Question about Canon CanoScan LiDE 500F Flatbed Scanner
Could not complete the import command because there is no scanner installed? pleas help
Hi there
Basically my scanner one day decided not to work when i try and import in photo shop it comes up with
Calibration Can not be performed pull out the film adapter unit at frame 1
then
( which isnt even in use?)
I have reinstalled soft wear, gone to the canon website downloaded new soft wear still no luck
when the scanner is attached it dose come on and just makes a noise as if it is about to scan but constant untill i pull out the usb.
please please help
ive tried to use the scanner through the canon tool box and it dosnt work
I'm on Mac OS X Leopard
Same here.  OSX.5.5.  CanoScan 500F. Black Bar down the image. Then downloaded and installed new drivers. Now I get "Calibration cannot be performed. Pull out the film etc..." and no film.  Hooked the scanner to older G4 laptop and it works, but still has black stripe from top to bottom.  What next?
    Guru:
  • 558 Answers
Have you properly connects the Scanner to your MAC PC.
A quick start manual you can get with this link:
Canon Lide 500F Scanner
You can get the Help from official Website just enter the Keywords under Support & Services Search Box: "Calibration cannot be performed"
with this you will get list of Errors and read them and hope it will help you.
Scott
Posted on Nov 12, 2008
  • Puneet Jain
    Puneet Jain Nov 12, 2008
    If the info given in Official website of Canon comes not much useful for you , then you will need to go for
    repairing your Scanner manually. As the problem is related to hardware.
    Thanks for using FixYa.
    Scott
    Sergeant:
    Champion:
  • 283 Answers
1.Uninstall the scanner program
2. restart your desk top
3. reinstall the driver (the orignal driver if availabe)
4. then try scan again.
THANK you.. dont rate me if you are not satisfied.. Thanks again
  • amin dianalan
    amin dianalan Nov 12, 2008
    detached the the usb of scaner and attached it back...tnx
    Guru:
  • 859 Answers
This is a hardware failure at the board level within the scanner. The calibration issue reflects the readers inability to compose the columns in the middle that return as a black stripe. If they were functioning but had a software issue the bar would be white.
Sorry. This scanner is toast.
Hi to everyone : i have lost my Scaner Umax Astra 3600 Driver pleas help me someone email-Ritesh.barange@gmail.com
HELLO, YOU CAN EASILY DOWNLOAD IT ONLINE.GO TO GOOGLE SEARCH,TYPE IN UMAX 2200 FLATBED SCANNER AND DOWNLOAD
Nov 18, 2010 | Umax Astra 2200 Flatbed Scanner
Using adobe photoshop 8 the editor will import from my Epson Perfection 1260, but the organiser will not get from it displaying "Epson perfection 1260 software for this device could not be launched the...
I don't think it's any of those things. I think it's a Twain Data Source problem. When you install the software for your scanner, make sure you also install the twain data source files. This is the scanning protocol used by all scanners and if not present, the scanner won't import images into Photoshop under the command "File" -> "Acquire."
Mar 25, 2010 | Epson Perfection 1250 Flatbed Scanner
Please, how do I install my flatbed mercury scanner 1200cu+. I cant find my installations disk
I found an Windows XP driver here: http://www.mercury-pc.com/download_file.php?option=file&item_id=2870. The documentation for the Mercury KOB 1200cu+ scanner indicates support for Win 98se/Me/2000/XP. On a newer Windows OS, it may not work but you can try and see if a generic scanner driver installs when you plug it into the computer. If it is recognized, scan using Windows Fax and Scan (File, Import from Scanner) or Paint (Import from Camera or Scanner).
I hope this helps.
Dec 16, 2009 | Mustek Be@rPaw 1200CU+ Flatbed Scanner
Exact same problem
firstly I hope the model number is correct. if yes try once again the following steps.
disconnect the Docketport from usb. go to device manager and see there devices marked with yellow exclamation mark. remove them and restart the windows.
1. download the driver and install it
http://www.docucap.com/drivers/DocketPORT465_v1_1_4_setup.exe
2. secondly Docketscan application is needed ..download it too and intall
now try connecting the dockerport
I hope this should make things work.
Aug 07, 2009 | Syscan DocketPORT 465 Scanner
Program won't completely install
what i can suggest is that you download the latest drivers from the epson website,also check if your operating system is uptodate with the latest patches and updates..
see if this helps:
One overlooked reason for getting access denied and/or other problems when installing software is the existence of a file that needs to be replaced but can't be due to a read-only attribute. This most often occurs in the %SystemRoot% directory and its' sub-directories. To display the files in your NT directory that have the read-only attribute, type:
dir %systemroot%\*.* /ar /s
You can remove the read-only attribute from a file by using the attrib command. To remove the read-only attribute from all files in the NT directory and sub-directories, type:
attrib -r %systemroot%\*.* /s i the run command..hope it helps!
Oct 31, 2008 | Epson Perfection 3490 Flatbed Scanner
Unable to scan
Hi Franklin_mus,
Thanks for your posting in FixYa.
It seems to be the problem of the Drivers and incomplete installation. Please uninstall the Scanner and do a complete installation step by step.
Let me know if you need any further assistance from me. Have a Nice day.
Regards
ELLIN
Sep 20, 2008 | Office Equipment & Supplies
My Mustek A3 Scanner Compltetely Freezes Itself and Photoshop
I'm having the same problem with my Mustek A3 and I didn't have this problem at all until I installed the newest version of McAfee virus protection...ever since I installed that stupid program, every time I go to scan something with the Mustek scanner through Photoshop, now it freezes on me at the initializing scanner screen. I even tried the system restore to reset everything before the McAfee was installed and miraculously the scanner works perfectly again. So whatever McAfee has on that disk is screwing up my scanner which is really irritating. And yeah, I tried downloading the new drivers from the Mustek site before I did the system restore and that didn't help at all either.
Jul 30, 2008 | Mustek A3 USB Flatbed Scanner
Preview OK but scan button not available...importing from PS CS2
Very verbose and you have lots of experience - just like me except I can give you 25 years- But to get on. You did not say what operating system you are working. Or the age of the Scanner It is important. Scanners made during the 95/8/ME era were set up for DOS commands from the computer. Now we are in the NT age The computer sends out NTFS commands and scanner cant figure it out. Some scanners were dual system. And you could fool around with the program compatibility facility. But by and large old scanners should be buried.
Jul 26, 2007 | Visioneer OneTouch 8920 Flatbed Scanner
Install my scanner with winXP
In a word you cannot. Try the Acer site to see if they offer a suitable software conversion- but this late on it is not likely. You could try/Start/Programs/Accessories/Compatibility Wizard- then set the software you use to 'Run as 95/98 - it may work. What it amounts to is this- A scanner has its own processor that controls the scan tracking the capture device DPI and all that and in your case it is looking for DOS commands and XP is sending out NTFS commands - and they no speak to each other.
May 09, 2007 | AcerScan Prisa 340P Flatbed Scanner
No image
I had the same problem and I figured out how to fix it. First I unplugged the scanner. Then I bit the cables in half. Next I hit the scanner as hard as possible with a hammer. Then I put it on the floor and jumped on it a few times. After that I covered it with gas and set it on fire. Finally I peed on it as it burned. Then I got a new scanner- an HP.
Mar 26, 2007 | Epson Perfection 1670 Flatbed Scanner
Canon CanoScan LiDE 500F Flatbed Scanner Logo
131 people viewed this question
old marine
old marine
