Question about ASUS Degatto Notebook
CMOS replacement for ASUS d1
Hi! i own an ASUS Degatto desktop replacement and it does not have an internal battery. everytime i open my laptop it always goes to the CMOS setup i am suspecting the problem is in the CMOS battery i tried opening my laptop to replace the CMOS battery but i can't succeed, can you help me with tips how to open up my laptop? thanks!
  • Marymmcc Feb 01, 2008
    2 years later....I cannot access the cmos battery either. Anyone?
    President:
  • 2,961 Answers
It's difficult to say but you will need to remove the underside screws and also maybe even the keyboard as it's often attached to the base. The cmos battery could also be behind the screen. Comment by sandrew, posted on Nov 12, 2006 I'm sorry but I dont have any personal experiences with your particular laptop, but the lcd's are generally held in with 1 screw in each corner normally covered by a rubber bung hiding the screws, I would be very carefull not to disconnect any wires behind the screen, if yor not sure take it to a qualified repairer. You will probably have to remove the top panel just below the hinges as they may be held in underneath
Posted on Nov 13, 2006
SOURCE:
How do I find and replace cmos battery on Clevo M762T/Sager NP7660 laptop notebook?
Your laptop CMOS battery is CR2032 and instead of writing the instructions on how to replace the CMOS battery I am posting the link where it has been illustrated with images/pictures.
http://www.paulstravelpictures.com/Laptop-CMOS-Battery-Replacement/
I hope this helps, please let me know if you have any further questions.
Best regards,
Amar Sondhi
Nov 20, 2013 | ASUS D1 500 (ap d1500) Barebone
Acer troubleshooting guide
Hi Sir,
You have a problem with your BIOS, to settle it down follow the followings:
1. Open your Computer Case
2. Pull-out the CMOS battery,
3. Replace the CMOS battery with a new one.
4. Set the BIOS again into default, with correct time and date.
ENJOY....
Hope it will help you.
Nov 05, 2013 | Computers & Internet
Hi! I have a problem with my ASUS laptop model A8E INTEL C2D T&!)) 1.8 GHZ/2GB DDR2. My battery is already drained. When I plugged it in(NO BTTERY) the screen is totally black, and no blinking process...
Hello hongeong and Welcome to Fixya.
Good job in describing your problem! I actually had that very same experience with a DELL machine and the only resolution is to replace the BIOS battery.
This battery keeps track of the current date and time (as defined by user) and updates it every second. If there is low, or no power in this battery, then the date/time update will stop and this will be "sensed" by the machine during POST (Power On Self Test) - this occurs when you turn on the computer.
I strongly recommend for you to take this machine to the nearest service provider as tearing your system apart to reach the whereabouts of the BIOS battery on the system board is a very difficult feat and requires the necessary tools and training to get it done correctly and avoid further issues.
For more information, go visit their support site at :
http://support.asus.com/
I hope this helps, and Thank you for using FixYa.
Mar 12, 2011 | ASUS Computers & Internet
Cmos problem: always reset cmos everytime unplug the power cord , but as long as it unplug, it wont reset. change the battery, recheck every cord, reset cmos, check jumper position as manual, done but...
A coin-cell battery (CR2032) usually powers the real-time clock and CMOS memory. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. When the computer is plugged in, the standby current from the power supply extends the life of the battery.
Just open the desktop, locate the CMOS (Coincell) and remove using screw driver. Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Feb 21, 2011 | ASUS P5P43TD Core 2 Quad/ Intel P43/ DDR3/...
Every time i open my laptop, I had to press F1 to load the windows, and I think I read, cmos battery is low. I have to change the date and time everytime I turn on the laptop. Is it really the CMOS...
Yes the cmos battery is the problem, the laptop must be dis-assembled right down to the motherboard where the battery is located in order to fix this issue.
Feb 02, 2011 | ASUS A6U Notebook
Howto boot from usb hdd on Asus D1 Degatto. Should I upgrade BIOS? Thanks...
Some laptops cannot boot up from a USB port. If the BIOS does not have the USB as a boot device then a BIOS upgrade may give you this capability. You need to check the ASUS WEB site to see if the BIOS upgrade will support an USB boot up device.
Dec 02, 2010 | Computers & Internet
My time & date stops. Have to reset them everytime.
Computers use a button type battery to keep the internal clock running when powered off. It's time to open it up and replace the button battery ;-)
Aug 07, 2010 | Computers & Internet
How do I replace the CMO
CMOS battery is that one, which keeps the bios settings and the time. That is now surely is not charging up and it has to be replaced. That is just like a coin. CMOS battery of desktops are easy for desktops, but i am not sure, where it is ( on mainboard though) exactly and the laptop should be opened. please take it to a repair center if you are not willing to open it yourself. its not a huge problem and do not worry.
thanks
Apr 18, 2009 | Acer Extensa 390CX Notebook
Penryn1600sli CMOS check bad error
That sounds like a classic case of a dying cmos battery.
Dec 18, 2008 | ASUS Terminator A7SC (TERMINATOR...
Disassembling ASUS Degatto Laptop
The cmos battery is held beneath the plastic shelf directly below the hard-drive. You will either need to force the shell apart enough to get to it; or, do like I did and remove the HD and carefully use an exacto knife to cut a small square out of the HD shelf. Just remember to cit slowly and let the knife do the work, not forcing it through the plastic! Patience grasshopper will bring great rewards! Hope this helps! J
Nov 11, 2006 | ASUS Degatto Notebook
ASUS Degatto Notebook Logo
358 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
