Question about Magellan Maestro 4040 GPS Receiver
I have a Magellan Maestro 4040 That will no longer pingower on.
This device was working fine for about 3 weeks. Then it would no longer power on. I don't think it is charging properly or at all. I have tried to charge it with the car charger and with theht USB attachment to my computer and it will not power on or anything what could it be ?
I bought it from a friend and it was working but it seems like the conector for the car charger to the device is a very loose conection. Has anyone else had this problem
    President:
  • 1,111 Answers
This is a very common problem with these magellan 3140 and also the 3100,2000,2200t,2500,4000,4040 and the 4050 most likely the power port is damaged and needs replaced.i have these power ports but often they just need re soldered..i can repair these magellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ... to open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Posted on Jun 12, 2009
Acer Aspire 5610 battery won't charge. AC chord is plugged in. Battery reads at 3%.
either dead battery or burned out power supply try buying universal one from radioshack or best buy make sure you can return it if its not solving the problem.
Mar 02, 2011 | Acer Aspire 5520-5908 Notebook
Ipod Nano 5th Gen. 3 months old and died--won't restore either.
A possible problem with the battery. Battery life depends on how you frequently used the devised and how you handled the proper cycle to charged and drained the battery.
Battery charging should complete it's charging hours and you have to properly fully drained the battery at least once a week, this will make the battery life go longer.
Initially try to plug and connect the Ipod into your computer and see to it that it was turning ON, or it was giving any sign that it was responding when you connect it to the computer.
Is there any incidents happen that you got a problem on charging the unit, or any like incidents like power outage on the area or a short circuit on the device charger?
Let me know here again for further instruction and clarification.
micro~
Feb 23, 2010 | Apple iPod nano
Won't turn on
Try holding the power button longer (10-30 seconds). Also, ours does not hold a charge for very long when not used (maybe a week?) try putting it on the charger again.
Jun 25, 2009 | Tomtom ONE GPS Receiver
Blinking lights no response
I was able to fix this same problem by doing a hard reset, and re-synching with my computer.
To do a hard reset, press the power button and the two center buttons, all at the same time. Hold them down for about 10 seconds - when you let go, the tablet will start trying to synch again. Once you go through the synching steps again, everything should work properly.
Jan 10, 2009 | Wacom (PTZ930AC) Graphic Tablet
2 of 4 USB Ports Not Functioning
Most likely a motherboard problem, though you can try and re-do windows, best bet on getting it all to work is Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Though this might really get on your nerves having to do this multiple times, id get a new motherboard.
Dec 26, 2008 | Gateway 4540GZ Notebook
Does the power supply you purchased from LCD Payless still working?
I tried to purchase one for the $142.00 and it was not in stock. I think contaced the person someone recommended on this website. This was his answer:
It seems a lot of people are having problems with the Protron power supply. I’ve been able to repair all the ones I’ve seen so I’m confident I can fix them. I don’t sell the replacement power supply but I’ve heard about the ones on EBay. They seem to be a mishmash of two power supplies (12vdc and 24vdc) wired together with the proper connector. This should work but it just doesn’t sound very clean looking to me and they end up costing $150.
I’ve been charging between $50 and $100 to repair these power supplies. My recommendation would be to send me the power supply I’ll check it out and unless it’s unusually damaged it will cost $50 plus shipping to repair. If I can’t repair it I’ll return ship it and only charge for shipping.
I will guarantee the repair for 1 month. I don’t know what’s causing the power supplies to fail so I can’t guarantee it any longer than that. My feeling about the reason the Protron power supply stops working is two part; could be overheating due to lack of proper ventilation to the power supply; or the TVs power requirement is overdriving the power supply.
Feel free to contact me if you have any questions.
I repair these at my work, so here’s the shipping address:
Dave Simpson
23372 South Pointe Dr.
Ste. B
Laguna Hills, CA 92653
Also, I’m set up for PayPal.
dave@thola.com
Sep 05, 2008 | Protron PLTV-32 Television
Unit doesn't work with vehicle power cable
if you are using the USB cable, that won't work. You must use the bracket plug. the USB cable will charge the unit and you can't use it while it's charging. If using the USB, the system thinks you are either charging the unit or connected to a computer. This is a design flaw.
Jul 04, 2008 | Garmin nuvi 200W GPS Receiver
Palm Z22 will not turn on
I had this problem in the very beginning and a few times after. What worked is the following.
Put it to charge for at least half an hour. You won't see it is charging or anything.
Then, while connected to the charger, press the reset button.
Have you guys tried it like this already?
Feb 02, 2008 | Palm Z22 Handheld
Psp wont charge
i think that maybe the car give the charger too much power and blew the battery or try the battery hope it helps
Jan 22, 2008 | Sony PlayStation Portable (PSP) Console
Iriver Clix problem
yes i river has got customer support in online but i don t know how efficient it is if you had brought it from india , you better contact the vndor and ask for its warranty support man or else give a try connect the i river to another computer with windows xp (i prefer) and then install the software bundled up with your device and try to format the device via the software and then disconnect the device and power it on it will work i think
Aug 06, 2007 | iRiver Clix Digital Media Player
Magellan Maestro 4040 GPS Receiver Logo
255 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
