Question about JVC JX-S333
All of a sudden it shuts off
I have a JVC TH-S33 home intertainment model and just a few weeks ago it started to sut down everytime there wud be a volume increase in the film ( like a car exploding, or guns firing ) i have checked the manual and it tells me that it is becasue of my playback, I HAVE NO IDEA HOW TO SELECT OR CHANGE IT and my manual does not help either!! could you help me
SOURCE: JVC TH-M303
Well this is and isn't a fix. I don't know what the underlaying problem is that causes the Amp to shut down but I have come up with a way to stop it from doing so. What ever the problem is it is triggering a circut on the board called "Protect" which can be circumvented. You need to start by pulling out the amplifier unit from the subwoofer assembly. You will see that there are two circut boards at 90 degrees to each other that are connected by 3 sets of connectors. You need to remove the screws and wire that hold in the board attached to the bottom of the assembly. You can then pull it out disconnecting the connectors. The connector closest to the power trasformer is the one that we are concerned with. On the vertically oriented circut board you will find a small map of the connector identifying pin #5 as "Protect". Inside the portion of the connector attached to the bottom board that you pulled out, use a small set of needle nose pliers to break off pin #5. Then reassemble the amp and put the subwoofer back together. I used this solution and it has been working since. If you have reservations about breaking the pin out then try just bending it out of the way and partially reassembling the unit and powering it up. Once you see that it does indeed solve the problem you can break it out. Like I said, I don't know why it started to turn off spontaniously in the first place but this does fix the problem.
Posted on Sep 25, 2007
n2whd
SOURCE: Subwoofer Shutdown
Whay don't you take a look at your data cable and jack contacts to see if any of them are bent or misplaced. Terry
Posted on Oct 02, 2007
marsrover
  • 682 Answers
SOURCE: jvc th-m45 shut off
shut off audio system is performed to protect it from damage due to high current consumption or short circuit in speakers try to disconnect subwoofer first and check if it is ok. the problem in your subwoofer or its cord-change the cord and check if it is ok thats fine if not change subwoofer.do the previuos for all speaker one by one.
if all above failed you must contact service center for help.
Posted on Apr 06, 2008
freetek
  • 5568 Answers
SOURCE: My remote wont change channels
I need to use the cable remote to change the channel and the TV remote to change volume.
That is because your TV is looking at the output of the cable box (probably on channel 3 or 4) so the TV has to be statically tuned to see the cable box's output.
On the second question; I, and perhaps others, can't answer this without spending a lot of time to download manuals for both systems while you have them (presumably, since they are new) on hand. You didn't include the TV's model number anyhow so even that wouldn't be adequate.
The home theatre may have a receiver but what does it receive? Unless it also has channel capabilities that correspond to cable channels, it can't. The typical routing should be from the cable box to the TV S-video input and the sound can be routed separately from the cable box to either/or both, the home theatre's and also the TV's audio inputs.
When I am installing new stuff, I make a sketch of the routing I want (or have) to use. To me, this is less confusing than the supplied instructions.
Posted on Feb 01, 2009
SOURCE: JVC TH-C& stop working when I increase Volume
Funny enough.... I had this same issue and could not for the life of me figure out what the issue was. I even called a tech out to my house and he was just as confused, called his boss and told him everything that was happening - working fine until a certain "noise level" was reached. The company manager had never heard/seen anything like this before and my house just happened to be in between his work and home so he planned to stop by on his way home. Confusion from us all.... The speaker wires are interchangeable with this system (positive/negative) and when I had moved, still under warranty from where I purchased it from, the company offered to come and re-install everything for me - the ding-dong they sent hooked all positive into the negative and vise-verse. Apparently, the th-c6 can handle this up to a certain point than it shuts itself off to avoid damages??? This is what I was told. Not thinking a electronics tech would install ALL the wires incorrectly this was not something that was first checked, of course. It was noticed as we all three sat around looking very closely at the inputs. It was noticed as we slot by slot checked that the wires were inserted...hmmmm, you think the negative wire in the positive slot has anything to do with it??? LOL, switched them all and worked perfect! Hope this helps.
Posted on Mar 16, 2009
I have JVC TH-L1 sound system and it stopped working
I had the same problem change the fuse before you mess up the circuit board .
Aug 06, 2012 | JVC TH-L1 Theater System
JVC TH-V70 Shuts Down
Hello
Even after disconnecting the speakers, the systems shut down, means that there is something short inside the set. Normally, the output amplifier section circuits will have the short. The set need service, and may have to replace the audio output IC of audio secion. Contact the nearest JVC authorised service center at your town. OK.
Jan 24, 2012 | JVC MX-GC5 CD Shelf System
Subwoofer JVC TH-M606 suddenly stopped functioning
Hiya, sorry that will have to go in for repair as it sounds like it may be protecting. Could be something loose but that would be lucky. Suggest finding a electronics shop in area that can assist. Best of luck
Jul 14, 2009 | JVC TH-M606 System
Subwoofer powers on for about 4 seconds and then shutsdown
I don't know if you were able to get the problem fixed, but I had the same sort of problem where it worked and then all of a sudden it stopped working right in the middle of a movie.
I took it to a repair shop and he found that it was the power supply... a $4.00 part.
Jun 14, 2009 | JVC TH-C30 System
Cannot figure out how to hook up my jvc th c5 to my tv & cable tv
Do you have audio outs on you tv to run to the jvc
Mar 15, 2009 | JVC TH-C5 System
Driver Problem
Please Reinstall once again. By replacing the existing Drivers. And also scan your computer for viruses and spy wares.
Mar 15, 2008 | Dell 924 All-in-One InkJet Printer
Subwoofer shuts down
Check the connection in the back of the sub,where your wire plugs in from the DVD unit, the connector is loose in the unit itself. Had mine replaced and is doing the same thing again
Nov 24, 2007 | JVC TH-M505 System
Subwoofer Shutdown
Oct 02, 2007 | JVC TH-C50 System
JVC KD-LH300
dirty,clean the optical pick-up?
Apr 30, 2007 | JVC Sirius KD-LH300 CD Player
Subwoofer not powering up
I could either be the sub or the main unit. The main unit actually sends a signal to the sub to turn it on so if that circuit is bad in the main unit the sub is never going to come on. I've also seen bad cables (You'd be amazed at how stubborn people can be when din connectors don't cooperate).
Sep 10, 2006 | JVC TH-M505 System
JVC JX-S333 Logo
42 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
