar 30, 2010 | Audio Players & Recorders
Home Theatre system goes into MUTE mode while film playing
Sounds like your system is going into a safe mode. This happens when you have a neg/pos reversed hooked up, or your wires are touching. This feature prevents you from blowing up your amp. Check your wires, and make sure the positive is hooked to positive etc. and make sure no bare wires are touching.
Sep 01, 2009 | Audio Players & Recorders
TV Audio won't come through the Home Theatre Speakers
why it doesn't come. just connect the RCA cable to the output pins of TV and connect them to the input female jacks of home theatre receiver. or if the TV has optical out and the home theatre reciever had optical in. thats the best option. just connect one optical cable to enjoy the 5.1 sound. tell me clear problem if u r nt solved.
kanny_amancha@yahoo.com
kanny-sounds.blogspot.com
Jan 26, 2009 | RCA RT2620 Home Theatre System System
Cinemate bose home theatre system
called bose they said to unplug the actual reciever piece from the back of the sub and to wait 60sec and plug back in and turn on. they also said that sometimes a surge protector can cause the remote to foul up
Dec 23, 2007 | Bose Cinemate Digital Home Theater System...
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Audio Players & Recorders
GE GTD120 System Logo
165 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jonathon summesfield
Carlos L. Burgos
Carlos L. Burgos
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
