Question about Nokia N70 Cellular Phone
N70 restore font
I have installed verdana font in my n70 and now i want to restore my original nokia n70 default font.I cant able to restore my default font. What i have to do for this.
  • 49 Answers
DOWNLOAD FONT REMOVER SIS FILE FROM GOOGLE SEARCH INSATLL IT IN UR MOBILE IT HELPS U
i guarantee my solution is always right
plz dont forgetme to rate on fixya (blue line)
Posted on Nov 12, 2008
No formatting nokia n70 phone
Posted on Sep 26, 2011
HI GUDPM JUST WANNA ASK HOW TO DOWNLOAD FONTS IN NOKIA N7O????
Changing N70 Fonts f you are one of those who do not like the plain default font or if you are a "dare to be different" kind of person then this one is for you! Change the fonts to whatever you have available or whatever suits your taste. Get ready for a little facelift for your phonemag-glass_10x10.gif smile.gif
Some background information: Nokia N70 does not use TTF font files, instead it uses GDR file which is a compilation of all the fonts that will be used by the phone. What we will do in the following steps is select the fonts that we want to use, use an application to compile the GDR file containing those fonts and finally uploading the font to the handset. Alright, time to begin.
#1. Download and install GDR crreator Download it here. http://www.crazylittleworld.com/n70/egdrsetup.zip
#2. Run the application. Dont worry about the funny language. I will explain how to use it to make working fonts.
#3. You will see various tabs in the application. Each tab is there to set the font for a certain part of the phone. The phone preview on the left shows the part where the font belongs. Navigate till you get familiar with what is under each tab.
#4. Under each tab, click browse to select the font, set the size (defaults should work fine unless your font is too small or too big) and select whether you want just the basic character set (ASCII/Unicode) or want all the characters + symbols from that font (Symbian/Unicode). From my experience Symbian/Unicode is only needed for Text Messaging (2nd tab in the application). See the image below for descriptions on application.
Easy GDR
#5. After you've set the font, click the "Compile Font" button (see image below) to add the font to the GDR and have a look at "Preview Font" window to get an idea of what the font will look like on the phone.
Easy%20GDR
#6. Finally, click the "Compile to GDR" button and save the file. Name it as you please.
Easy%20GDR
#7. Now transfer the GDR file to your N70 via Bluetooth. Create a folder named "Fonts" in C:\System and copy the file from inbox to the Fonts folder (like we did with the Screensaver files above). In the end you should get this - C:\System\Fonts\<filename>.gdr
#8. Delete the GDR file from Messaging -> Inbox and restart the phone.
Jun 16, 2011 | Nokia N70 Cellular Phone
Tip
Radio Interference affecting the UPS
Erratic operation up to and including load loss due to radio or camera flash operation. Do not operate or let customers operate a radio or a camera flash near the critical power systems, especially if the doors are open. Various manufacturers have recommend not to use these devices near the UPS or other Critical Power Systems.
1. Depending on the physical layout and components used on the control boards, the controls may be affected by an Radio Frequency (RF) signal of relatively low strength at the right (wrong to the control circuits) frequency from a hand held radio.
2. Microprocessor circuits which often have a crystal for clock frequency, may modulate the signal in with the clock frequency and cause the CPU to lock up due to a missed or garbled instruction.
3. Analog circuits with high gains, high impedances, and diodes, may demodulate the RF signal and cause the controls to malfunction.
4. So far, cellular phones have not been detected to cause a problem, but it is still a good idea not to get them too close to the control circuits when in use.
NOTE: Units built for certain military applications must meet RF interference
susceptibility specifications. They have special shielding installed, but
even they may not meet the susceptibility specifications with the doors
opened.
5. It has been witnessed for a UPS to blow inverter fuses when a strobe flash on a camera was charging and the UPS doors were open. The RF from the strobe oscillator caused an inverter bridge to misfire.
6. It has also been seen to knock down a microprocessor controlled UPS when the strobe flashed and caused an EPROM to misread even though the UV eraser window on the EPROM was covered with a label. light still penetrated enough to garble the instruction to the CPU and cause it to lock up.
on Oct 21, 2011 | Computers & Internet
My nokia n70 is not being restored to its original settings
Dial *#7370 and this will restore factory settings.
Default password, if asked: 12345
Mar 23, 2011 | Nokia N70 Cellular Phone
Font color editor for nokia n70
generally you cant change the fonts.. the better thing to do is use the default nokia theme which wil be in blue color..
Mar 24, 2010 | Nokia N70 Cellular Phone
My nokia n70
formating memory card wont solve your problem, memory card is just a removable storage device.
Folow these steps to format your phone.
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to mmc memory card.
3. Switch-off your phone.
4. Press and hold these 3 keys; Green dial key, * (star key) and no. 3 key and then press the power on/off to switch on the phone.
Remember, do not let go all of the keys, hold until you see a formatting word screen show!
5. After a few minutes when the full phone formatting completed, your phone will be back to original system and factory setttings.
If that doesnt work, you need to take it to a service centre for a firmware flash. it is risky to do it on your own, you might destroy your phone
May 23, 2008 | Nokia N70 Cellular Phone
Original n70 font
u first uninstall the new font by font remover...
May 03, 2008 | Nokia N70 Cellular Phone
Font
i hav got the font remover for nokia phones and
i hav provided the download link here......
http://rapidshare.com/files/119047347/FontRemover.sis
Apr 14, 2008 | Nokia N70 Cellular Phone
How to restore nokia n70
cant send sms's. the smssync is no longer on my phone. need to restore the factory default software or get the sms sync to install on my phone. please help.
Apr 04, 2008 | Nokia N70 Cellular Phone
Font size reduced
TRY TO FORMAT U R NOKIIA N 70....
DO U KNOW CODE FOR FORMETING......
HOPE U KNOW....IF DONT MAIL ME AT
SIGMA_SHIVA1@YAHOO.CO.IN
I WILL HELP U...
HEY DUDE,,,,,,DONT FORGET TO VOTE FOR ME MAN....
Nov 04, 2007 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
739 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
