Question about D-Link AirPlus DI-524 Wireless Router
Dont know the password and user name
Want to connect n95 to dlink DI-524 but dont know the password and user name of dlink DI-524 how do i get it and start internet on my mobile?
  • 1 more comment
  • rudolfrebell Nov 12, 2008
    want to connect n95 to dlink DI-524 but dont know the password and user name of dlink DI-524 how do i get it and start internet on my mobile?
  • Anonymous Jan 14, 2009
    i cannot install my wireless router. is the log-in admin and password is none meaning nothing... just press enter
  • Anonymous Feb 04, 2009
    The server 192.168.0.1 at DI-524 requires a username and password.
    Warning: This server is requesting that your username and password be sent in an insecure manner (basic authentication without a secure connection).
Ok, i thought i should enlighten you with my solution. I had the same problem - admin and blank password did not work. With everything hooked up properly and turned on - press and hold reset button with a pin for at least 10 secs, a looooong 10 secs. The lights do not go out until you release the reset button. NEXT, close ur INTERNET EXPLORER (make sure you are using I.E. for this), then open Internet Explorer. Now type in that stupid http://192.168.0.1 hit enter. A new screen should appear (called AIRPlusG) where you can change the password - change the password! Click on "Status" and you will see that same username/password. Username: admin, then your new password. Should connect you
Posted on Jun 03, 2012
User name: admin
password: (blank)
Posted on Feb 18, 2009
    Genius:
  • 1,913 Answers
Http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically.
Posted on Nov 12, 2008
Does a D-Link DI-524 Router have User Password Protection? If so, How do I Initiate It? I have Several other Users Gobbling up My Gigabytes!
All routers can be setup to have a secuirty password. For DLINK, go to http://192.168.0.1 and login using admin as user name and leave the password blank. Once you're in, go to the "Security" tab or option and click on WEP or WPA, select the encryption, choose a password and click save or apply.
I hope this helped you.
You can rate my answer if you appreciate my help.
Thanks!
-damneddle
Oct 14, 2011 | D-Link AirPlus DI-524 Wireless Router
I need a pin# for my D-link and I am unable to find it on the router or the manual. I can't access my inernet with it.
Dlink defult paswords:
1. Name: user Password: blank
2. Name: admin Password: blank
3. Name: admin Password: admin
Aug 25, 2011 | D-Link AirPlus DI-524 Wireless Router
How do i upgrade my firmware on my dlink dl-524?
Go to the following website to download the firmware update for the DL-524. This will save the firmware update to your harddrive:
http://www.dlink.com.au/tech/Download/download.aspx?product=DI-524&revision=REV_B&filetype=Firmware
1. Open the web browser
2. Type in the IP address of the DL-524 router.
3. Type admin in the user name field
4. Type the password you set on this device
5. Click on the Tools tab
6. Click the browse button and locate the firmware file you downloaded and saved to your hard drive.
7. Click the apply button to complete the firmware upgrade.
Mar 17, 2009 | D-Link AirPlus DI-524 Wireless Router
Cant connect my laptop wirelessly...
Try to reconfigure your wireless network on your DI-524.
To access the configuration page of your router by Default type in on the address bar 192.168.0.1. On the login page by default the Username is admin and leave the Password blank.
If inside the the configuration page of the router
>Click Home
> Click on WIRELESS located on the left side and you will have the wireless setting of your network
> Change the wireless network name
> Under security choose either WEP or WPA -PSK for this type of router.
> Type in your new network key (also know as Passphrase of Key1).
For WEP use 0 to 9 Number or A to F character and it should be exactly 10 characters.
For WPA-PSK you can use alpha numeric from 0 to 9 and from A to Z. The minimun character would be 8.
> Click on apply
> Click on continue.
Try accessing your wireless network first using your wireless computer. If you are connected to your wireless network try connecting to the Internet.
Jan 27, 2009 | D-Link AirPlus DI-524 Wireless Router
Want to know the pre shared key
If you don't know your pre shared key or forgotten it. You need to access the configuration page of your router and create a new network name and a sign a new network key or pre shared key. Create the profile of your SSID/Wireless network connetion under wireless settings.
Jan 17, 2009 | D-Link AirPlus DI-524 Wireless Router
Connect dlink to n95
Hello...the pre-shared key is also known as the network key, and you can find it within your router settings.
Open a web browser, and login to your router by typing http://192.168.0.1 into the address bar.
You are prompted for a username and password. Enter username: admin and leave the password blank, or enter your password if you have set one.
Go to Home >Wireless. You should see your pre-shared key, or network key there.
Hope this helps you, but please come back to Fixya if this does not work or you need further help.
Connecting to dlink-524 on vista
your key code is the the code that you set fpr the key code di you write it down like it tells you to
Nov 24, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I have my router wireles d-link but i dont have a cd for instal the software i want a software for configure my router d-link DI-524
Hello ,
Actually you do not need a software to configure it. Connect it to your PC with network cable and type in Internet Explorer : 192.168.0.1
And by entering ADMIN user with default (should be ADMIN as well) password you should come to setup page of your router.
For more details pls refer to :
http://support.dlink.com/products/view.asp?productid=DI%2D524%5FrevC#
regards,
Konstantin
Aug 06, 2008 | Computers & Internet
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
Forgot User name and password to encrypt my DI-524 router
reset the router and start over. Instructions on DLinks website.
Dec 22, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
891 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
