While I'me on the internet (adsl), and I receive a call, the internet connection is lost. It takes a few attempts to re-connect it after.
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Do you have dsl filters on all of your phones, and/or answering/fax machines? If so, I'd be calling the internet provider.
    Scholar:
  • 61 Answers
Your dsl provide you with filters and these filters must be install on all the phone jacks then the phone connects to that and there is one that has two opens in the filter this one has to be with the modem installe the same way except the phone goes to the phone side and the modem has (assuming your not using comcast that is totally different setup) there is no filter for comcast...
if all filters are installed properly then check the phone and the line that connects them sometimes a phone has 4 pins in them and the regular phone line has 2 pins in the center make sure you are using a 2 oin phone line after you check the phone base to see which one it requires (for comcast this could be your problem)
Posted on Nov 12, 2008
Printer will not fax I have dsl modem for computer
Hi
If you have ADSL modem for the internet, and same line you connected with Fax then you will need to ADSL splitter to split your adsl line, get the ADSL splitter in market. in splitter you get one male pine or two female pine, male pin you connect the main switch where the connect is come, one female is ADSL there your connect your modem, and other female pin you connect you fax and try. your fax and internet will work both at a time.
Jun 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Tip
How To share a ADSL Connexion with 2 computers
Introduction
It is about sharing the ADSL connection from PC1
(Server) with PC2 (Client).
Assume that the connection to the Internet
configured correctly in the PC1.
* ) Hardware Requirements
A PC running Windows XP and equipped with a network card
(Server).
Internet access.
A second PC with a network adapter (client PC).
RJ45 crossover cable
*)Configuring Server Side
1. Assign an IP address
Click on Start / Control Panel / Network Connections
and Internet
Double click the Network Connections icon
get a new window
Click on the icon Local Area Connection with the right button
your mouse and select Properties. A new window appears
Double click on Internet Protocol (TCP / IP) a new window
appears
2. Share the connection.
Back in the Control Panel and select
Connections.
Then in the window that opens right click
your Remote Access (for example ADSL) and select
Properties option.
A new window appears:
Select the Advanced tab under Connection Sharing
Internet check Allow other network users to
connect through this computer's Internet connection and the
Establish a connection box Dial whenever
computer attempts to connect to internet and confirm by clicking
OK. A new window will open:
To Continue Click Here : .....More
on Jul 15, 2010 | Computers & Internet
Only internet light is blinking
According to the user guide, the modem is trying to connect to the isp. If it is continually blinking, check all your cables. Once you are satisfied all cables are properly connect contact the isp to find out if there is an outage in your area and if not they can help you.
May 25, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Have ADSL Modem and Wireless Router, i connect with UTP cable so dont have internet in my wireless router... I connect my laptop to modem directly and have internet... Whats wrong...??
the wireless router is not properly configured... configure ur adsl and disable dhcp server in the same. and then disconnect it ... then configure ur wifi router with a static internet address that is from the adsl range . put the default gateway as the adsl and save it, connect the adsl to wifi and switch both of them on... ur done... but make sure if ur adsl address is 192.168.1.1 the ur wifi address is 192.168.10.1
Jan 10, 2010 | Cnet CWR-854 Router
I have a DSL502T ADSL Router,and have bought a new emachines computer. I can not connect to the internet. The computer has a wireless connection loaded but I want to connect by dailup Please could you help...
You are a bit confused with the various components required for Internet connections.
If you have a dial-up connection with an Internet Service Provider, all you do is connect your computer's modem port to the phone line and dial the phone number of your Internet Service provider.
If you are connected to the Internet Servise Provider by ADSL and have a combined ADSL router and modem then you connect the phone line to this router/modem. If the ADSL modem is separate component then the phone line is connected to the ADSL modem and this modem is connected to the router with a LAN cable and the computer is connected to the router with another LAN cable. If the route is wireless and the computer has a wireless card then you don't need a LAN cable between the router and the computer.
If you are connected to the Internet by ADSL, to secure your Internet connection and configure your computer so it can connect to the Internet, please follow my instruction - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 17, 2009 | Computers & Internet
My ex-next door neighbour has recently flitted 20 miles south. He can no longer connect to the Internet via his BT Voyager ADSL Router. I think he has lost an essential connection during the removal. In...
Your ex-next door neighbour needs to contact his Internet Service Provider to get a new ADSL connection linked to his new phone line. The original ADSL connection is tied to his old phone line/number and it will not work in his new location. Each ADSL connection is setup at the local telephone exchange and tied to that phone line/number..
If his Internet Service Provide does not operate nor can provide an ADSL service in his new area then he needs to find a new Internet Service Provider.
Oct 22, 2009 | Computers & Internet
Distortion on Netgrear Modem
Hopefully you are directly connected and not trying to use wireless. You can try building or buying a Farady Cage. This should isolate the router from the interference.. Shield cage for router Google Search
May 09, 2017 | NetGear DM602 ADSL-Modem
Unable to connect to Xbox Live!
are you connecting both imac and xbox to the internet at the same time? is your adsl modem a modem/router? and does it have wireless capability?.. if all answer are yes.
assign static ip/subnet mask/default gateway and dns on xbox, then forward 88/3074 on your modem/router.
Nov 08, 2008 | Computers & Internet
On and off line every 20 flashes.
Have you attempted to connect the internet after the router stops flashing? Do the lights start flashing again? If you do, then it would be considered normal.
If they don't and you do not have an internet connection, try the next step.
Next, plug your computer straight into the modem - Do you have an internet connection now? If you do, your router may require configuration.
Nov 10, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
ROUTER CONNECTIVITY
Ok, do a troubleshooting session.
Unplug the router from the internet modem.
Try at first to connect using a Network cable from you PC to one of the LAN sockets.
Can you access http://192.168.1.1  with your web browser?  (the configuration page)
     If yes it is possible that the router has the same address as your adsl modem.
    change the router address to something 192.168.0.1 instead of 192.168.1.1
     Save your changes. Plug your WRT to the adsl modem and try again.
     Does the internet work now with a wired connection ?
If the above does not work can you "ping" the machine ?
      ping 192.168.1.1
if none of that works try doing a hard reset... heres a little guide (off the DD-WRT wiki)
http://www.dd-wrt.com/wiki/index.php/Reset_And_Reboot
Oct 09, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
David Payne
David Payne
