Question about Sony Cyber-shot DSC-W200 Digital Camera
Slow speed Hello My camera (sony dsc w200) became very slow even if remove memory stick. I tried a lot like format & reset what should I do It takes much time to start
    Champion:
  • 225 Answers
If it is a circuit board problem, it can only be repaired with a replacement board.
Posted on Nov 13, 2008
I have Sony DSC-S40 camera with MS 1Gb, when i switch it on i have "access" then error message says" Memory stick error" and flashing "C:13:01" and I can't take photoes or...
Hello and Welcome to Fixya!
C:13:01 memory stick error message indicates a Self diagnostic message.In C:13:01 the issue may be with the Internal Memory or with the Memory Stick.
To solve it try the following solutions
Format error with the Internal Memory which can be corrected by formatting the Internal Memory.
If it is issue with memory stick then turning the power off and on again or taking out and inserting the "Memory Stick" several times may help in resolving the issue. Error may be because of Unformatted "Memory Stick" which can be resolved by formatting the Memory Stick in the Camera If it not remove by formatting in the camera then connect it to PC and tried to format it again but either FAT instead of FAT32 which is the regular format and then reinserted the memory stick and formatted it with the camara. Now it will be solved if it still exist then it means Memory Stick is broken or not compatible which can be resolved by inserting a new compatible Memory stick
I hope this solution helps you
Your token of appreciation in the form of four thumbs and testimonial will be esteemed.
THANK YOU and Keep Visiting FixYa
Apr 09, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
When I switch it on, I get this error: Memory Stick error C 13:01 camera Sony cyber shot DSC-P73
I hope it will help you
Your Rating as Four Thumbs which are given below to this solution will appreciate me
Thanks
Mar 02, 2011 | Sony Cyber-Shot DSC-P73 Digital Camera
Hello, my sony cybershot DSC-W200 is stuck on USB Mode since last night ( Mass storage) and doesnt want to change program or take any pictures. Is there anything i can do such as reinitialise it with a...
The same thing happened with my dsc-w220. while i was on chat to get help i tried inserting and removing the usb connector cable to the camera. i did it a 5 or 6 times. it works now.
May 18, 2010 | Sony Cyber-shot DSC-W200 Digital Camera
Can i use a memory card SDHC for my digital camera sony cyper shot DSC-w200 or not?
According to Sony, your has 31 mg of internal memory and can use either Memory Stick™ DUO Media, or Memory Stick DUO PRO™media
The information is below:
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=20008504#specifications
Sep 19, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Sony cyber-shot dsc-w200 taking blurry pictures in auto mode...
Its due to slow shutter speed setting.
If you want to take moving object picture, set high speed shutter, there would an icon of golf stick that is for moving object pictures.
Mar 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Sony cybershot DSC W30 buttons fail
take the battery out and let the camera sit for an hour or two, take out the memory card, try to view photos on computer, if it does not work, you will have to format the card and start over. Some times when the format on the card is bad, the camera will not work properly. I have two cybershots myself.
Mar 13, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
No memory space in internal memory-no more pictures can be taken!
there may be two problems. 1. Format your card before using it. 2. Switch your storage device to memory card and it will work. Hope it works..:))
Mar 10, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Camera reset for w90 and w200 sony
If camera is DSC-W90 and DSC-W200, go to camera menu and select Initialize -> OK
That will Reset camera to factory default settings.
Feb 23, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Sony Cybershot DSC S650 Memory stick not formatting
Well I have the same camera.
And mine won't turn on.
Suggestion dont trust this camera.
Or maybe it just can't hold that much memory.
Mar 15, 2008 | Sony Cybershot S650 Digital Camera
Is a "high speed" memory card necessary?
In the case of the SONY stick. Yes. The original sticks were too slow for some applications.
Sep 08, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Sony Cyber-shot  DSC-W200 Digital Camera Logo
188 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
