Question about Olevia Televison & Video
Lost signal tried to reset and go back to factory settings as something was off with my resolution and colors etc and now i've got a black screen
    New Friend:
  • 99 Answers
Try master resetting, check the manual.
Rifaa
Posted on Nov 12, 2008
I was on a webpage this morning and everything was fine. When I moved my mouse, the screen turned pink (all the way into the explorer bar, not just the webpage) with something that looked like a barc
when you say you've reset the drivers, what do you mean?
you may need to download and install a new driver for your display adapter as the installed driver may have become corrupted.
Mar 09, 2012 | Toshiba Computers & Internet
We have a Phillips plasma tv and the picture pixelates randomly and freezes for about a second and sound breaks also. We have had everything checked and have been unable to find a solution. The latest...
In my openion, Its problem of hardware in your TV and signal processing circuits are involved. It might be problem of Firmware (programe to control the performence over all) Philips can advise you better in this regard.
Aug 01, 2008 | Televison & Video
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
BLACK SCREEN AND POWER BUTTON WILL ONLY BLINK OFF AND ON
This sounds like the signal coming from the computer may be out of sync. Do you see anything on the screen while the computer is starting up, showing the POST text (testing memory, etc.)? If so, try connecting another monitor and set the resolution to something low.
Then, reconnect the monitor in question and set your preferred resolution. If this doesn't work, slowly increase the resolution until you reach an acceptable one.
I hope this helps.
Dec 20, 2010 | Dell Computers & Internet
Samsung LN22C350D1D FACTORY SETTINGS??
1. Do what you did, enter to service mode, and reset to factory default.
2. Use the component cable (green, blue, red, white, red) connect your set top box to the TV’s component input.
May 10, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
My monitor's screen resolution and color depth are at a very very low resolution and I am unable to increase/improve this. Consequently, everything is fuzzy and colors are impossible to view. My monitor is...
please try doing a factory reset of the monitor.
please press the menu button on the monitor itself. you can easily locate the buttons below or on the right hand side of the screen on the monitor panel.
select the factory reset /recall options with the help of the arrow/+ - buttons.
this would reset your monitor color settings to default.
Jan 22, 2010 | CTX Computers & Internet
TV suddenly lost the ability to project red
Reset the colors setting back to factory original setting.Should have all colors back to original.Not than ur main tuner signal board is dead,must replaced.
Jan 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
No GPS signal?
I had this problem (waiting for a valid GPS signal). I did a factory reset and the unit started working again (yes, I lost all my settings, but what good is a GPS unit that just sits there waiting for a valid GPS signal?). To do a factory reset, go to menu -> change preferences -> Reset factory settings.
Jan 17, 2008 | Tomtom ONE GPS Receiver
Colors in QL-711V shifted to green
Hi, I had the same problem and I wrote an email to Nu. They wrote me back that I should use the Factory reset feature which you have to go through the Factory Menu to get to. Instructions to do this are as follows. I got to the menu my first try but it has been a pain to get back to it. I hope it will be easier to access for yours.
Hope this helps
-Nate
Page 1
You will need to display a gray scale picture which varys from black to white
You will need to display a gray scale picture which varys from black to white. Displaymate 16 grays pattern is good or something like the picture to the right. 1 Press and hold SEL/AUTO and press the power button. Then release the SEL/AUTO button. 2 Press the MENU key to display the factory menu. Sencore 11 gray Pattern 3 Press the and select FACTORY2 menu. Factory2 is at the bottom. Press SEL/AUTO to select the FACTORY2 menu. 4 Press the to select AUTO COLOR. 5 Press the to run AUTO COLOR. Wait until finished. You will see the colors changing and then become stable when finished. About 10 seconds. 6 Press the and select COLOR UPDATE. 7 Press the to run COLOR UPDATE. It will finish quickly. < 1second. 8 Press MENU to exit the menu. Power off/on.
Nov 05, 2007 | NuTech QL-711V 17" Flat Panel LCD Monitor
Picture black and white , no color
try resetting the tv back to factory settings under within the tv's menu setting you should find a setting to reset the tv, most likely all the color and contract settings may have been tunred down,
Sep 08, 2007 | Sony KP-61V90 61" Rear Projection...
Televison & Video Logo
94 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
