Question about Motorola Mobility ROKR E6 Smartphone
Screen Alignment of Motorola E6 not responding at Bottom right
The touch Screen of the Motorola E6 has some how lost its alignment. and when trying to realign the same, the bottom right cornor of the screen is not taking the input though I can hear the tap sound from phone, when i touch that part.
This issue has caused the right sight of the screen to misread the inputs e.g. if i press "P" in vertual keyboard "O" gets pressed also it has stoped the scroll bar to work properly.
  • Guria Nov 12, 2008
    Hi Team.
    The screen of my Motorokr E6 gets hanged at times, it does not respond at all.
    Scholar:
  • 29 Answers
There's two possibility, which for ur case i suppose, a simple format will help. Format ur phone (soft format goes with -- factory setting) which i remind you, it will erase all your data, back up ur datas to computer first or to ur memory card, and ur phone book to simcard or to pc, anywhere u want. the hard format-- u must go to technician after the soft format fail.
if the two format doesn't help at all, that means ur touchscreen surface is having problem, bring it to technician to get it fixed.
hope u get lucky by just formating - cost u nothing.Gud luck
Posted on Nov 13, 2008
Align screen
The digitizer might be damaged. CONTACT US
Mark
Motorola Support
Aug 18, 2014 | Motorola RAZR Cell Phones
Garmin iQue M3. Gradually not responding to touch
First make sure the screen is clean of any dirt or oils that may deposit on your screen from your fingers. Use a stylist (a mini pencil like item that came with your GPS) or and other non metal semi pointed item and go through the screen alignment process. Hit the "X's" as you see them (it will move 4 or 5 times to ensure the screen is aligned.) After it is aligned it should give you other options. I have seen GPS's recycle trough the alignment process two or three times before cycling out. If you do this and you are still you are having issues, and you have tried resetting it, you may have a hardware issue.
Mar 07, 2011 | Garmin iQue M3 Pocket PC GPS Receiver
HTC Touch Diamond screen alignment
Hi
with the one i have, i have to take the battery out leave it for ten minutes and try again- if that doesnt work do it again -
get someone to phone you - try and tap the settings.
If this doesnt work - try the above again -
after 3 /4 times you will be able to get into settings and realign......
cheers
Sep 11, 2009 | HTC Touch Diamond Smartphone
Touch screen not responding
Double check at the back of the phone if the LDI (liquid damage indicator) is white. If it's red; phone has been liquid damaged. If white, try to master reset phone. then powercycle it. Retest if phone works, if not contact your service provider for other options and for more troubleshooting process for your phone, if it needed to be exchanged or not.
Aug 11, 2009 | Motorola Mobility MOTOROKR E6
My touch screen is not responding
My touch screen has not been responding but my navigation buttons are working. I'm not able to check my contacts too.. .
Oct 27, 2008 | Motorola Mobility MOTOROKR E6
Motorola e6 freeze
the phone stop responding the touch screen stop working, it turns on but no other action after that. phone was not drop or any water damage. any suggestions to reset phone
Sep 10, 2008 | Motorola Mobility ROKR E6 Smartphone
Sudden switch offf....................
Hi. 1st u go urs mobile setting and restore ur fectory setting its code is 00000.
Mar 06, 2008 | Motorola Mobility ROKR E6 Smartphone
Problem in motorkr touchscreen
check the slider switch on the right side
Bottom row of touch screen won't work
may have a sollution for ya. i cant spell. try to reset the alignment on the screen. i had the same problem once and somewhere in settings you can RESET the screen alignment. good luck
Dec 29, 2007 | Alpine IVA-D300 Car DVD Player
Motorola Mobility ROKR E6 Smartphone Logo
180 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
