Question about Intel D101GGC Motherboard
Sume time not booting os.then windows opening very slow
I m also new installed to os. But not booting in os. sume time disk boot filear, incase in my system booting properly windows opening very slow it is take to more then time. again sys working in 15 min totally anging mouse then keyboard not working. then again not booting and disk boot filear message. what is the problem? then How solve in this problem please tell . i m waiting in your mail.
    Problem Solver:
  • 18 Answers
Hi there
you might have a failing hard disk or motherboard, try clear c-mos battery and try again . Also replace any faulty ram and other hardware that may cause the problem , unplug FDD, CD ROM and other devices , replace keyboard and mouse
Regards
Roger
Posted on Nov 12, 2008
I have a computer, with microsot xp home edition service pack 3 system model KM400-8235 total physical memory, 1,280,00MB available 428,91 gb total virtual memory 2.0 gb available 1.96 gb page file...
If you boot from the Windows CD you should have the option to Format the Disk. Since you are using an Upgrade you will need to format the disk and install the Original OS then do the upgrade again.
Sep 28, 2011 | StarTech.com StarView SV211K 2-port KVM...
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
Just installed a HS12YHA in a MacBook Air rev a and the drive is not recognized with disk utility or found when attempting to install OS X.
new drives need to be formatted when purchased (incase you didn't do that, just covering bases)
in the case that you have done that, and it still won't be recognized it might be worth getting an external enclosure for the new drive (the HS12YHA) in the enclosure and format it as an external if that is an option.
if that's not an option booting off of the copy of the OS X install and attempting to repair the disk and verify its permissions might solve the problem as well. Running certain utilities such as Disc Warrior will locate bad blocks (if any) which can also signify if the drive is no longer functioning.
If the drive clicks or doesn't make any signs of turning on at all such as not showing up at all in Disk Utility when booting off install DVD or from another copy of the OS, it may be DOA and need to be sent back for RMA processing.
However from my findings, it looks like the HS12YHA is a PATA hard drive where as the macbook air uses a SATA style hard drive. So it could be possible you were shipped the wrong hard drive.
hopefully that helps good luck
Feb 15, 2011 | Apple 13.3 MacBook Air 1.6GHz 2GB RAM...
How to remove one operating system in dual boot?
-right click on my computer, select properties
-move to the advanced tab
-under 'startup and recovery' select settings
-in the new dialog box you have a couple of options:
-if you wish to leave DOS on the machine, but not see the option screen you can simply set the 'time to display list of operating systems:' to 0 as winXP should now be ur default OS
-if the removal of dos is your goal, then click edit
-first save a copy of the notepad file which opens 'boot.ini' just incase you make a mistake
-now there will be a lines similar to:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn
*There will also be a line for dos here under [operating systems] something like 'multi(1)disk(0)partition(#).....'
-check that your default line points to XP, as it does above
-now erase the line with the other OS, in this case DOS 7.1 ie. 'multi(1)' NOTE *the entire line may be more than one line in notepad*
-save the file
-then you are free to erase the folder associated with the erased OS NOTE *if a mistake was made, you may wish to do this as the last step*
-reboot your system and its done.
-upon any mistakes load into either DOS or XP, etc which ever is easiest (or still remaining on your system)
-copy the old boot.ini over the modified one, and try again
-good luck
Feb 01, 2011 | Computers & Internet
How to parition the harddrive for windows
If You Have Problems Creating a Partition If you have problems creating a Windows partition, check the following: * The disk must be a single partition, formatted as Mac OS Extended (Journaled). If the disk already has more than one partition, you must repartition it. * The disk must be an internal disk. You cannot use Boot Camp Assistant to install Windows on an external disk. * If a dialog appears saying "The disk cannot be partitioned because verification failed," try repairing the disk using Disk Utility and opening Boot Camp Assistant again. If that doesn't work, back up all the information on your computer, start up from your Mac OS X installation disc, and erase the disk using Disk Utility. Restore the information to your computer from the backup and try opening Boot Camp Assistant again.
Dec 22, 2010 | Apple MacBook Pro Notebook
Cant we install multiple OS if i install multiple OS only the new OS will be booted the recent OS will be gone
that is because you are installing over the old one or simply upgrading the old OS, if you want a "multiboot" system each OS has to have its own directory on the drive, IE windows vista installed to c:\winvista and windows XP installed to c:\winxp your c:\boot.ini file which is where boot information is stored should update itself automatically, i do not suggest messing around in this file if you do not know exactly what you are doing as you could render the system unbootable
Feb 25, 2010 | Intel DG31PR Motherboard
Windows boot manager
Hit F8 a few times while your computer starts to boot, a boot selection screen should come up. Try selecting "Last Known Good Configuration" and see if you can boot up without running the repair install.
Sep 02, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Dell b130 internal system restoration failed
Incase you don't have any thing important on the computer try a factory restore. This will wipe out everthing and make the cmputer like new. To start it power off the laptop. Power it on and hold down ctrl and tap f11 severl times at the Dell logo screen. Try this q couple of times as it may not work the first time. If this does nothing you'll need the os cd (xp cd) tO repair or reinstall windows.
Aug 07, 2009 | Dell Computers & Internet
Error of not booting of operating system in a cd-rom
select boot option to your hardisk to boot from your Windows. be sure that Windows is not corrupted so that it can boot normally the system.
Jun 07, 2009 | Dell Dimension 4700 PC Desktop
Winxp cannot boot - missing files message
Just make sure you get these files on your computer.
Download hal.dll from here:
http://www.dll-files.com/dllindex/dll-files.shtml?hal
Place it in windows\system32 folder.
Now go to the drive you have windows installed in (C:/ for example), and then create a new file, name it boot.ini.
Open boot.ini with notepad, and enter this:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS /usepmtimer
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Save boot.ini now, and try booting your computer, it should work.
Nov 17, 2007 | Computers & Internet
Intel D101GGC Motherboard Logo
112 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
