Question about Sony KP-61HS10 61" Rear Projection Television
No large picture only smaller multiple pictures on my Sony 61HS10
I have a sony 61HS10 rear projection tv. The small displays work, showing two or more pictures at the same time but when you want to display just one large full screen picture there is sound but no picture, It will also do a full screen freeze frame. Sound works fine. Color works fine, small displays are all working well, no blurriness. When you push button for one large picture and a small picture in corner from another channel, the small picture works and not the big one.
  • 88 Answers
Found this bit of tech info try this and see if it does the trick.
The convergence feature is used to align the picture tubesinside the television so the image is projected on the screen evenlywithout ghosting or what can be described as a shadow of the image.
IMPORTANT: Some Sony® televisions have the ability to automatically adjust the covergence using a FOCUS or FLASH FOCUS feature,while others have manual convergence settings. Consult the instructionmanual of the television for specific information. Manuals areavailable online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
If adjusting the convergence does not resolve the issue, service may be required .
biigg53566
Posted on Dec 06, 2008
    Genius:
  • 2,035 Answers
Try to play a dvd on the tv and check if its coming in the full screen or does it have same results...Please let me know ...
  • Anand Kumar
    Anand Kumar Dec 06, 2008
    Try this :
    1. Turn off the television.
    2. IMPORTANT:
      For a projection television that uses an internal lamp, wait 5 minutes
      after turning off the television to allow the lamp to cool before
      continuing with the following steps.
    3. Unplug the television power cord from the electrical outlet.
    4. Let the television remain without power for 60 seconds.
    5. Plug the power cord back into the electrical outlet.
    6. NOTE:
      If the television is plugged into a power strip or surge protector,
      remove it from the power strip or surge protector and plug it directly
      into the wall outlet. If the issue is resolved, the problem is with the
      power strip or surge protector and not the television.
    7. Turn on the television.
Sony kp-61hs10 tv, has sound but picture goes black after 3 min.
I just had the same problem. If your lucky it might be a free 5 minute fix. The five light flashes mean impropper current. I took the front grill off, then behind that is another black cover, I took that off and noticed the circuit boards COVERED in dust. I then took an air can duster and blew off all the dust... works like new. No more flashes and in an out picture. The collection of dust was interfereing with the electrical current.
Ben
Apr 15, 2009 | Sony KP-61HS10 61" Rear Projection...
As you told big picture freeze is working ,then there could the problem in the main processors which not to able pick video input signal ...If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:http://servicemanuals.vstore.ca/ which also contains the part number incase you need a new part...
Good luck.....
Dec 06, 2008 | Sony KP-53HS30 53" Rear Projection...
Picture flashing on and off
Press Display / Info button on "TV original remote", such display will disappear.
Nov 17, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection.
Put tv in standby then press above said buttons. You will be in service mode.
Be Care Full while in Service Mode data handling.
Oct 03, 2008 | Sony KP-61HS10 61" Rear Projection...
Picture very blurry with lines going accross screen
hi gud day! your problem has a solution. Just try to fix your tv from blurry picture. Pull the socket at hte back of the picture tube. remove the socket from pcb(printed circuit board) de solder the pins. then after that, if you see a 2 metal formed like a small mountain facing each other, try to clean those remove the rust (green color) using sander or any material you can use, just avoid using oil on that bcause it is sparking. then try to install it again and try to turn on your tv. if still not working replace that socket with a new one. you can buy it at any electronic supply store. and re install then on it again.. surely it will fix your tv without expensive components.
be sure unplugging the tv from ac souce before disassimbling...
thanks,
janex
Mar 31, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 Rear projection TV blurry /shadows at first start
Sounds like the convergence ic's need to be replaced or resoldered. Sometimes it can be a microfuse if you are lucky. But my question is if you hit the focus button up front does it make it thru the auto convergence? Let me know. Have a good one.
Feb 09, 2008 | Sony KP-61HS10 61" Rear Projection...
KP-61HS10
yes. go here
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Dec 20, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection Television, dirty innerscreen
The important thing here is cleaning the refelective mirror inside you tv .We have noticed in dirty areas the dirt on mirror makes blurry picture.THerefore you have to open back cover and than tp cover to clean mirror and also dont forget to claen c.r.t lenses ,sisnce they are mounted facing upward ,lot of dust sit on c.r.t lens there fore clean 3 of them r.g.b..And you will notice on picture diffrence.
Dec 18, 2007 | Sony KP-61HS10 61" Rear Projection...
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
22 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
