Question about Logitech Z-2300 Computer Speakers
Strange problems with Z-2300's
Hello.
I just got a Z-2300 system. It's factory-refurbished but is supposed to be 100% working. Anyway, when i went to listen to some music (I use Winamp), the speakers acted strange.
The system powered on, the light on the remote pod lights up, but the system seems to only be operating at 40% power, plus there was almost no sound coming from the left speaker. I turned the computer's volume (my computer is an HP Pavilion Dv6000 notebook, the operating system is Vista Premium) to 100%, and Winamp's volume to 100% with no major effect. It got a little louder, but nowhere near normal. I checked the RCA connections (yellow to yellow, black to black), jiggled the wires, checked for bad connections, but everything was fine. The balance was also centered.
I switched the connections to see if it was a bad speaker, and the left speaker worked in the right RCA jack, but not the left jack. I restarted my computer, and tried again with Winamp, and this time the left speaker was working, but the volume problem was still there.
I know it's not a bad connection to my computer (I plugged these into the 3.5mm jack), because a different set of speakers works fine. I tried using just the computer's sounds (no media players or music), and interestingly, the right speaker worked fine, but the left was still very quiet. I checked the sound card and tested the output, and it's the same story, a normal right speaker and a flat left speaker. There is some sound coming out of it, though, if the right is at 100%, the left is maybe 25%.
Finally, I tried using a different media player than Winamp. I used Windows Media Player, and it was the same; 100% out of the subwoofer and right speaker, but the left was flat, you couldn't even tell if it was working, which doesn't make sense because it worked (kind of) both without any media player and on Winamp.
The computer's speakers work fine, the remote pod works fine, the subwoofer works and the right speaker works, but not the left. They both work with Winamp, but the volume is very low, even when everything's at 100% (computer, Winamp, speakers). I've tried everything short of taking them apart and fiddling with the guts.
My only guess is a bad amplifier or a bad RCA jack. I don't see how the amp is bad though, since the system works fine, except for the left channel.
Anyone else have this problem?
I'd appreciate any help/suggestions!
Thanks
Nick
  • 1 more comment
  • Anonymous Apr 16, 2009
    i have the same EXACT problem. EXACTLY THE SAME. did you find out what to do?
  • Anonymous Apr 24, 2009
    I have the exact same problem, except mine is the right side instead of the left.
  • Anonymous Apr 28, 2009
    Same problem and I found that it's my jack thats going bad. The area of the cord right next to the jack seems to be faulty so that when I bend it a certain way it plays through both speakers (it only plays through the right speaker). It was definitely NOT a problem with my RCA connectors. I'm going to try cutting out that section of cord or maybe just splitting it open to see whats going on inside. Worst case I might have to replace the jack.
I'm having this same problem and have sort of solved it with a really wierd technique I found at Logitech. Evidently this problem is related to the control pod rather then the RCA jack. Try this:
Unplug the control pod from the subwoofer Turn off the main switch Turn the volume knob one full turn, tap the knob Repeat again (2 times) Replug the control pod Turn on the main switch and the control pod See what happens
I found that this got the speaker working finicky after it was almost totally useless. It seems to be cutting out randomly, but fidgeting with the control pod or it's connector jack fixes it. No clue what the deal is here, but your problem is identical to mine so take some time to screw around with these components with music running so you can hear if it suddenly works.
Posted on Jan 24, 2009
Need to restore to factory settings an dont have a reboot disk
Bro...no need to restore to factory..just format your hard disk and reinstall new windows
Nov 17, 2011 | Acer Aspire M1100-B1300A Refurbished AMD...
I have a toshiba flat screen 42 inch. i went to change the channel and now all i have is a white screen and no sound
Hello
The tuner card in your TV is not working I thinks. Anyway set the TV to its factory defaults. It will make all the setting to factory levels. If this also didn't helep you, repace the tuner card.
To restore the TV to its factory setting:
[1] Press Menu and open the SETUP menu.
[2] Highlight INSTALLATION and press ENTER. A new set of installation menu will appear.
[3] Open the SYSTEM STATUS menu. Hilight the SYSTEM INFORMATION, and press ENTER.
[4] Press [ => / [5] Enter your PIN code (or 0000 if no PIN code has been set).
OK
Apr 21, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I went to put a new toner in my Lexmark T520 and it won't print now it comes up with incompatibility in the window...how do I fix this?
Did you replace the toner cartridge with a Lexmark new or factory refurbished cartridge?
If not, then more than likely that's your problem. Lexmark put smart chips in the cartridges that prevents there re-use unless these chips were either replaced or scrubbed clean.
If this is a factory new or refurbished cartridge, contact Lexmark.
Oct 06, 2010 | Lexmark T520 Laser Printer
I am having HP 2300 LaserJet printer. From Yesterday it started printing continuously. When you give one test page from XP It will print that Test continuously without stopping. I need to cancel the Job...
Hello .
First select the configure device menu by up & down arrow keys in display select them by pressing green button find no of copies in sub menu change this value to 1 & set them by pressing the green button.Your value set to no of copies to 1 & your problem will be 100% resolved.
Sep 19, 2010 | HP LaserJet 2300d Printer
Hello, I recently replaced an IBM 20/40GB DDS4 internal drive that was not working(would not accept tape, broken door hinge) with an exact same drive refurbished. I was told today that the drive did not...
i resolved the problem myself by removing the new drive and comparing it to the old 1 the jumpers were configured differently so i changed them and all was fine .. thanks anyway
Jan 20, 2010 | IBM Refurbished 20/40GB DDS/4 4MM INTERNAL...
I have a logitech z-2300 speaker system, one of the speakers (left) sound goes in and out and has been for a while, so is not completely blown. Is there anyway to fix this before its too late...?
its a problem with the speaker, if you could possibly change out the wire, I would suggest that cause there could be a break in the speaker.
If you can't do that then the speaker needs to be replaced.
Dec 01, 2009 | Logitech Z-2300 Computer Speakers
Need to reset my acer to factory installed settings? acer desktop.
While rebooting, press the ALT while continuously tapping the F10 key until it launches the recovery console. This will restore your machine back to the factory settings. CAUTION: all other files, docs,pics,programs will be lost!
Oct 05, 2009 | Acer Aspire M1100-B1300A Refurbished AMD...
Does not turn on
What worked for me (after getting the idea from another post on a slightly different problem) was to plug headphones into the wired remote. The moment I did that, the blue light went on and the speakers worked. They continued working even after removing the headphones. I think it was an issue with the wired remote, but anyway it's working fine now.
Jul 19, 2009 | Logitech Z-2300 Computer Speakers
Lexmark 2300 driver
I cant load my lexmark 2300 onto my new computer with vista windows
Apr 03, 2008 | Lexmark X2350 All-In-One InkJet Printer
Logitech Z-2300 Computer Speakers Logo
755 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
